Zgłaszane przez Was urządzenia często giną w treści postów i dyskusji stąd moja prośba by używać tego tematu tylko do zgłoszeń nowych urządzeń.
EDIT - aktualna baza tutaj:
https://github.com/lsroka76/Z2S_Library ... database.h
- Has thanked: 289 times
- Been thanked: 161 times
To bardzo prosze o dodanie bo nadal się nie parują:
https://pl.aliexpress.com/item/10050070 ... pt=glo2pol
https://pl.aliexpress.com/item/10050083 ... pt=glo2pol
11:45:00.827 -> [146631][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_1bwpjvlz"
11:45:00.827 -> [146554][I][Z2S_Device_Scanner.ino:88] loop(): manufacturer _TZ3000_1bwpjvlz
11:45:00.956 -> [146749][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
11:45:00.956 -> [146749][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xd24e) src endpoint(1) to dst endpoint(1) cluster(0x0)
11:45:00.956 -> [146750][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
11:45:00.956 -> [146751][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0203"
11:45:00.956 -> [146633][I][Z2S_Device_Scanner.ino:89] loop(): model TS0203
11:45:00.956 -> [146752][I][ZigbeeGateway.cpp:207] zbPrintDeviceDiscovery(): short_addr_req 53838
11:46:38.321 -> [244131][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_ja5osu5g"
11:46:38.321 -> [243696][I][Z2S_Device_Scanner.ino:88] loop(): manufacturer _TZ3000_ja5osu5g
11:46:38.833 -> [244634][I][ZigbeeHandlers.cpp:21] zb_action_handler(): Receive Zigbee action(0x1000) callback
11:46:38.833 -> [244634][V][ZigbeeHandlers.cpp:94] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x8bb6) src endpoint(1) to dst endpoint(1) cluster(0x0)
11:46:38.833 -> [244635][V][ZigbeeHandlers.cpp:103] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
11:46:38.833 -> [244635][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS004F"
11:46:38.833 -> [244132][I][Z2S_Device_Scanner.ino:89] loop(): model TS004F
11:46:38.833 -> [244638][I][ZigbeeGateway.cpp:207] zbPrintDeviceDiscovery(): short_addr_req 35766Czujnik otwarcia drzwi (okna) https://pl.aliexpress.com/item/1005006876002235.html :
eWeLink::SNZB-04
Szukasz nowego GG? Jest tutaj: https://forum.supla.org/viewtopic.php?t=18036Czujnik temperatury i wilgotności https://pl.aliexpress.com/item/1005006128683842.html :
_TZE200_a8sdabtg::TS0601
Szukasz nowego GG? Jest tutaj: https://forum.supla.org/viewtopic.php?t=18036Kolejny czujnik otwarcia drzwi. Wygląda identycznie, jak ten o którym wspominałem dwa posty wyżej.
_TZ3000_au1rjicn::TS0203
Yepestis
- Has thanked: 19 times
- Been thanked: 3 times
Czy mogę prosić o dodanie urządzenia z poniższego linku, jest to przycisk bezprzewodowy który posiada 3 akcje (1 kliknięcie, 2 kliknięcia, długie przytrzymanie przycisku).
https://pl.aliexpress.com/item/10050067 ... pt=glo2pol
Czy poniższe dane będą wystarczające do dodania?
