Has thanked: 289 times
Tutaj proszę o zgłoszenia czujników temperatury, wilgotności, ciśnienia (ma ktoś?), oświetlenia oraz czujników IAS (otwarcia i inne 0/1).
Najlepiej w formacie PRODUCENT::MODEL - bez logów, ewentualnie z linkiem do strony.
zokopian
Witam.
Proszę o dodanie czujnika temperatury i wilgotności ZTH-05
https://www.zigbee2mqtt.io/devices/ZTH05.html
W chwili obecnej czujnik paruje się z bramką, pojawia się w supli jednak brak wskazań.
Logi z parowania czujnika
Software Info:
  Compile Date/Time : Jan 21 2025 20:23:01
  Compile Host OS   : windows
  ESP-IDF Version   : v5.3.2-282-gcfea4f7c98-dirty
  Arduino Version   : 3.1.1
Board Info:
  Arduino Board     : ESP32C6_DEV
  Arduino Variant   : esp32c6
  Arduino FQBN      : esp32:esp32:esp32c6:UploadSpeed=921600,CDCOnBoot=cdc,CPUFreq=160,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=custom,DebugLevel=verbose,EraseFlash=all,JTAGAdapter=default,ZigbeeMode=zczr
============ Before Setup End ============
[   303][V][esp32-hal-periman.c:235] perimanSetBusDeinit(): Deinit function for type GPIO (1) successfully set to 0x4200f23c
[   303][V][esp32-hal-periman.c:160] perimanSetPinBus(): Pin 9 successfully set to type GPIO (1) with bus 0xa
[   304][D][ZigbeeCore.cpp:85] addEndpoint(): Endpoint: 1, Device ID: 0x0050
[   304][D][ZigbeeCore.cpp:138] zigbeeInit(): Initialize Zigbee stack
[   389][D][ZigbeeCore.cpp:145] zigbeeInit(): Register all Zigbee EPs in list
[   393][I][ZigbeeCore.cpp:153] zigbeeInit(): List of registered Zigbee EPs:
[   393][I][ZigbeeCore.cpp:155] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
[   398][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
[   399][I][ZigbeeCore.cpp:246] esp_zb_app_signal_handler(): Zigbee stack initialized
[   404][I][ZigbeeCore.cpp:358] esp_zb_app_signal_handler(): Network(0xc955) closed, devices joining not allowed.
[   406][I][ZigbeeCore.cpp:252] esp_zb_app_signal_handler(): Device started up in non factory-reset mode
[   406][I][ZigbeeCore.cpp:265] esp_zb_app_signal_handler(): Device rebooted
[   407][I][ZigbeeCore.cpp:269] esp_zb_app_signal_handler(): Opening network for joining for 180 seconds
[   407][D][ZigbeeCore.cpp:500] searchBindings(): Requesting binding table for address 0x0000
[   409][D][ZigbeeCore.cpp:439] bindingTableCb(): Binding table callback for address 0x0000 with status 0
[   409][D][ZigbeeCore.cpp:442] bindingTableCb(): Binding table info: total 0, index 0, count 0
[   410][D][ZigbeeCore.cpp:445] bindingTableCb(): No binding table entries found
=========== After Setup Start ============
INTERNAL Memory Info:
  Total Size        :   394876 B ( 385.6 KB)
  Free Bytes        :   324108 B ( 316.5 KB)
  Allocated Bytes   :    60712 B (  59.3 KB)
  Minimum Free Bytes:   320960 B ( 313.4 KB)
  Largest Free Block:   294900 B ( 288.0 KB)
GPIO Info:
  GPIO : BUS_TYPE[bus/unit][chan]
     9 : GPIO
    12 : USB_DM
    13 : USB_DP
    16 : UART_TX[0]
    17 : UART_RX[0]
============ After Setup End =============
[   875][I][ZigbeeCore.cpp:356] esp_zb_app_signal_handler(): Network(0xc955) is open for 180 seconds
[ 19451][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[ 19453][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[ 19982][I][ZigbeeCore.cpp:325] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xfa56)
[ 19983][V][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Device capabilities: 0x80
[ 19983][D][ZigbeeGateway.cpp:449] zbDeviceAnnce(): zbDeviceAnnce short address (0xfa56), ieee_addr (0xa4):(0xc1):(0x38):(0xdd):(0x34):(0x6f):(0x29):(0xcc)
[ 19984][D][ZigbeeGateway.cpp:452] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0xfa56), ieee_addr (0xa4):(0xc1):(0x38):(0xdd):(0x34):(0x6f):(0x29):(0xcc)
[ 19987][I][ZigbeeGateway.cpp:484] printJoinedDevices(): joined devices:
[ 19987][I][ZigbeeGateway.cpp:487] printJoinedDevices(): Device on endpoint 1, short address: 0xfa56
[ 20091][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 20091][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xfa56), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0x0
[ 20092][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 20188][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[ 20306][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 20306][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa56) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 20307][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[ 20308][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "3"
[ 20688][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x1
[ 20688][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 20870][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 20870][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa56) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 20871][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[ 20872][I][ZigbeeGateway.cpp:326] zbReadBasicCluster(): Peer Manufacturer is "_TZE204_upagmta9"
[ 21189][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x2
[ 21189][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[ 21317][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 21317][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa56) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 21318][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[ 21318][I][ZigbeeGateway.cpp:339] zbReadBasicCluster(): ZCL version id is "3"
[ 21442][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 21477][I][ZigbeeCore.cpp:356] esp_zb_app_signal_handler(): Network(0xc955) is open for 180 seconds
[ 21690][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x3
[ 21690][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x1
[ 21849][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 21849][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa56) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 21850][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(73)
[ 21851][I][ZigbeeGateway.cpp:345] zbReadBasicCluster(): ZCL application version id is "73"
[ 22191][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x4
[ 22191][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[ 22416][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 22417][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa56) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 22417][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[ 22418][I][ZigbeeGateway.cpp:333] zbReadBasicCluster(): Peer Manufacturer is "TS0601"
[ 22692][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x5
[ 22692][I][ZigbeeGateway.cpp:294] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x7
[ 22729][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 22730][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa56) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 22730][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[ 22731][I][ZigbeeGateway.cpp:351] zbReadBasicCluster(): ZCL power source id is "3"
[ 23194][I][ZigbeeGateway.cpp:300] zbQueryDeviceBasicCluster(): basic tsn 0x6
[ 23194][I][ZigbeeGateway.cpp:311] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0xfffe
[ 23293][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 23293][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xfa56) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 23294][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0xfffe), type(0x30), value(0)
[ 23295][I][ZigbeeGateway.cpp:355] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x30
[ 23695][I][ZigbeeGateway.cpp:852] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[ 23861][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
