Czy komuś z kolegów udało się sparować Czujnik ruchu: XIAOMI MI RTCGQ01LM z bramką Z2S? Mnie już troszkę zaczyna trafiać. Czy ktoś może mnie naprowadzić, czy jest to w ogóle możliwe? W logach wykrywa lumi.sensor_motion, ale urzadzenie nie dodaje sie do bramki. Co robię źle?
[124437][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[124438][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0x176e) src endpoint(1) to dst endpoint(1) cluster(0x0)
[124439][ZigbeeGateway.cpp:695] zbReadBasicCluster(): Peer Model is "lumi.sensor_motion"
[124442][D][ZigbeeCore.cpp:494] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[124442][D][ZigbeeCore.cpp:495] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 110, cluster_id: 0x0000, asdu_length: 7
APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0x176e
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 204, rx_time: 0
[124444][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x0, command id: 10
[124445][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[124445][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[124446][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
[124446][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 13 size: 4
[124447][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x01
[124447][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[124447][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[124448][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x0A
[124448][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x176e, 0x176e, 0x0, 0x0
[124449][I][z2s_devices_table.cpp:3933] Z2S_onCustomCmdReceive(): 00:15:8D:00:03:58:E6:9E, endpoint 0x1, cluster 0x0, cmd id 0xa
[124449][I][z2s_devices_table.cpp:161] Z2S_findChannelNumberSlot(): 00:15:8D:00:03:58:E6:9E, endpoint 0x1, channel type 0xffffffff
[124450][E][z2s_devices_table.cpp:58] no_channel_found_error_func(): No channel found for address 00:15:8D:00:03:58:E6:9E
[124450][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
[124451][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x2000) callback
[124451][V][ZigbeeHandlers.cpp:234] zb_attribute_reporting_handler(): Received report from address(0x176e) src endpoint(1) to dst endpoint(1) cluster(0x0)
[124452][I][ZigbeeGateway.cpp:721] zbReadBasicCluster(): ZCL application version id is "10"
[124453][D][ZigbeeCore.cpp:494] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[124453][D][ZigbeeCore.cpp:495] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
APSDE INDICATION - src_addr_mode: 0, cluster_id: 0x0000, asdu_length: 29
[124455][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0x0, command id: 10
[124455][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[124456][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 1
[124456][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x1234
[124457][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 14 size: 24
[124457][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x02
[124458][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xFF
[124458][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x4C
[124458][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x06
[124459][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[124459][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x10
[124459][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x01
[124460][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x21
[124460][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xDB
[124460][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x0B
[124461][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x21
[124461][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xA8
[124461][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x01
[124462][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x24
[124462][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[124463][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
[124464][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x21
[124464][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0xE8
[124464][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x04
[124465][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x20
[124465][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x50
[124465][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x176e, 0x176e, 0x0, 0x0
[124466][I][z2s_devices_table.cpp:3933] Z2S_onCustomCmdReceive(): 00:15:8D:00:03:58:E6:9E, endpoint 0x1, cluster 0x0, cmd id 0xa
[124466][I][z2s_devices_table.cpp:161] Z2S_findChannelNumberSlot(): 00:15:8D:00:03:58:E6:9E, endpoint 0x1, channel type 0xffffffff
[124467][E][z2s_devices_table.cpp:58] no_channel_found_error_func(): No channel found for address 00:15:8D:00:03:58:E6:9E
[124467][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not
