Yepestis
Has thanked: 19 times
Been thanked: 3 times
vajera wrote: Fri Mar 07, 2025 7:33 pm
Yepestis wrote: Fri Mar 07, 2025 12:15 pm Proszę o dodanie obsługi czujnika gleby (pomiar wilgotności i temperatury)
https://www.zigbee2mqtt.io/devices/TS06 ... s0601-soil
https://a.aliexpress.com/_ExZ9xe8
Peer Manufacturer is "_TZE284_myd45weu"
Peer Model is "TS0601"
============ After Setup End =============
[ 10505][V][ZigbeeCore.cpp:254] openNetwork(): Opening network for joining for 180 seconds
[ 10972][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0x937a) is open for 180 seconds
[ 27099][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 27101][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 27632][I][ZigbeeCore.cpp:354] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x8aa7)
[ 27633][V][ZigbeeCore.cpp:358] esp_zb_app_signal_handler(): Device capabilities: 0x80
[ 27633][D][ZigbeeGateway.cpp:471] zbDeviceAnnce(): zbDeviceAnnce short address (0x8aa7), ieee_addr (0xa4):(0xc1):(0x38):(0xee):(0xeb):(0xb4):(0xfd):(0x1)
[ 27634][D][ZigbeeGateway.cpp:474] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x8aa7), ieee_addr (0xa4):(0xc1):(0x38):(0xee):(0xeb):(0xb4):(0xfd):(0x1)
[ 27635][I][ZigbeeGateway.cpp:498] zbDeviceAnnce(): Tuya magic last hope
[ 27850][I][ZigbeeGateway.cpp:541] printJoinedDevices(): joined devices:
[ 27850][I][ZigbeeGateway.cpp:544] printJoinedDevices(): Device on endpoint 1, short address: 0x8aa7
[ 27946][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x0, command id: 11
[ 27946][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 27947][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 27947][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[ 27948][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 15 size: 2
[ 27948][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xA8
[ 27948][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x82
[ 27949][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x8aa7, 0x8aa7, 0x0, 0x0
[ 27949][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 27967][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 27967][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x8aa7), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x0
[ 27968][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 27969][I][ZigbeeGateway.cpp:1298] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x1[0x0]
[ 28251][I][ZigbeeGateway.cpp:309] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 28282][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 28283][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x8aa7) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 28283][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[ 28284][I][ZigbeeGateway.cpp:342] zbReadBasicCluster(): Peer Manufacturer is "_TZE284_myd45weu"
[ 28751][I][ZigbeeGateway.cpp:315] zbQueryDeviceBasicCluster(): basic tsn 0x2
[ 28751][I][ZigbeeGateway.cpp:309] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[ 28849][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 28849][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x8aa7) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 28850][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[ 28851][I][ZigbeeGateway.cpp:349] zbReadBasicCluster(): Peer Model is "TS0601"
[ 29070][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 29129][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0x937a) is open for 180 seconds
[ 29252][I][ZigbeeGateway.cpp:315] zbQueryDeviceBasicCluster(): basic tsn 0x3
[ 29252][I][ZigbeeGateway.cpp:993] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[ 29492][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
[ 29493][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x8aa7) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 29493][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(0), cluster(0x0), attribute(0xffff)
[ 29753][I][ZigbeeGateway.cpp:271] zbPrintDeviceDiscovery(): short_addr_req 35495
[ 29806][I][ZigbeeGateway.cpp:205] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 35495, endpoints count 1
[ 29806][I][ZigbeeGateway.cpp:208] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[ 29927][I][ZigbeeGateway.cpp:224] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 35495, endpoint # 1
[ 29928][I][ZigbeeGateway.cpp:225] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 5, out clusters # 2
[ 29928][I][ZigbeeGateway.cpp:229] Z2S_simple_desc_req_cb(): In cluster # 1, id 4
[ 29929][I][ZigbeeGateway.cpp:229] Z2S_simple_desc_req_cb(): In cluster # 2, id 5
[ 29929][I][ZigbeeGateway.cpp:229] Z2S_simple_desc_req_cb(): In cluster # 3, id 61184
[ 29929][I][ZigbeeGateway.cpp:229] Z2S_simple_desc_req_cb(): In cluster # 4, id 0
[ 29930][I][ZigbeeGateway.cpp:229] Z2S_simple_desc_req_cb(): In cluster # 5, id 60672
[ 29930][I][ZigbeeGateway.cpp:244] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
[ 29931][I][ZigbeeGateway.cpp:244] Z2S_simple_desc_req_cb(): Out cluster # 2, id 10
[ 30053][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 30053][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x8aa7), src_endpoint(1) to dst_endpoint(1), cluster(0x4) for command (0xc) with status 0x84
[ 30054][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 30054][I][ZigbeeGateway.cpp:1298] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x5[0x0]
[ 30068][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 30069][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x8aa7), src_endpoint(1) to dst_endpoint(1), cluster(0x5) for command (0xc) with status 0x84
[ 30069][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 30070][I][ZigbeeGateway.cpp:1298] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x6[0x0]
[ 30083][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 30084][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x8aa7), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0xc) with status 0x84
[ 30085][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 30085][I][ZigbeeGateway.cpp:1298] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x7[0x0]
[ 30099][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 30099][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x8aa7), src_endpoint(1) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[ 30100][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 30101][I][ZigbeeGateway.cpp:1298] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x8[0x0]
[ 30114][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 30115][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x8aa7), src_endpoint(1) to dst_endpoint(1), cluster(0xed00) for command (0xc) with status 0x84
[ 30116][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 30116][I][ZigbeeGateway.cpp:1298] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x9[0x0]
[ 30130][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
[ 30130][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 30131][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 30131][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[ 30132][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 6 size: 2
[ 30132][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x0C
[ 30132][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x84
[ 30133][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x8aa7, 0x8aa7, 0x0, 0x0
[ 30133][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 30137][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 30137][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x8aa7), src_endpoint(1) to dst_endpoint(1), cluster(0xa) for command (0xc) with status 0x84
[ 30138][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 30139][I][ZigbeeGateway.cpp:1298] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0xb[0x0]
[ 34169][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 34170][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x8aa7) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 34170][I][ZigbeeGateway.cpp:678] zbAttributeReporting(): zbAttributeReporting from (0xfd01), endpoint (1), cluster (0x0), attribute id (0xffcf), attribute data type (0x21)
[ 34290][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[ 34290][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 17 from address 0x8aa7
[ 34291][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 3
[ 34291][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[ 34292][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xff