[ 23861][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0xfa56) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 23862][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(0), cluster(0x0), attribute(0xffff)
[ 24195][I][ZigbeeGateway.cpp:263] zbPrintDeviceDiscovery(): short_addr_req 64086
[ 24424][I][ZigbeeGateway.cpp:197] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 64086, endpoints count 1
[ 24425][I][ZigbeeGateway.cpp:200] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[ 24546][I][ZigbeeGateway.cpp:216] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 64086, endpoint # 1
[ 24547][I][ZigbeeGateway.cpp:217] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 4, out clusters # 2
[ 24547][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 1, id 4
[ 24548][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 2, id 5
[ 24548][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 3, id 61184
[ 24549][I][ZigbeeGateway.cpp:221] Z2S_simple_desc_req_cb(): In cluster # 4, id 0
[ 24549][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
[ 24550][I][ZigbeeGateway.cpp:236] Z2S_simple_desc_req_cb(): Out cluster # 2, id 10
[ 24671][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 24672][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xfa56), src_endpoint(1) to dst_endpoint(1), cluster(0x4) for command (0xc) with status 0x84
[ 24673][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 24686][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 24687][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xfa56), src_endpoint(1) to dst_endpoint(1), cluster(0x5) for command (0xc) with status 0x84
[ 24688][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 24702][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 24702][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xfa56), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0xc) with status 0x84
[ 24703][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 24718][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 24718][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xfa56), src_endpoint(1) to dst_endpoint(1), cluster(0x0) for command (0xc) with status 0x84
[ 24719][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 24733][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x19, command id: 11
[ 24733][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 24734][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[ 24734][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[ 24735][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 27 size: 2
[ 24735][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x0C
[ 24736][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x84
[ 24736][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xfa56, 0xfa56, 0x0, 0x0
[ 24736][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 24740][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 24740][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0xfa56), src_endpoint(1) to dst_endpoint(1), cluster(0xa) for command (0xc) with status 0x84
[ 24741][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 26606][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[ 26607][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 17 from address 0xfa56
[ 26607][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 3
[ 26608][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[ 26608][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x6
[ 26609][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x40
[ 26730][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 26730][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0xfa56) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 26731][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x29cc), endpoint (1), cluster (0x0), attribute id (0x1), attribute data type (0x20)
[ 26732][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 26732][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0xfa56) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 26733][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x29cc), endpoint (1), cluster (0x0), attribute id (0xffe2), attribute data type (0x20)
[ 26733][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 26734][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0xfa56) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 26735][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x29cc), endpoint (1), cluster (0x0), attribute id (0xffe4), attribute data type (0x20)
[ 28242][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[ 28242][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[ 28242][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[ 28243][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[ 28243][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 8 size: 2
[ 28244][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x07
[ 28244][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[ 28244][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xfa56, 0xfa56, 0x0, 0x0
[ 28245][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[ 89258][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 89258][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0xfa56) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 89259][I][ZigbeeGateway.cpp:590] zbAttributeReporting(): zbAttributeReporting from (0x29cc), endpoint (1), cluster (0x0), attribute id (0xffdf), attribute data type (0x42)
[ 89838][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[ 89838][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0xfa56) src endpoint(1) to dst endpoint(1) cluster(0x0)
Pozdrawiam.
8x SRW-01, 1x SBW-01, 1x MEW-01,
10x TH 10, 7x Touch, 1x SV, 1x Basic R2,
2x S26, 4x mini, 2x POW R2, 1x S55,
3x Shelly 1, 1x nodemcu + BME 280,
2x H801. 4x Nous a1, 4x SP111, 2x NEO
1x MoesHouse, 2x SMTONOFF SMT002
1x Sonoff POW R3 25A
andras
Has thanked: 2 times
Been thanked: 4 times
Proszę o dodanie czujnika ruchu :
_TZ3000_6ygjfyll::TS0202
mariomar
zokopian wrote: Thu Feb 20, 2025 5:39 pm Witam.
Software Info:
Board Info:
GPIO Info:
     9 : GPIO
    12 : USB_DM
    13 : USB_DP
    16 : UART_TX[0]
    17 : UART_RX[0]
Pozdrawiam.
Podbijam. :roll: Mam taki sam przypadek, już to zgłaszałem.
viewtopic.php?p=198197#p198197
@zokopian, @mariomar
To nie jest "klasyczny" czujnik T/H zgodny z Zigbee tylko Tuya 0xEF00 - podobny do tego czujnika gleby, ale oczywiście DPs ma inne.
W każdym razie dodany - BWNU - proszę o feedback.
andras wrote: Thu Feb 20, 2025 5:56 pm Proszę o dodanie czujnika ruchu :
+BWNU
zokopian
vajera wrote: Thu Feb 20, 2025 9:42 pm @zokopian, @mariomar
Witam.
Czujnik sparowany z bramką, pojawił się w supli. Pojawiły się też odczyty. Temperatura zaokrąglana jest do pełnego stopnia - da się z tym coś zrobić?
Załączam log :
[  2149][I][Z2S_Gateway.ino:231] loop(): Starting Zigbee subsystem
[  2150][D][ZigbeeCore.cpp:138] zigbeeInit(): Initialize Zigbee stack
[  2153][D][ZigbeeCore.cpp:145] zigbeeInit(): Register all Zigbee EPs in list
[  2157][I][ZigbeeCore.cpp:153] zigbeeInit(): List of registered Zigbee EPs:
[  2157][I][ZigbeeCore.cpp:155] zigbeeInit(): Device type: Home Gateway, Endpoint: 1, Device ID: 0x0050
[  2164][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Config Ready (0x17), status: ESP_FAIL
[  2165][I][ZigbeeCore.cpp:246] esp_zb_app_signal_handler(): Zigbee stack initialized
[  2171][I][ZigbeeCore.cpp:358] esp_zb_app_signal_handler(): Network(0xb110) closed, devices joining not allowed.
