Przyciski, guziki, kontrolery scen - zgłoszenia, uwagi, pomysły [bramka ZigBee]
Leszekbialy
Has thanked: 2 times
Proszę o dodanie przycisku
448719][I][ZigbeeGateway.cpp:574] zbDeviceAnnce(): Tuya magic last hope
[449223][I][ZigbeeGateway.cpp:617] printJoinedDevices(): joined devices:
[449224][I][ZigbeeGateway.cpp:620] printJoinedDevices(): Device on endpoint 1, short address: 0xc11d
[449225][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[449226][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
[449227][D][Z2S_Gateway.ino:2268] loop(): Unknown model _TZ3000_5bpeda8u::TS0041, no binding is possible
[449228][V][esp32-hal-rmt.c:306] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
[449229][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Asked to Loop: NO, LoopCancel: NO
[449736][I][ZigbeeHandlers.cpp:37] zb_action_handler(): Receive Zigbee action(0x1000) callback
[449736][V][ZigbeeHandlers.cpp:155] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xc11d) src endpoint(1) to dst endpoint(1) cluster(0x0)
[449737][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(16)
[449738][I][ZigbeeGateway.cpp:411] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_5bpeda8u"
[449738][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[449739][I][ZigbeeGateway.cpp:431] zbReadBasicCluster(): ZCL version id is "3"
[449739][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(68)
[449740][I][ZigbeeGateway.cpp:437] zbReadBasicCluster(): ZCL application version id is "68"
[449740][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[449741][I][ZigbeeGateway.cpp:418] zbReadBasicCluster(): Peer Model is "TS0041"
[449741][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[449742][I][ZigbeeGateway.cpp:443] zbReadBasicCluster(): ZCL power source id is "3"
[449742][V][ZigbeeHandlers.cpp:164] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0xfffe), type(0x30), value(0)
[449743][I][ZigbeeGateway.cpp:447] zbReadBasicCluster(): Attribute 0xFFFE, data type 0x30
[450158][V][ZigbeeCore.cpp:415] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[450230][E][AsyncTCP.cpp:1516] begin(): bind error: -8
Has thanked: 290 times
Leszekbialy wrote: Sat Aug 16, 2025 11:54 pm Proszę o dodanie przycisku
Napisz coś więcej o nim - ile funkcji, przycisków, może link do strony produktu? Wrzucenie tego modelu w Google wygenerowało 1wynik - stronę z forum.supla.org z Twoją prośbą 😉
Leszekbialy
I tu robi się ciekawiej na obudowie Smart Scence Burton model: C3006-Ty01
na opakowaniu XTZ-K1P_F1
w instrukcji ZM-SY101
Jest to jeden klawisz okrągły na baterię CR2450
Been thanked: 31 times
Leszekbialy wrote: Sun Aug 17, 2025 8:18 pm I tu robi się ciekawiej na obudowie Smart Scence Burton model: C3006-Ty01
Jak masz inną bramkę niż Z2S (np. Tuya) to spróbuj go z nią sparować i zobacz jakie funkcje Ci pokaże.
@vajera - piszę powyższe, bo ostatnio zaczęli wypuszczać te przyciski obcięte o jedną funkcję. Konkretnie długie przytrzymanie. Normalnie działa klik i dwuklik. Nawet nie zawracałem Ci głowy i poszedł zwrot "kastrata". Co ciekawe przy niektórych aukcjach nawet to zaznaczają (ale to rzadkość). W każdym razie warto mieć to na uwadze, bo można sporo czasu stracić na zastanawianie się dlaczego long press nie działa...
Leszekbialy
Taki ten jest działa tylko 1klik i 2x klik. W zasadzie to mi wystarczy i nie mam innej bramki
Leszekbialy wrote: Mon Aug 18, 2025 7:16 pm Taki ten jest działa tylko 1klik i 2x klik. W zasadzie to mi wystarczy i nie mam innej bramki
Czyli "kastrat" :lol: Ale jak Ci wystarczy, to OK.
Mario78 wrote: Fri Aug 01, 2025 3:02 pm
vajera wrote: Fri Aug 01, 2025 2:19 pm
Mario78 wrote: Fri Aug 01, 2025 10:06 am @vajera jest nadzieja na ten przycisk?
Odpisz proszę bo nie wiem czy nam na co czekać:)
Dobra, chciałeś to masz zadanie domowe na weekend ;) Wersja 0.8.73-01/08.2025 zawiera wstępną obsługę tego przycisku. Oznacza to, że przycisk powinien się dodać w formie 16(!) wirtualnych przekaźników, które na razie nie będą działać. Od Ciebie potrzebuję natomiast logów z naciskania poszczególnych przycisków, w miarę możliwości z informacją, który przycisk nacisnąłeś.
Obecnie jestem na urlopie wroce w niedzielę i będę logować. Dzięki wielkie za to co juz zrobiles. :)
Leżę na plaży pije piwko i sobie przeglądam co tam nowego aby być na bieżąco. 😀
W razie czego przypominam się o testy, o ile nie zostałeś na tej plaży na dłużej 😉
+BWNU 0.8.93-24/08/2025 - póki co dodałem go zgodnie z opisem - czyli jako przycisk 3-funkcyjny - jeżeli long press nie będzie działał to usunę go z tej definicji.
lukasz06 wrote: Wed Aug 13, 2025 8:37 am Nie wiem czy to akurat Moes (w gui pokazuje ZB device _TZ3000_wkai4ga5::TS0044)
Zostawiłem tą wartość jednak na 0, bo działa szybciej, jeśli chodzi o przypisanie reakcji w Cloud.
Natomiast reakcje lokalne działają z opóźnieniem lub wykonują się co 2-3 naciśnięcia,
To jest MOES4x3 - ustawiając tam "0" sprawiasz, że bramka daje domyślny czas 1500 ms, więc w teorii wpisanie np. 500 powinno dać szybszą reakcję i wtedy reakcje lokalne powinny też lepiej działać.
lukasz06
Has thanked: 45 times
Been thanked: 21 times
vajera wrote: Mon Aug 25, 2025 10:08 am
Dzięki. Ogólnie na razie jeszcze leży na biurku.
Przy okazji zapytam, czy zostawiając na nim tylko 2 kanały, bo w sumie reszty nie potrzebuję
nie będę miał problemów przy aktualizacji bramki?