[ 34292][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x51
[ 34413][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 34414][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x8aa7) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 34414][I][ZigbeeGateway.cpp:678] zbAttributeReporting(): zbAttributeReporting from (0xfd01), endpoint (1), cluster (0x0), attribute id (0x1), attribute data type (0x20)
[ 34415][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 34415][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x8aa7) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 34416][I][ZigbeeGateway.cpp:678] zbAttributeReporting(): zbAttributeReporting from (0xfd01), endpoint (1), cluster (0x0), attribute id (0xffe2), attribute data type (0x20)
[ 34417][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 34417][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x8aa7) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 34418][I][ZigbeeGateway.cpp:678] zbAttributeReporting(): zbAttributeReporting from (0xfd01), endpoint (1), cluster (0x0), attribute id (0xffe4), attribute data type (0x20)
[ 34536][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[ 34536][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x8aa7
[ 34537][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[ 34537][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[ 34538][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xf5
[ 34538][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x5
[ 34539][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[ 34539][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[ 34540][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[ 34540][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[ 34540][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[ 34541][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[ 34541][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x17
[ 34659][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[ 34659][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x8aa7
[ 34660][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[ 34660][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[ 34661][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xf6
[ 34661][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x3
[ 34662][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[ 34662][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[ 34663][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[ 34663][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[ 34663][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[ 34664][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[ 34664][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x0
[ 34783][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[ 34783][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x8aa7
[ 34784][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[ 34784][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[ 34785][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xf7
[ 34785][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0xf
[ 34785][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[ 34786][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[ 34786][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[ 34787][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[ 34787][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[ 34788][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[ 34788][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x64
[ 34906][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[ 34907][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x8aa7
[ 34907][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[ 34907][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[ 34908][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xf8
[ 34908][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0xe
[ 34909][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[ 34909][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[ 34910][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[ 34910][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x2
[ 35029][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 35030][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x8aa7) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 35031][I][ZigbeeGateway.cpp:678] zbAttributeReporting(): zbAttributeReporting from (0xfd01), endpoint (1), cluster (0x0), attribute id (0xffdf), attribute data type (0x42)
[ 35689][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[ 35689][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 35690][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[ 35690][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[ 35691][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 12 size: 2
[ 35691][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x07
[ 35691][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[ 35692][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x8aa7, 0x8aa7, 0x0, 0x0
[ 35692][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 36004][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[ 36005][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x8aa7
[ 36005][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[ 36006][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[ 36006][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xf9
[ 36006][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x5
[ 36007][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[ 36007][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[ 36008][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[ 36008][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[ 36009][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[ 36009][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[ 36009][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x17
[ 36128][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[ 36129][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x8aa7
[ 36129][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[ 36130][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[ 36130][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xfa
[ 36130][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x3
[ 36131][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[ 36131][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[ 36132][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[ 36132][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[ 36132][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[ 36133][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[ 36133][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x0
[ 36252][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[ 36253][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x8aa7
[ 36253][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[ 36254][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[ 36254][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xfb
[ 36254][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0xf
[ 36255][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[ 36255][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[ 36256][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[ 36256][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[ 36257][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[ 36257][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[ 36257][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x64
[ 36375][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[ 36376][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x8aa7
[ 36376][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[ 36377][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[ 36377][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xfc
[ 36377][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0xe
[ 36378][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[ 36378][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[ 36379][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[ 36379][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x2
+BWNU
Dziękuję, sparował się i działa. Tylko jeden problem, w pomiarze temperatury przecinek jest przesunięty.