[  2172][I][ZigbeeCore.cpp:252] esp_zb_app_signal_handler(): Device started up in non factory-reset mode
[  2173][I][ZigbeeCore.cpp:265] esp_zb_app_signal_handler(): Device rebooted
[  2173][I][ZigbeeCore.cpp:269] esp_zb_app_signal_handler(): Opening network for joining for 180 seconds
[  2174][D][ZigbeeCore.cpp:499] searchBindings(): Requesting binding table for address 0x0000
[  2175][D][ZigbeeCore.cpp:439] bindingTableCb(): Binding table callback for address 0x0000 with status 0
[  2176][D][ZigbeeCore.cpp:442] bindingTableCb(): Binding table info: total 1, index 0, count 1
[  2176][D][ZigbeeCore.cpp:452] bindingTableCb(): Binding table record: src_endp 1, dst_endp 1, cluster_id 0xef00, dst_addr_mode 3
[  2177][I][z2s_devices_table.cpp:861] Z2S_onBTCBoundDevice(): BTC bound device(0x1b78) on endpoint(0x1), cluster id(0xef00)
[  2178][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xffffffff
[  2178][I][z2s_devices_table.cpp:83] Z2S_findChannelNumberNextSlot(): Z2S_findChannelNumberNextSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xffffffff
[  2179][D][ZigbeeCore.cpp:469] bindingTableCb(): Device bound to EP 1 -> device endpoint: 216, short addr: 0x4082, ieee addr: 40:81:A4:F4:40:81:A4:F4
[  2180][D][ZigbeeCore.cpp:490] bindingTableCb(): Filling bounded devices finished
Starting local web server
Recv: [53 55 50 4C 41 17 02 00 00 00 AD 02 00 00 1C 00 00 00 01 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 01 00 01 53 55 50 4C 41 ]
Received new device config
Processing AutomaticTimeSync config
Sending device config result OK (1)
Send: [53 55 50 4C 41 17 04 00 00 00 B7 02 00 00 0A 00 00 00 01 00 00 00 00 00 00 00 00 00 ]
Send: [53 55 50 4C 41 ]
Recv: [53 55 50 4C 41 17 03 00 00 00 AA 02 00 00 08 00 00 00 00 2D 00 00 00 00 00 00 53 55 50 4C 41 ]
Received SetChannelConfig for channel 0, function 45, config type 0, config size 0
Channel[0]: handleChannelConfig, func 45, configtype 0, configsize 0
Channel[0] no config on server
Sending channel config result OK (1)
Send: [53 55 50 4C 41 17 05 00 00 00 B4 02 00 00 03 00 00 00 01 00 00 ]
Recv: [53 55 50 4C 41 17 04 00 00 00 AB 02 00 00 01 00 00 00 00 53 55 50 4C 41 ]
Received ChannelConfigFinished for channel [0]
Send: [53 55 50 4C 41 17 06 00 00 00 A9 02 00 00 28 00 00 00 00 2D 00 00 00 00 20 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ]
Channel[0]: channel config send
Recv: [53 55 50 4C 41 17 05 00 00 00 DC 00 00 00 03 00 00 00 1E 0A F0 53 55 50 4C 41 ]
Activity timeout set to 30 s
Recv: [53 55 50 4C 41 17 06 00 00 00 EA 01 00 00 1A 00 00 00 E9 07 02 15 06 09 0B 0C 0E 00 00 00 45 75 72 6F 70 65 2F 57 61 72 73 61 77 00 53 55 50 4C 41 ]
Clock: current time: 2025-02-21 09:11:11
Clock: time diff (system-new): -1 s
Clock: new time: 2025-02-21 09:11:12
Recv: [53 55 50 4C 41 17 07 00 00 00 B3 02 00 00 03 00 00 00 01 00 00 53 55 50 4C 41 ]
Channel[0] Set channel config succeeded (1)
Recv: [53 55 50 4C 41 17 08 00 00 00 AA 02 00 00 28 00 00 00 00 2D 00 00 00 00 20 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 55 50 4C 41 ]
Received SetChannelConfig for channel 0, function 45, config type 0, config size 32
Channel[0]: handleChannelConfig, func 45, configtype 0, configsize 32
Channel[0] temperature correction 0.00
Channel[0] humidity correction 0.00
Send: [53 55 50 4C 41 17 07 00 00 00 B4 02 00 00 03 00 00 00 01 00 00 ]
[  2643][I][ZigbeeCore.cpp:356] esp_zb_app_signal_handler(): Network(0xb110) is open for 180 seconds
LittleFsConfig: writing to file "/supla-dev.cfg"
LittleFsConfig: writing to file "/supla-dev.cfg.bak"
[ 23526][V][WebServer.cpp:416] handleClient(): New client: client.localIP()=10.10.10.118
[ 23527][V][Parsing.cpp:128] _parseRequest(): method: GET url: / search:
[ 23528][V][Parsing.cpp:296] _collectHeader(): header skipped: Host: 10.10.10.118
[ 23528][V][Parsing.cpp:296] _collectHeader(): header skipped: Connection: keep-alive
[ 23529][V][Parsing.cpp:296] _collectHeader(): header skipped: DNT: 1
[ 23530][V][Parsing.cpp:296] _collectHeader(): header skipped: Upgrade-Insecure-Requests: 1
[ 23531][V][Parsing.cpp:296] _collectHeader(): header skipped: User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/133.0.0.0 Safari/537.36
[ 23533][V][Parsing.cpp:296] _collectHeader(): header skipped: Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7
[ 23534][V][Parsing.cpp:296] _collectHeader(): header skipped: Accept-Encoding: gzip, deflate
[ 23535][V][Parsing.cpp:296] _collectHeader(): header skipped: Accept-Language: pl-PL,pl;q=0.9,en-US;q=0.8,en;q=0.7,de;q=0.6
[ 23536][V][Parsing.cpp:302] _parseArguments(): args:
[ 23536][V][Parsing.cpp:268] _parseRequest(): Request: /
[ 23537][V][Parsing.cpp:269] _parseRequest():  Arguments:
SERVER: get request
[ 27028][V][WebServer.cpp:416] handleClient(): New client: client.localIP()=10.10.10.118
Send: [53 55 50 4C 41 17 08 00 00 00 28 00 00 00 10 00 00 00 49 43 B8 67 00 00 00 00 D9 5F 03 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 09 00 00 00 32 00 00 00 10 00 00 00 3A 35 B8 67 00 00 00 00 4B 06 00 00 00 00 00 00 53 55 50 4C 41 ]
[ 37552][V][ssl_client.cpp:364] stop_ssl_socket(): Cleaning SSL connection.