[322162][I][ZigbeeCore.cpp:324] esp_zb_app_signal_handler(): New device commissi oned or rejoined (short: 0x8468)
[322163][V][ZigbeeCore.cpp:328] esp_zb_app_signal_handler(): Device capabilities : 0x80
[322280][D][ZigbeeGateway.cpp:152] find_Cb(): Sensor found: short address(0x8468 ), endpoint(1)
[322347][I][ZigbeeGateway.cpp:342] printJoinedDevices(): joined devices:
[322348][I][ZigbeeGateway.cpp:345] printJoinedDevices(): Device on endpoint 1, s hort address: 0x8468
[322397][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x 1000) callback
[322398][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribu te response: from address(0x8468) src endpoint(1) to dst endpoint(1) cluster(0x0 )
[322398][V][ZigbeeHandlers.cpp:105] zb_cmd_read_attr_resp_handler(): Read attrib ute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[322399][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ300 0_mrpevh8p"
[322400][I][Z2S_Gateway.ino:295] loop(): manufacturer _TZ3000_mrpevh8p
[322518][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x 1000) callback
[322519][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribu te response: from address(0x8468) src endpoint(1) to dst endpoint(1) cluster(0x0 )
[322519][V][ZigbeeHandlers.cpp:105] zb_cmd_read_attr_resp_handler(): Read attrib ute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[322520][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0041"
[322521][I][Z2S_Gateway.ino:297] loop(): model TS0041-
Yepestis
I jeszcze jedno urządzenie, kontraktron
https://pl.aliexpress.com/item/1005008300756525.html
Parowania, kilka razy otwarcie, na koniec 2 razy zerwanie styku kontrolnego (otwarcie obudowy)
[309222][V][ZigbeeCore.cpp:225] openNetwork(): Opening network for joining for 180 seconds
[309690][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): Network(0x2fc2) is open for 180 seconds
[367486][V][ZigbeeCore.cpp:371] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[367488][V][ZigbeeCore.cpp:371] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[368568][I][ZigbeeCore.cpp:324] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xaf86)
[368569][V][ZigbeeCore.cpp:328] esp_zb_app_signal_handler(): Device capabilities: 0x80
[369073][D][ZigbeeGateway.cpp:152] find_Cb(): Sensor found: short address(0xaf86), endpoint(1)
[369076][I][ZigbeeGateway.cpp:342] printJoinedDevices(): joined devices:
[369077][I][ZigbeeGateway.cpp:345] printJoinedDevices(): Device on endpoint 1, short address: 0xaf86
[369153][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1000) callback
[369154][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x0)
[369154][V][ZigbeeHandlers.cpp:105] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[369155][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_n2egfsli"
[369158][I][Z2S_Gateway.ino:295] loop(): manufacturer _TZ3000_n2egfsli
[369164][V][ZigbeeCore.cpp:371] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[369600][I][ZigbeeCore.cpp:355] esp_zb_app_signal_handler(): Network(0x2fc2) is open for 180 seconds
[369715][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1000) callback
[369715][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x0)
[369716][V][ZigbeeHandlers.cpp:105] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(7)
[369717][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "SNZB-04"
[369718][I][Z2S_Gateway.ino:297] loop(): model SNZB-04
[369719][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_akqdg6g7::TS0201, entry # 0
[369719][I][Z2S_Gateway.ino:380] loop(): LIST checking Xiaomi::LYWSD03MMC-z, entry # 1
[369720][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_rdhukkmi::TS0201, entry # 2
[369720][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_fllyghyj::TS0201, entry # 3
[369721][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_v1w2k9dd::TS0201, entry # 4
[369721][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZE204_upagmta9::TS0601, entry # 5
[369722][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_xr3htd96::TS0201, entry # 6
[369722][I][Z2S_Gateway.ino:380] loop(): LIST checking SONOFF::SNZB-02D, entry # 7
[369723][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_0hkmcrza::TS0203, entry # 8
[369724][I][Z2S_Gateway.ino:380] loop(): LIST checking TEST1::TS0202, entry # 9
[369724][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_mcxw5ehu::TS0202, entry # 10
[369725][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZE200_3towulqd::TS0601, entry # 11
[369725][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_26fmupbb::TS0203, entry # 12
[369726][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_rcuyhwe3::TS0203, entry # 13
[369726][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_2mbfxlzr::TS0203, entry # 14
[369727][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZE200_bh3n6gk8::TS0601, entry # 15
[369728][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_k4ej3ww2::TS0207, entry # 16
[369728][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3210_up3pngle::TS0205, entry # 17
[369729][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_85czd6fy::TS0207, entry # 18
[369729][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_upgcbody::TS0207, entry # 19
[369730][I][Z2S_Gateway.ino:380] loop(): LIST checking TEST1::TS0205, entry # 20