Czujnik mam w mieszkaniu i powinno być 22 stopnie a wyświetla 2,2.
Has thanked: 289 times
Yepestis wrote: Fri Mar 07, 2025 8:34 pm
+BWNU
To sprawdź wersję 0.5.9 - jak juz się skompiluje.
Yepestis
vajera wrote: Fri Mar 07, 2025 9:50 pm
+BWNU
Niestety dalej to samo, temperatura zanizona 10 krotnie.
Sprawdziłem też z bramką Tuya czy dobrze pokazuje ten czujnik i tam jest ok czy 10 razy wyższa temperatura.
PS W webinterface wyświetla mi wersję 0.5.8. A Github twierdzi że nie ma różnić miedzy 0.5.8 a 0.5.9.
https://github.com/lsroka76/Z2S_Library ... 8...v0.5.9
Yepestis wrote: Sat Mar 08, 2025 6:20 am Niestety dalej to samo, temperatura zanizona 10 krotnie.
Wygląda to następująco:
  • dodalem ten nowy model do bazy przypisując mu ten sam DEVICE_DESC_ID co poprzedniemu czujnikowi gleby - zadziałało, ale pojawił się problem zbyt niskiej temperatury,
  • nie mogłem po prostu usunąć linijki kodu z "temperature/10" bo wtedy tamten czujnik pokazywałby temperaturę 10x wyższą,
  • stworzyłem nowe DESC_ID dla tego czujnika i zmodyfikowałem kod żeby odpowiednio zmieniał wartość wysyłanej do Supla temperatury,
  • ALE - Twój czujnik jest już zapisany w tablicy ze starym model_id, więc nic się nie zmienia,
  • w związku z powyższym masz do wyboru:
    • wgrać bramkę od zera 😞 albo
    • spróbować usunąć urządzenie z tablicy Supla - przez WebInterface, zrestartować bramkę i wykonać tę procedurę re-pairingu urządzenia.
Yepestis
vajera wrote: Sat Mar 08, 2025 6:58 am
Usunąłem ale później nie udało mi się na nowo sparować, podjąłem próbę na drugiej bramce z wgranym firmware na czysto i tu też nie chce się sparować, na priv wysłałem pełny LOG.
Yepestis wrote: Sat Mar 08, 2025 8:21 am
Zapomniałem o jednym wpisie - tak to jest, jak się edytuje kod na komórce 😉 Zaraz będzie nowy release.
Yepestis
vajera wrote: Sat Mar 08, 2025 8:45 am
Potwierdzam że teraz się dodał bez problemu i temperaturę wskazuje właściwą.
Jesteś jak zwykle niezawodny ale już nie będę męczyć z czujnikami do kwiatków :lol:
Yepestis wrote: Sat Mar 08, 2025 8:54 am Potwierdzam że teraz się dodał bez problemu i temperaturę wskazuje właściwą.
Nie męczysz - właśnie wróciło do mnie wspomnienie jak w podstawówce narodziła się moja pasja do elektroniki - zaczęło się właśnie od pomysłu jakby tu monitorować wilgotność w doniczce :D
Jeszcze w temacie tego czujnika - to oznacza, że jego dokładność pomiaru temperatury wynosi ±1°C.
Yepestis
vajera wrote: Sat Mar 08, 2025 9:01 am
Wygląda na to że dokładność ±1°C w tym przypadku oznacze też jego rozdzielczość. Przełączyłem na bramkę Tuya i też pokazuje tylko pełne jedności bez wartości po przecinku.
Ale zastanawia mnie coś innego, pomimo przełączenia na bramkę Tuya, w aplikacji Supla cały czas kanał jest online pomimo tego że minęła już ponad godzina od przełączenia.
lukasz06
Has thanked: 45 times
Been thanked: 21 times
Mam coś podobnego z czujnikiem temp.
Jak go przyniosę w inne miejsce i straci zasięg, to i tak pokazuje że jest online i ostatnią zapamiętaną wartość