Deinitializing SRPC
Supla server connection lost. Trying to reconnect
[ 37555][V][ssl_client.cpp:364] stop_ssl_socket(): Cleaning SSL connection.
[ 37556][V][ssl_client.cpp:364] stop_ssl_socket(): Cleaning SSL connection.
Connecting without certificate validation (INSECURE)
Establishing encrypted connection with: svr11.supla.org (port: 2016)
[ 38550][D][NetworkManager.cpp:127] hostByName(): DNS found IPv4 188.34.204.56
[ 38551][V][ssl_client.cpp:68] start_ssl_client(): Free internal heap before TLS 241040
[ 38552][V][ssl_client.cpp:75] start_ssl_client(): Starting socket (domain 2)
[ 38596][V][ssl_client.cpp:170] start_ssl_client(): Seeding the random number generator
[ 38602][V][ssl_client.cpp:178] start_ssl_client(): Setting up the SSL/TLS structure...
[ 38602][D][ssl_client.cpp:196] start_ssl_client(): WARNING: Skipping SSL Verification. INSECURE!
[ 38603][V][ssl_client.cpp:292] start_ssl_client(): Setting hostname for TLS session...
[ 38604][V][ssl_client.cpp:313] ssl_starttls_handshake(): Performing the SSL/TLS handshake...
[ 39213][V][ssl_client.cpp:334] ssl_starttls_handshake(): Verifying peer X.509 certificate...
[ 39213][V][ssl_client.cpp:342] ssl_starttls_handshake(): Certificate verified.
[ 39214][V][ssl_client.cpp:358] ssl_starttls_handshake(): Free internal heap after TLS 202420
Connected via IP 10.10.10.118
SSL error: 48, UNKNOWN ERROR CODE (0030)
Connected to Supla Server
Initializing SRPC (proto: 23)
Send: [53 55 50 4C 41 17 01 00 00 00 4B 00 00 00 6B 02 00 00 7A 6F 6B 6F 70 69 61 6E 40 67 6D 61 69 6C 2E 63 6F 6D 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E7 9B 4D 64 B8 13 10 C2 E4 43 04 DB E5 C2 4E 1B 7A A8 94 B7 D6 CA 15 71 BF B5 81 AC ED C4 9B D8 5A 69 67 62 65 65 20 74 6F 20 53 75 70 6C 61 20 47 61 74 65 77 61 79 00 00 00 00 00 00 00 00 00 00 00 ]
CH[0], type: 3038, FuncList: 0x0, function: 45, flags: 0x8010000, online, validityTimeSec: 0, icon: 0, value: [c8 cd fb ff 18 fc ff ff]
Send: [00 DE 0B 00 00 00 00 00 00 2D 00 00 00 00 00 01 08 00 00 00 00 00 00 00 00 00 C8 CD FB FF 18 FC FF FF 00 ]
Recv: [53 55 50 4C 41 17 01 00 00 00 46 00 00 00 07 00 00 00 03 00 00 00 78 1B 01 53 55 50 4C 41 ]
Device registered (activity timeout 120 s, server version: 27, server min version: 1)
Changing activity timeout to 30 s
Send: [53 55 50 4C 41 17 02 00 00 00 D2 00 00 00 01 00 00 00 1E ]
Send: [53 55 50 4C 41 17 03 00 00 00 B7 02 00 00 0A 00 00 00 01 00 00 00 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 03 00 00 00 AA 02 00 00 28 00 00 00 00 2D 00 00 00 00 20 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 04 00 00 00 B4 02 00 00 03 00 00 00 01 00 00 ]
[ 60001][I][Z2S_Gateway.ino:248] loop(): Device on endpoint(0x1), short address(0x1b78), model id(0x1010), rejoined(NO)
Send: [53 55 50 4C 41 17 05 00 00 00 28 00 00 00 10 00 00 00 6E 43 B8 67 00 00 00 00 C5 09 03 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 06 00 00 00 32 00 00 00 10 00 00 00 5E 35 B8 67 00 00 00 00 DD CE 0E 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 06 00 00 00 28 00 00 00 10 00 00 00 87 43 B8 67 00 00 00 00 7D 15 03 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 07 00 00 00 32 00 00 00 10 00 00 00 77 35 B8 67 00 00 00 00 92 90 0E 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 07 00 00 00 28 00 00 00 10 00 00 00 A0 43 B8 67 00 00 00 00 35 21 03 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 08 00 00 00 32 00 00 00 10 00 00 00 90 35 B8 67 00 00 00 00 75 5A 0E 00 00 00 00 00 53 55 50 4C 41 ]
[118669][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[118677][I][ZigbeeCore.cpp:325] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x1b78)
[118678][V][ZigbeeCore.cpp:329] esp_zb_app_signal_handler(): Device capabilities: 0x80
[118678][D][ZigbeeCore.cpp:346] esp_zb_app_signal_handler(): Device already bound to endpoint 1
[120003][I][Z2S_Gateway.ino:248] loop(): Device on endpoint(0x1), short address(0x1b78), model id(0x1010), rejoined(YES)
[121735][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0xa, command id: 0
[121735][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[121736][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 0
[121736][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x0
[121737][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 11 size: 2
[121737][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x07
[121737][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[121738][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x1b78, 0x1b78, 0x0, 0x0
[121738][I][z2s_devices_table.cpp:502] Z2S_onCustomCmdReceive(): Z2S_onCustomCmdReceive cluster 0xa, command id 0x0, rssi: -61
[121739][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0x2af8
[121740][I][z2s_devices_table.cpp:507] Z2S_onCustomCmdReceive(): No channel found for address  )o4 8
[121740][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[123685][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[123686][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 17 from address 0x1b78
[123686][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 3
[123687][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[123687][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0xe
[123687][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x40
[123688][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0x17d4
[123689][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xfa0
[123689][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xbde
[123809][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[123810][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x1b78) src endpoint(1) to dst endpoint(1) cluster(0x0)
[123810][I][ZigbeeGateway.cpp:615] zbAttributeReporting(): zbAttributeReporting from (0x29cc), endpoint (1), cluster (0x0), attribute id (0x1), attribute data type (0x20)
[123811][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[123812][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x1b78) src endpoint(1) to dst endpoint(1) cluster(0x0)