[369730][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3210_up3pngle::TS0205, entry # 21
[369731][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_lf56vpxj::TS0202, entry # 22
[369732][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_decxrtwa::TS0203, entry # 23
[369732][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_yxqnffam::TS0203, entry # 24
[369733][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_cehuw1lw::TS011F, entry # 25
[369733][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_5f43h46b::TS011F, entry # 26
[369734][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_w0qqde0g::TS011F, entry # 27
[369734][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_wkai4ga5::TS0044, entry # 28
[369735][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_yj6k7vfo::TS0041, entry # 29
[369736][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_4fjiwweb::TS004F, entry # 30
[369736][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_uri7ongn::TS004F, entry # 31
[369737][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_ixla93vd::TS004F, entry # 32
[369737][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_qja6nq5z::TS004F, entry # 33
[369738][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_abrsvsou::TS004F, entry # 34
[369738][I][Z2S_Gateway.ino:380] loop(): LIST checking IKEA of Sweden::Remote Control N2, entry # 35
[369739][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZ3000_gjrubzje::TS0001, entry # 36
[369740][I][Z2S_Gateway.ino:380] loop(): LIST checking SONOFF::ZBMINIL2, entry # 37
[369740][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZE200_cpmgn2cf::TS0601, entry # 38
[369741][I][Z2S_Gateway.ino:380] loop(): LIST checking _TZE200_0dvm9mva::TS0601, entry # 39
[369742][D][Z2S_Gateway.ino:382] loop(): Unknown model _TZ3000_n2egfsli::SNZB-04, no binding is possible
Channel(0) value changed to 212396.00
Send: [53 55 50 4C 41 17 17 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 00 00 00 00 60 ED 09 41 ]
Send: [53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 18 00 00 00 28 00 00 00 10 00 00 00 7E 01 00 00 00 00 00 00 92 DA 0A 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 14 00 00 00 32 00 00 00 10 00 00 00 2A 56 9A 67 00 00 00 00 1B FF 0A 00 00 00 00 00 53 55 50 4C 41 ]
[389092][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1031) callback
[389092][V][ZigbeeHandlers.cpp:175] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0xff), delay (0x0)
[389093][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0x3e8
[389094][I][Z2S_Devices_Table.cpp:344] Z2S_onIASzoneStatusChangeNotification(): No channel found for address p1E▒D8▒
[390007][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1031) callback
[390007][V][ZigbeeHandlers.cpp:175] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0xff), delay (0x0)
[390009][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0x3e8
[390009][I][Z2S_Devices_Table.cpp:344] Z2S_onIASzoneStatusChangeNotification(): No channel found for address p1E▒D8▒
[390160][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1031) callback
[390160][V][ZigbeeHandlers.cpp:175] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0xff), delay (0x0)
[390161][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0x3e8
[390162][I][Z2S_Devices_Table.cpp:344] Z2S_onIASzoneStatusChangeNotification(): No channel found for address p1E▒D8▒
[392311][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1031) callback
[392311][V][ZigbeeHandlers.cpp:175] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0xff), delay (0x0)
[392312][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0x3e8
[392313][I][Z2S_Devices_Table.cpp:344] Z2S_onIASzoneStatusChangeNotification(): No channel found for address p1E▒D8▒
[393424][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1031) callback
[393425][V][ZigbeeHandlers.cpp:175] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0xff), delay (0x0)
[393426][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0x3e8
[393427][I][Z2S_Devices_Table.cpp:344] Z2S_onIASzoneStatusChangeNotification(): No channel found for address p1E▒D8▒
[393524][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1031) callback
[393525][V][ZigbeeHandlers.cpp:175] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0xff), delay (0x0)
[393526][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0x3e8
[393526][I][Z2S_Devices_Table.cpp:344] Z2S_onIASzoneStatusChangeNotification(): No channel found for address p1E▒D8▒
[393789][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1031) callback
[393789][V][ZigbeeHandlers.cpp:175] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0xff), delay (0x0)
[393790][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0x3e8
[393791][I][Z2S_Devices_Table.cpp:344] Z2S_onIASzoneStatusChangeNotification(): No channel found for address p1E▒D8▒
[396567][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1031) callback
[396567][V][ZigbeeHandlers.cpp:175] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0xff), delay (0x0)
[396568][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0x3e8
[396569][I][Z2S_Devices_Table.cpp:344] Z2S_onIASzoneStatusChangeNotification(): No channel found for address p1E▒D8▒
[397650][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1031) callback
