[311707][I][ZigbeeGateway.cpp:433] zbReadBasicCluster(): Peer Manufacturer is "_TZE200_ps5v5jor"
[312548][I][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): basic tsn 0x63
[312548][I][ZigbeeGateway.cpp:379] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[312697][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[312697][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 10, cluster_id: 0x0000, asdu_length: 14
APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0x2bea
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 255, rx_time: 0
[312699][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1
[312700][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[312700][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[312701][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0
[312701][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 28 size: 11
[312702][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x05
[312702][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00
[312703][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x42
[312703][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x06
[312703][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x54
[312704][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x53
[312704][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x30
[312704][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x36
[312705][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x30
[312705][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x31
[312705][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x2bea, 0x2bea, 0x0, 0x0
[312706][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[312706][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1000) callback
[312707][V][ZigbeeHandlers.cpp:255] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x2bea) src endpoint(1) to dst endpoint(1) cluster(0x0)
[312708][V][ZigbeeHandlers.cpp:263] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[312708][I][ZigbeeGateway.cpp:443] zbReadBasicCluster(): Peer Model is "TS0601"
[313509][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[313509][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 0, src_endpoint: 0, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0002, asdu_length: 3
APSDE INDICATION - profile_id: 0x0000, security_status: 0, lqi: 255, rx_time: 0
[313550][I][ZigbeeGateway.cpp:385] zbQueryDeviceBasicCluster(): basic tsn 0x64
[313551][I][Z2S_Gateway.ino:1757] loop(): LIST matched _TZE200_ps5v5jor::TS0601, entry # 234, endpoints # 1, endpoints 0x0::0x0,0x0::0x0,0x0::0x0,0x0::0x0
[313552][I][Z2S_Gateway.ino:1785] loop(): DESC matched 0x6019, 1, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, endpoint 0x1
[313553][I][Z2S_Gateway.ino:1808] loop(): Tuya magic
[313553][I][ZigbeeGateway.cpp:1487] sendAttributesRead(): Sending 'read attribute' command
[313739][D][ZigbeeCore.cpp:468] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[313740][D][ZigbeeCore.cpp:469] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 234, cluster_id: 0x0000, asdu_length: 55
[313741][I][ZigbeeHandlers.cpp:131] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1
[313742][I][ZigbeeHandlers.cpp:134] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[313742][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[313743][I][ZigbeeHandlers.cpp:142] zb_raw_cmd_handler(): manuf_specific 0x0
[313743][I][ZigbeeHandlers.cpp:146] zb_raw_cmd_handler(): RAW bufid: 19 size: 52
[313744][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x04
[313744][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00
[313744][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x42
[313745][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x10
[313745][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x5F
[313745][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x54
[313746][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x5A
[313746][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x45
[313746][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x32
[313747][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x30
[313747][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x5F
[313748][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x70
[313748][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x73
[313748][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x35
[313749][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x76
[313749][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x35
[313749][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x6A
[313750][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x6F
[313750][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x72
[313750][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00
[313751][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00
[313751][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x20
[313751][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x03
[313752][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x01
[313752][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00
[313753][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00
[313753][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x20
[313753][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x55
[313754][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x05
[313754][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00
[313755][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x42
[313755][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x06
[313755][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x54
[313756][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x53
[313756][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x30
[313756][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x36
[313757][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x30
[313757][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x31
[313757][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x07
[313758][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00
[313758][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x30
[313759][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x03
[313760][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0xFE
[313760][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0xFF
[313760][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00
[313761][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x30
[313761][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): 0x00
[313762][I][ZigbeeHandlers.cpp:158] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x2bea, 0x2bea, 0x0, 0x0
[313762][I][ZigbeeHandlers.cpp:184] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[313763][I][ZigbeeHandlers.cpp:41] zb_action_handler(): Receive Zigbee action(0x1000) callback
[313764][V][ZigbeeHandlers.cpp:255] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x2bea) src endpoint(1) to dst endpoint(1) cluster(0x0)
[313764][V][ZigbeeHandlers.cpp:263] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[313765][I][ZigbeeGateway.cpp:433] zbReadBasicCluster(): Peer Manufacturer is "_TZE200_ps5v5jor"
[313766][V][ZigbeeHandlers.cpp:263] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[313766][I][ZigbeeGateway.cpp:461] zbReadBasicCluster(): ZCL version id is "3"
[313767][V][ZigbeeHandlers.cpp:263] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(85)
[313767][I][ZigbeeGateway.cpp:469] zbReadBasicCluster(): ZCL application version id is "85"
[313768][V][ZigbeeHandlers.cpp:263] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[313768][I][ZigbeeGateway.cpp:443] zbReadBasicCluster(): Peer Model is "TS0601"
[313769][V][ZigbeeHandlers.cpp:263] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[313770][I][ZigbeeGateway.cpp:477] zbReadBasicCluster(): ZCL power source id is "3"
[313771][V][ZigbeeHandlers.cpp:263] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0xfffe), type(0x30), value(0)
[313772][I][ZigbeeGateway.cpp:481] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x30
[313769][D][ZigbeeGateway.cpp:530] bindDeviceCluster(): Requesting ZED (0x2bea), endpoint (0x1), cluster_id (0x0) to bind ZC
Przypominam się w temacie.