[123812][I][ZigbeeGateway.cpp:615] zbAttributeReporting(): zbAttributeReporting from (0x29cc), endpoint (1), cluster (0x0), attribute id (0xffe2), attribute data type (0x20)
[123813][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[123814][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x1b78) src endpoint(1) to dst endpoint(1) cluster(0x0)
[123814][I][ZigbeeGateway.cpp:615] zbAttributeReporting(): zbAttributeReporting from (0x29cc), endpoint (1), cluster (0x0), attribute id (0xffe4), attribute data type (0x20)
[124385][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x2000) callback
[124386][V][ZigbeeHandlers.cpp:129] zb_attribute_reporting_handler(): Received report from address(0x1b78) src endpoint(1) to dst endpoint(1) cluster(0x0)
[124387][I][ZigbeeGateway.cpp:615] zbAttributeReporting(): zbAttributeReporting from (0x29cc), endpoint (1), cluster (0x0), attribute id (0xffdf), attribute data type (0x42)
Send: [53 55 50 4C 41 17 08 00 00 00 28 00 00 00 10 00 00 00 B9 43 B8 67 00 00 00 00 EF 2C 03 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 09 00 00 00 32 00 00 00 10 00 00 00 A9 35 B8 67 00 00 00 00 F7 62 0E 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 09 00 00 00 28 00 00 00 10 00 00 00 D2 43 B8 67 00 00 00 00 77 40 03 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 0A 00 00 00 32 00 00 00 10 00 00 00 C2 35 B8 67 00 00 00 00 A2 75 0E 00 00 00 00 00 53 55 50 4C 41 ]
[180005][I][Z2S_Gateway.ino:248] loop(): Device on endpoint(0x1), short address(0x1b78), model id(0x1010), rejoined(YES)
[182644][I][ZigbeeCore.cpp:358] esp_zb_app_signal_handler(): Network(0xb110) closed, devices joining not allowed.
Send: [53 55 50 4C 41 17 0A 00 00 00 28 00 00 00 10 00 00 00 EB 43 B8 67 00 00 00 00 18 50 03 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 0B 00 00 00 32 00 00 00 10 00 00 00 DC 35 B8 67 00 00 00 00 47 01 00 00 00 00 00 00 53 55 50 4C 41 ]
Recv: [53 55 50 4C 41 17 0C 00 00 00 F4 01 00 00 08 00 00 00 76 1D 00 00 00 C1 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 0B 00 00 00 FE 01 00 00 32 00 00 00 76 1D 00 00 00 00 00 00 B3 09 00 00 00 00 00 00 0A 0A 0A 76 40 4C CA 5F 89 D4 00 00 B3 2E 00 00 D4 00 00 00 AE 00 00 00 00 03 00 00 00 00 00 00 00 00 ]
Send: [53 55 50 4C 41 17 0C 00 00 00 28 00 00 00 10 00 00 00 1A 44 B8 67 00 00 00 00 A0 F6 0D 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 0D 00 00 00 32 00 00 00 10 00 00 00 0B 36 B8 67 00 00 00 00 D1 E9 09 00 00 00 00 00 53 55 50 4C 41 ]
[240007][I][Z2S_Gateway.ino:248] loop(): Device on endpoint(0x1), short address(0x1b78), model id(0x1010), rejoined(YES)
Send: [53 55 50 4C 41 17 0D 00 00 00 28 00 00 00 10 00 00 00 33 44 B8 67 00 00 00 00 29 0A 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 0E 00 00 00 32 00 00 00 10 00 00 00 24 36 B8 67 00 00 00 00 6F C8 0A 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 0E 00 00 00 28 00 00 00 10 00 00 00 4C 44 B8 67 00 00 00 00 E3 15 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 0F 00 00 00 32 00 00 00 10 00 00 00 3D 36 B8 67 00 00 00 00 70 8A 0A 00 00 00 00 00 53 55 50 4C 41 ]
[300009][I][Z2S_Gateway.ino:248] loop(): Device on endpoint(0x1), short address(0x1b78), model id(0x1010), rejoined(YES)
Send: [53 55 50 4C 41 17 0F 00 00 00 E0 01 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 10 00 00 00 EA 01 00 00 1A 00 00 00 E9 07 02 15 06 09 10 0C 0E 00 00 00 45 75 72 6F 70 65 2F 57 61 72 73 61 77 00 53 55 50 4C 41 ]
Clock: current time: 2025-02-21 09:16:12
Send: [53 55 50 4C 41 17 10 00 00 00 28 00 00 00 10 00 00 00 74 44 B8 67 00 00 00 00 A4 21 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 11 00 00 00 32 00 00 00 10 00 00 00 65 36 B8 67 00 00 00 00 CC 17 0A 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 11 00 00 00 28 00 00 00 10 00 00 00 8D 44 B8 67 00 00 00 00 24 35 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 12 00 00 00 32 00 00 00 10 00 00 00 7E 36 B8 67 00 00 00 00 D9 EA 0A 00 00 00 00 00 53 55 50 4C 41 ]
[360011][I][Z2S_Gateway.ino:248] loop(): Device on endpoint(0x1), short address(0x1b78), model id(0x1010), rejoined(YES)
Send: [53 55 50 4C 41 17 12 00 00 00 28 00 00 00 10 00 00 00 A6 44 B8 67 00 00 00 00 DA 40 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 13 00 00 00 32 00 00 00 10 00 00 00 97 36 B8 67 00 00 00 00 24 D9 0A 00 00 00 00 00 53 55 50 4C 41 ]
[390940][V][WebServer.cpp:416] handleClient(): New client: client.localIP()=10.10.10.118
[390941][V][Parsing.cpp:128] _parseRequest(): method: GET url: / search:
[390942][V][Parsing.cpp:296] _collectHeader(): header skipped: Host: 10.10.10.118
[390943][V][Parsing.cpp:296] _collectHeader(): header skipped: Connection: keep-alive
[390943][V][Parsing.cpp:296] _collectHeader(): header skipped: DNT: 1
[390944][V][Parsing.cpp:296] _collectHeader(): header skipped: Upgrade-Insecure-Requests: 1
[390945][V][Parsing.cpp:296] _collectHeader(): header skipped: User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/133.0.0.0 Safari/537.36
[390947][V][Parsing.cpp:296] _collectHeader(): header skipped: Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7
[390948][V][Parsing.cpp:296] _collectHeader(): header skipped: Accept-Encoding: gzip, deflate
[390949][V][Parsing.cpp:296] _collectHeader(): header skipped: Accept-Language: pl-PL,pl;q=0.9,en-US;q=0.8,en;q=0.7,de;q=0.6
[390950][V][Parsing.cpp:302] _parseArguments(): args:
[390951][V][Parsing.cpp:268] _parseRequest(): Request: /
[390951][V][Parsing.cpp:269] _parseRequest():  Arguments:
SERVER: get request
[394013][V][WebServer.cpp:416] handleClient(): New client: client.localIP()=10.10.10.118
[399017][V][WebServer.cpp:416] handleClient(): New client: client.localIP()=10.10.10.118
Send: [53 55 50 4C 41 17 13 00 00 00 28 00 00 00 10 00 00 00 BF 44 B8 67 00 00 00 00 79 4C 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 14 00 00 00 32 00 00 00 10 00 00 00 B0 36 B8 67 00 00 00 00 5E 7B 0A 00 00 00 00 00 53 55 50 4C 41 ]