[397651][V][ZigbeeHandlers.cpp:175] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0xff), delay (0x0)
[397652][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0x3e8
[397652][I][Z2S_Devices_Table.cpp:344] Z2S_onIASzoneStatusChangeNotification(): No channel found for address p1E▒D8▒
[398047][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1031) callback
[398047][V][ZigbeeHandlers.cpp:175] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0xff), delay (0x0)
[398049][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0x3e8
[398049][I][Z2S_Devices_Table.cpp:344] Z2S_onIASzoneStatusChangeNotification(): No channel found for address p1E▒D8▒
[400017][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1031) callback
[400017][V][ZigbeeHandlers.cpp:175] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0xff), delay (0x0)
[400019][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0x3e8
[400019][I][Z2S_Devices_Table.cpp:344] Z2S_onIASzoneStatusChangeNotification(): No channel found for address p1E▒D8▒
[400024][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x2000) callback
[400025][V][ZigbeeHandlers.cpp:74] zb_attribute_reporting_handler(): Received report from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x1)
[400026][I][ZigbeeGateway.cpp:415] zbAttributeRead(): zbAttributeRead power config battery percentage remaining 200
[400026][I][Z2S_Devices_Table.cpp:325] Z2S_onBatteryPercentageReceive(): onBatteryPercentageReceive 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1
[400027][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0xffffffff
[400028][I][Z2S_Devices_Table.cpp:329] Z2S_onBatteryPercentageReceive(): No channel found for address p1E▒D8▒
[400029][I][ZigbeeGateway.cpp:429] zbAttributeRead(): zbAttributeRead from (0x3170), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[400049][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1031) callback
[400049][V][ZigbeeHandlers.cpp:175] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0xff), delay (0x0)
[400051][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0x3e8
[400051][I][Z2S_Devices_Table.cpp:344] Z2S_onIASzoneStatusChangeNotification(): No channel found for address p1E▒D8▒
[400136][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x2000) callback
[400136][V][ZigbeeHandlers.cpp:74] zb_attribute_reporting_handler(): Received report from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x1)
[400137][I][ZigbeeGateway.cpp:418] zbAttributeRead(): zbAttributeRead power config cluster (0x1), attribute id (0x20), attribute data type (0x20)
[400138][I][ZigbeeGateway.cpp:429] zbAttributeRead(): zbAttributeRead from (0x3170), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[400253][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x2000) callback
[400254][V][ZigbeeHandlers.cpp:74] zb_attribute_reporting_handler(): Received report from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500)
[400255][I][ZigbeeGateway.cpp:428] zbAttributeRead(): zbAttributeRead IAS zone cluster (0x500), attribute id (0xf001), attribute data type (0x20)
[400366][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x2000) callback
[400366][V][ZigbeeHandlers.cpp:74] zb_attribute_reporting_handler(): Received report from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500)
[400367][I][ZigbeeGateway.cpp:428] zbAttributeRead(): zbAttributeRead IAS zone cluster (0x500), attribute id (0x13), attribute data type (0x20)
Send: [53 55 50 4C 41 17 19 00 00 00 28 00 00 00 10 00 00 00 97 01 00 00 00 00 00 00 66 2C 0B 00 00 00 00 00 ]
[407803][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1031) callback
[407803][V][ZigbeeHandlers.cpp:175] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0xff), delay (0x0)
[407804][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0x3e8
[407805][I][Z2S_Devices_Table.cpp:344] Z2S_onIASzoneStatusChangeNotification(): No channel found for address p1E▒D8▒
Recv: [53 55 50 4C 41 17 15 00 00 00 32 00 00 00 10 00 00 00 43 56 9A 67 00 00 00 00 08 D6 0A 00 00 00 00 00 53 55 50 4C 41 ]
[411809][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1031) callback
[411810][V][ZigbeeHandlers.cpp:175] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x0), extended status (0x0), zone id (0xff), delay (0x0)
[411811][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0x3e8
[411811][I][Z2S_Devices_Table.cpp:344] Z2S_onIASzoneStatusChangeNotification(): No channel found for address p1E▒D8▒
[413640][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x1031) callback
[413641][V][ZigbeeHandlers.cpp:175] zb_cmd_ias_zone_status_change_handler(): IAS Zone Status Notification: from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500), zone status (0x1), extended status (0x0), zone id (0xff), delay (0x0)
[413642][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0x3e8
[413642][I][Z2S_Devices_Table.cpp:344] Z2S_onIASzoneStatusChangeNotification(): No channel found for address p1E▒D8▒
[418257][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x2000) callback
[418257][V][ZigbeeHandlers.cpp:74] zb_attribute_reporting_handler(): Received report from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x1)
[418258][I][ZigbeeGateway.cpp:415] zbAttributeRead(): zbAttributeRead power config battery percentage remaining 200
