Dla jednego silnika podłączonego do WEMOSA pod GPIO 12, 13, 14, 15
Testowałem na ESP32. Na Wemosie też powinien działać.
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
/* This example shows ESP82xx/ESP32 based device with simple WebInterface
used to configure Wi-Fi parameters and Supla server connection.
There is one RollerShutter, one Relay and 3 buttons configured.
Two buttons are for roller shutter with Action Trigger.
Third button is for controlling the relay and for switching module to
config mode.
After fresh installation, device will be in config mode. It will have its
own Wi-Fi AP configured. You should connect to it with your mobile phone
and open http://192.168.4.1 where you can configure the device.
Status LED is also configured. Please adjust GPIOs to your HW.
#include "Stepper_28BYJ_48.h"
// piny pod które podłączony jest Stepper_28BYJ_48 //
#define PIN1 12
#define PIN2 13
#define PIN3 14
#define PIN4 15
Stepper_28BYJ_48 stepper(PIN1, PIN2, PIN3, PIN4);
#define STATUS_LED_GPIO 2
#define ROLLER_SHUTTER_UP_RELAY_GPIO_VIRTUAL 0 // pin wirtualny
#define ROLLER_SHUTTER_DOWN_RELAY_GPIO_VIRTUAL 1 // pin wirtualny
#define BUTTON_UP_GPIO 4
#define BUTTON_DOWN_GPIO 5
#define BUTTON_CFG_GPIO 0
#include <SuplaDevice.h>
#include <supla/control/roller_shutter.h>
//#include <supla/control/relay.h>
//#include <supla/control/action_trigger.h>
#include <supla/events.h>
#include <supla/io.h>
// Choose where Supla should store roller shutter data in persistent memory
// We recommend to use external FRAM memory
Supla::Eeprom eeprom;
// #include <supla/storage/fram_spi.h>
// Supla::FramSpi fram(STORAGE_OFFSET);
Supla::ESPWifi wifi;
//Supla::Device::StatusLed statusLed(STATUS_LED_GPIO, true); // inverted state
Supla::Device::StatusLed statusLed(STATUS_LED_GPIO, false); // inverted state
// HTML www component (they appear in sections according to creation
// sequence)
Supla::Html::DeviceInfo htmlDeviceInfo(&SuplaDevice);
Supla::Html::WifiParameters htmlWifi;
Supla::Html::ProtocolParameters htmlProto;
Supla::Html::StatusLedParameters htmlStatusLed;
Supla::Control::RollerShutter *rs = nullptr;
class VirtualExpander : public Supla::Io {
public:
VirtualExpander() : Supla::Io(false) {}
void customDigitalWrite(int channelNumber, uint8_t pin, uint8_t val) override {
VIRTUAL_VARIABLE[pin] = val;
int customDigitalRead(int channelNumber, uint8_t pin) override {
return VIRTUAL_VARIABLE[pin];
private:
bool VIRTUAL_VARIABLE[8];
void setup() {
Serial.begin(115200);
auto EX_OUTPUT = new VirtualExpander();
// Channels configuration
// CH 0 - Roller shutter
rs = new Supla::Control::RollerShutter(EX_OUTPUT, ROLLER_SHUTTER_UP_RELAY_GPIO_VIRTUAL, ROLLER_SHUTTER_DOWN_RELAY_GPIO_VIRTUAL, true);
// Buttons configuration
auto buttonOpen = new Supla::Control::Button(BUTTON_UP_GPIO, true, true);
auto buttonClose = new Supla::Control::Button(BUTTON_DOWN_GPIO, true, true);
auto buttonCfg = new Supla::Control::Button(BUTTON_CFG_GPIO, true, true);
buttonOpen->addAction(Supla::OPEN_OR_STOP, *rs, Supla::ON_CLICK_1);
buttonOpen->setHoldTime(1000);
buttonOpen->setMulticlickTime(300);
buttonClose->addAction(Supla::CLOSE_OR_STOP, *rs, Supla::ON_CLICK_1);
buttonClose->setHoldTime(1000);
buttonClose->setMulticlickTime(300);
buttonCfg->configureAsConfigButton(&SuplaDevice);
// configure defualt Supla CA certificate
SuplaDevice.begin();
void loop() {
SuplaDevice.iterate();
static bool x;
switch ( rs->getCurrentDirection() ) {
case 0: // RS STOP
if (x) {
digitalWrite(PIN1, LOW); digitalWrite(PIN2, LOW); digitalWrite(PIN3, LOW); digitalWrite(PIN4, LOW);
break;
case 1: // RS DOWN
x = 1;
stepper.step(-1);
break;
case 2: // RS UP
x = 1;
stepper.step(1);
break;