[420013][I][Z2S_Gateway.ino:248] loop(): Device on endpoint(0x1), short address(0x1b78), model id(0x1010), rejoined(YES)
Send: [53 55 50 4C 41 17 14 00 00 00 28 00 00 00 10 00 00 00 D8 44 B8 67 00 00 00 00 4E 58 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 15 00 00 00 32 00 00 00 10 00 00 00 C9 36 B8 67 00 00 00 00 86 4F 0A 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 15 00 00 00 28 00 00 00 10 00 00 00 F1 44 B8 67 00 00 00 00 D6 6B 0E 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 16 00 00 00 32 00 00 00 10 00 00 00 E2 36 B8 67 00 00 00 00 46 6B 0A 00 00 00 00 00 53 55 50 4C 41 ]
[466885][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[466885][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1b78
[466886][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[466887][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[466887][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x81
[466888][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1
[466888][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[466888][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[466889][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[466889][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[466890][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[466890][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[466891][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0xf8
[466891][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0x17d4
[466892][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xfa0
[466893][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xbde
[467060][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[467061][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1b78
[467061][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[467062][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[467062][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x82
[467063][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x2
[467063][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[467063][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[467064][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[467064][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[467065][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[467065][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[467066][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x2e
[467066][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0x17d4
[467067][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xfa0
[467068][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xbde
[467233][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[467234][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1b78
[467234][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[467235][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[467235][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x83
[467236][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x3
[467236][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[467236][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[467237][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[467237][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x2
[467238][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0x17d4
[467239][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xfa0
[467239][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xbde
[467407][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[467408][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1b78
[467408][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[467408][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[467409][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x84
[467409][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x9
[467410][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[467410][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[467411][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[467411][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[467412][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0x17d4
[467412][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xfa0
[467413][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xbde
Channel(0) value changed to temp(24.00), humi(46.00)
Send: [53 55 50 4C 41 17 16 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 C0 5D 00 00 B0 B3 00 00 ]
Send: [53 55 50 4C 41 17 17 00 00 00 28 00 00 00 10 00 00 00 0B 45 B8 67 00 00 00 00 51 81 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 17 00 00 00 32 00 00 00 10 00 00 00 FB 36 B8 67 00 00 00 00 47 BA 0B 00 00 00 00 00 53 55 50 4C 41 ]
[480015][I][Z2S_Gateway.ino:248] loop(): Device on endpoint(0x1), short address(0x1b78), model id(0x1010), rejoined(YES)
Send: [53 55 50 4C 41 17 18 00 00 00 28 00 00 00 10 00 00 00 24 45 B8 67 00 00 00 00 D7 94 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 18 00 00 00 32 00 00 00 10 00 00 00 14 37 B8 67 00 00 00 00 73 CD 0B 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 19 00 00 00 28 00 00 00 10 00 00 00 3D 45 B8 67 00 00 00 00 76 A4 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 19 00 00 00 32 00 00 00 10 00 00 00 2D 37 B8 67 00 00 00 00 DD 87 0C 00 00 00 00 00 53 55 50 4C 41 ]
[540017][I][Z2S_Gateway.ino:248] loop(): Device on endpoint(0x1), short address(0x1b78), model id(0x1010), rejoined(YES)
Send: [53 55 50 4C 41 17 1A 00 00 00 28 00 00 00 10 00 00 00 56 45 B8 67 00 00 00 00 32 B0 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 1A 00 00 00 32 00 00 00 10 00 00 00 46 37 B8 67 00 00 00 00 2F 51 0C 00 00 00 00 00 53 55 50 4C 41 ]
[573824][V][ssl_client.cpp:364] stop_ssl_socket(): Cleaning SSL connection.
Deinitializing SRPC
[573827][V][ssl_client.cpp:364] stop_ssl_socket(): Cleaning SSL connection.