[418259][I][Z2S_Devices_Table.cpp:325] Z2S_onBatteryPercentageReceive(): onBatteryPercentageReceive 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1
[418259][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0xffffffff
[418260][I][Z2S_Devices_Table.cpp:329] Z2S_onBatteryPercentageReceive(): No channel found for address p1E▒D8▒
[418260][I][ZigbeeGateway.cpp:429] zbAttributeRead(): zbAttributeRead from (0x3170), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[418322][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x2000) callback
[418322][V][ZigbeeHandlers.cpp:74] zb_attribute_reporting_handler(): Received report from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x1)
[418323][I][ZigbeeGateway.cpp:418] zbAttributeRead(): zbAttributeRead power config cluster (0x1), attribute id (0x20), attribute data type (0x20)
[418323][I][ZigbeeGateway.cpp:429] zbAttributeRead(): zbAttributeRead from (0x3170), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[418455][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x2000) callback
[418456][V][ZigbeeHandlers.cpp:74] zb_attribute_reporting_handler(): Received report from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500)
[418456][I][ZigbeeGateway.cpp:428] zbAttributeRead(): zbAttributeRead IAS zone cluster (0x500), attribute id (0xf001), attribute data type (0x20)
[418619][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x2000) callback
[418619][V][ZigbeeHandlers.cpp:74] zb_attribute_reporting_handler(): Received report from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500)
[418620][I][ZigbeeGateway.cpp:428] zbAttributeRead(): zbAttributeRead IAS zone cluster (0x500), attribute id (0x13), attribute data type (0x20)
[419345][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x2000) callback
[419346][V][ZigbeeHandlers.cpp:74] zb_attribute_reporting_handler(): Received report from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x1)
[419347][I][ZigbeeGateway.cpp:415] zbAttributeRead(): zbAttributeRead power config battery percentage remaining 200
[419347][I][Z2S_Devices_Table.cpp:325] Z2S_onBatteryPercentageReceive(): onBatteryPercentageReceive 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1
[419348][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0xffffffff
[419348][I][Z2S_Devices_Table.cpp:329] Z2S_onBatteryPercentageReceive(): No channel found for address p1E▒D8▒
[419349][I][ZigbeeGateway.cpp:429] zbAttributeRead(): zbAttributeRead from (0x3170), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[421250][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x2000) callback
[421250][V][ZigbeeHandlers.cpp:74] zb_attribute_reporting_handler(): Received report from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x1)
[421251][I][ZigbeeGateway.cpp:415] zbAttributeRead(): zbAttributeRead power config battery percentage remaining 200
[421251][I][Z2S_Devices_Table.cpp:325] Z2S_onBatteryPercentageReceive(): onBatteryPercentageReceive 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1
[421252][I][Z2S_Devices_Table.cpp:42] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0x44:0xa4:0x45:0x31:0x70, endpoint 0x1, channel type 0xffffffff
[421253][I][Z2S_Devices_Table.cpp:329] Z2S_onBatteryPercentageReceive(): No channel found for address p1E▒D8▒
[421254][I][ZigbeeGateway.cpp:429] zbAttributeRead(): zbAttributeRead from (0x3170), endpoint (1), cluster (0x1), attribute id (0x21), attribute data type (0x20)
[421376][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x2000) callback
[421377][V][ZigbeeHandlers.cpp:74] zb_attribute_reporting_handler(): Received report from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x1)
[421377][I][ZigbeeGateway.cpp:418] zbAttributeRead(): zbAttributeRead power config cluster (0x1), attribute id (0x20), attribute data type (0x20)
[421378][I][ZigbeeGateway.cpp:429] zbAttributeRead(): zbAttributeRead from (0x3170), endpoint (1), cluster (0x1), attribute id (0x20), attribute data type (0x20)
[421433][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x2000) callback
[421434][V][ZigbeeHandlers.cpp:74] zb_attribute_reporting_handler(): Received report from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500)
[421435][I][ZigbeeGateway.cpp:428] zbAttributeRead(): zbAttributeRead IAS zone cluster (0x500), attribute id (0xf001), attribute data type (0x20)
[421587][I][ZigbeeHandlers.cpp:22] zb_action_handler(): Receive Zigbee action(0x2000) callback
[421587][V][ZigbeeHandlers.cpp:74] zb_attribute_reporting_handler(): Received report from address(0xaf86) src endpoint(1) to dst endpoint(1) cluster(0x500)
[421588][I][ZigbeeGateway.cpp:428] zbAttributeRead(): zbAttributeRead IAS zone cluster (0x500), attribute id (0x13), attribute data type (0x20)
SOYER
- Been thanked: 2 times
Może dobrze byłoby wrzucić do pierwszego postu listę już działających urządzeń i na bieżąco ją aktualizować w momencie opanowania kolejnego.
https://kryry01.aqi.eco/pl
https://github.com/Soyer79
Te u mnie dodałem i działają :
czujnik ruchu
czujnik otwarcia okna
czujnik wody
.manufacturer_name = "eWeLink", .model_name = "SNZB-03"Code: Select all
.manufacturer_name = "eWeLink", .model_name = "DS01"Code: Select all
.manufacturer_name = "_TZ3000_prits6g4", .model_name = "TS0001"