[574936][D][NetworkManager.cpp:127] hostByName(): DNS found IPv4 188.34.204.56
[574937][V][ssl_client.cpp:68] start_ssl_client(): Free internal heap before TLS 241300
[574937][V][ssl_client.cpp:75] start_ssl_client(): Starting socket (domain 2)
[575054][V][ssl_client.cpp:170] start_ssl_client(): Seeding the random number generator
[575059][V][ssl_client.cpp:178] start_ssl_client(): Setting up the SSL/TLS structure...
[575060][D][ssl_client.cpp:196] start_ssl_client(): WARNING: Skipping SSL Verification. INSECURE!
[575060][V][ssl_client.cpp:292] start_ssl_client(): Setting hostname for TLS session...
[575061][V][ssl_client.cpp:313] ssl_starttls_handshake(): Performing the SSL/TLS handshake...
[575589][V][ssl_client.cpp:334] ssl_starttls_handshake(): Verifying peer X.509 certificate...
[575589][V][ssl_client.cpp:342] ssl_starttls_handshake(): Certificate verified.
[575590][V][ssl_client.cpp:358] ssl_starttls_handshake(): Free internal heap after TLS 202692
CH[0], type: 3038, FuncList: 0x0, function: 45, flags: 0x8010000, online, validityTimeSec: 0, icon: 0, value: [c0 5d 00 00 b0 b3 00 00]
Send: [00 DE 0B 00 00 00 00 00 00 2D 00 00 00 00 00 01 08 00 00 00 00 00 00 00 00 00 C0 5D 00 00 B0 B3 00 00 00 ]
Recv: [53 55 50 4C 41 17 03 00 00 00 AA 02 00 00 28 00 00 00 00 2D 00 00 00 00 20 00 14 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 55 50 4C 41 ]
Channel[0] temperature correction 0.20
Channel(0) value changed to temp(24.20), humi(46.00)
Send: [53 55 50 4C 41 17 05 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 88 5E 00 00 B0 B3 00 00 ]
[577103][V][ssl_client.cpp:364] stop_ssl_socket(): Cleaning SSL connection.
Deinitializing SRPC
[577106][V][ssl_client.cpp:364] stop_ssl_socket(): Cleaning SSL connection.
[577107][V][ssl_client.cpp:364] stop_ssl_socket(): Cleaning SSL connection.
[578105][D][NetworkManager.cpp:127] hostByName(): DNS found IPv4 188.34.204.56
[578106][V][ssl_client.cpp:68] start_ssl_client(): Free internal heap before TLS 241300
[578107][V][ssl_client.cpp:75] start_ssl_client(): Starting socket (domain 2)
[578146][V][ssl_client.cpp:170] start_ssl_client(): Seeding the random number generator
[578151][V][ssl_client.cpp:178] start_ssl_client(): Setting up the SSL/TLS structure...
[578152][D][ssl_client.cpp:196] start_ssl_client(): WARNING: Skipping SSL Verification. INSECURE!
[578152][V][ssl_client.cpp:292] start_ssl_client(): Setting hostname for TLS session...
[578153][V][ssl_client.cpp:313] ssl_starttls_handshake(): Performing the SSL/TLS handshake...
[578832][V][ssl_client.cpp:334] ssl_starttls_handshake(): Verifying peer X.509 certificate...
[578833][V][ssl_client.cpp:342] ssl_starttls_handshake(): Certificate verified.
[578833][V][ssl_client.cpp:358] ssl_starttls_handshake(): Free internal heap after TLS 202696
CH[0], type: 3038, FuncList: 0x0, function: 45, flags: 0x8010000, online, validityTimeSec: 0, icon: 0, value: [88 5e 00 00 b0 b3 00 00]
Send: [00 DE 0B 00 00 00 00 00 00 2D 00 00 00 00 00 01 08 00 00 00 00 00 00 00 00 00 88 5E 00 00 B0 B3 00 00 00 ]
Send: [53 55 50 4C 41 17 05 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 C0 5D 00 00 B0 B3 00 00 ]
[600019][I][Z2S_Gateway.ino:248] loop(): Device on endpoint(0x1), short address(0x1b78), model id(0x1010), rejoined(YES)
Send: [53 55 50 4C 41 17 06 00 00 00 E0 01 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 06 00 00 00 EA 01 00 00 1A 00 00 00 E9 07 02 15 06 09 15 0C 0E 00 00 00 45 75 72 6F 70 65 2F 57 61 72 73 61 77 00 53 55 50 4C 41 ]
Clock: current time: 2025-02-21 09:21:11
Clock: new time: 2025-02-21 09:21:12
[616885][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[616885][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1b78
[616886][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[616886][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[616887][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x85
[616887][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1
[616888][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[616888][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[616888][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[616889][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[616889][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[616890][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[616890][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0xf5
[616891][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0x17d4
[616892][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xfa0
[616892][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xbde
[617061][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[617062][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1b78
[617062][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[617063][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[617063][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x86
[617064][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x2
[617064][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[617065][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[617065][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[617065][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[617066][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[617066][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[617067][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x24
[617067][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0x17d4
[617068][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xfa0
[617069][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xbde
[617239][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[617239][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1b78
[617240][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[617240][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[617241][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x87
[617241][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x3
[617242][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[617242][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[617243][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[617243][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x2
[617243][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0x17d4
[617244][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xfa0
[617245][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xbde
[617414][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[617414][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1b78
[617415][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[617415][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[617416][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x88
[617416][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x9
[617417][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[617417][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[617417][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[617418][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[617418][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0x17d4
[617419][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xfa0
[617420][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xbde
Channel(0) value changed to temp(24.00), humi(36.00)
Send: [53 55 50 4C 41 17 07 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 C0 5D 00 00 A0 8C 00 00 ]
Send: [53 55 50 4C 41 17 08 00 00 00 28 00 00 00 10 00 00 00 A0 45 B8 67 00 00 00 00 BD 3D 0F 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 07 00 00 00 32 00 00 00 10 00 00 00 91 37 B8 67 00 00 00 00 93 AD 0B 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 09 00 00 00 28 00 00 00 10 00 00 00 BA 45 B8 67 00 00 00 00 2A 07 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 08 00 00 00 32 00 00 00 10 00 00 00 AA 37 B8 67 00 00 00 00 A7 74 0B 00 00 00 00 00 53 55 50 4C 41 ]
[660021][I][Z2S_Gateway.ino:248] loop(): Device on endpoint(0x1), short address(0x1b78), model id(0x1010), rejoined(YES)
Send: [53 55 50 4C 41 17 0A 00 00 00 28 00 00 00 10 00 00 00 D3 45 B8 67 00 00 00 00 E3 12 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 09 00 00 00 32 00 00 00 10 00 00 00 C3 37 B8 67 00 00 00 00 9C 3D 0B 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 0B 00 00 00 28 00 00 00 10 00 00 00 EC 45 B8 67 00 00 00 00 97 1E 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 0A 00 00 00 32 00 00 00 10 00 00 00 DC 37 B8 67 00 00 00 00 ED 32 0B 00 00 00 00 00 53 55 50 4C 41 ]
[720023][I][Z2S_Gateway.ino:248] loop(): Device on endpoint(0x1), short address(0x1b78), model id(0x1010), rejoined(YES)
Send: [53 55 50 4C 41 17 0C 00 00 00 28 00 00 00 10 00 00 00 05 46 B8 67 00 00 00 00 25 2E 00 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 0B 00 00 00 32 00 00 00 10 00 00 00 F5 37 B8 67 00 00 00 00 E9 2A 0B 00 00 00 00 00 53 55 50 4C 41 ]
[737080][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[737081][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1b78
[737081][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[737082][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[737082][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x89
[737083][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x1
[737083][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[737084][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[737084][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[737085][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[737085][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[737085][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[737086][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x75
[737086][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0x17d4
[737087][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xfa0
[737088][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xbde
[737255][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[737255][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1b78
[737256][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 10
[737256][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[737257][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x8a
[737257][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x2
[737258][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x2
[737258][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[737258][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x4
[737259][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[737259][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x7] = 0x0
[737260][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x8] = 0x0
[737260][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x9] = 0x25
[737261][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0x17d4
[737262][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xfa0
[737262][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xbde
[737424][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[737425][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1b78
[737425][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[737426][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[737426][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x8b
[737427][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x3
[737427][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[737428][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[737428][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[737428][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x2
[737429][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0x17d4
[737430][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xfa0
[737430][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xbde
[737592][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1040) callback
[737592][I][ZigbeeHandlers.cpp:343] zb_cmd_custom_cluster_req_handler(): Receive custom command: 2 from address 0x1b78
[737593][I][ZigbeeHandlers.cpp:345] zb_cmd_custom_cluster_req_handler(): Payload size: 7
[737593][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x0] = 0x0
[737594][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x1] = 0x8c
[737594][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x2] = 0x9
[737595][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x3] = 0x4
[737595][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x4] = 0x0
[737595][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x5] = 0x1
[737596][I][ZigbeeHandlers.cpp:347] zb_cmd_custom_cluster_req_handler(): Payload [0x6] = 0x0
[737596][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0x17d4
[737597][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xfa0
[737598][I][z2s_devices_table.cpp:62] Z2S_findChannelNumberSlot(): Z2S_findChannelNumberSlot 0xa4:0xc1:0x38:0xdd:0x34:0x6f:0x29:0xcc, endpoint 0x1, channel type 0xbde
Channel(0) value changed to temp(11.00), humi(37.00)
Send: [53 55 50 4C 41 17 0D 00 00 00 67 00 00 00 0E 00 00 00 00 00 00 00 00 00 F8 2A 00 00 88 90 00 00 ]
Send: [53 55 50 4C 41 17 0E 00 00 00 28 00 00 00 10 00 00 00 1E 46 B8 67 00 00 00 00 22 7E 01 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 0C 00 00 00 32 00 00 00 10 00 00 00 0E 38 B8 67 00 00 00 00 47 79 0C 00 00 00 00 00 53 55 50 4C 41 ]
Send: [53 55 50 4C 41 17 0F 00 00 00 28 00 00 00 10 00 00 00 37 46 B8 67 00 00 00 00 CB 8D 01 00 00 00 00 00 ]
Recv: [53 55 50 4C 41 17 0D 00 00 00 32 00 00 00 10 00 00 00 27 38 B8 67 00 00 00 00 90 8F 0C 00 00 00 00 00 53 55 50 4C 41 ]
Pozdrawiam.
Has thanked: 289 times
zokopian wrote: Fri Feb 21, 2025 8:36 am Witam.
Pozdrawiam.
Poprawione - przy okazji powinny się też poprawić odczyty temperatury w tym czujniku gleby (@Yepestis?).
BTW. Daj znać czy po jakimś czasie pojawi Ci się ikona baterii (do 24h) - bo widzę, że on raportuje battery_state (low, medium, high) a nie battery level, ale może mu się zachce? Jak nie to przełączymy się na battery state.
EDIT A jak oceniasz ten czujnik? Stabilność, wiarygodność odczytów, bateria, zasięg do bramki, jakość/cena? Poleciłbyś go innym?
Yepestis
Has thanked: 19 times
Been thanked: 3 times
vajera wrote: Fri Feb 21, 2025 11:04 am
Pozdrawiam.
A ja już myślałem że ten czujnik tak ma że zaokrągla do pełnych stopni.
Teraz pokazuje jedno miejsce po przecinku w temperaturze. Wilgotność też ma jedno miejsce po przecinku ale obecnie u mnie jest tam zaro cały czas to ciężko powiedzieć.
zokopian
Po poprawce temperatura wskazywana z jednym miejscem po przecinku. Jeśli chodzi o wiarygodność pomiarów to temperatura w miarę dobrze jednak wilgotność jest zawyżana o 8-9 punktów procentowych (do skorygowania w cloud). zasięg urządzenia do bramki - powiedziałbym, że średni ale tu ma również znaczenie na jakim urządzeniu jest postawiona bramka. Ja mam postawioną na ESP32-C6 N16. Bateria to CR2032 3V - nie mam pojęcia ile wytrzyma. Ikona baterii jak na razie się nie pojawiła.
Pozdrwaiam.
