arqiu70
Bardzo proszę o dodanie żarówki RGBW-GU10.
[ 48799][I][ZigbeeGateway.cpp:496] zbDeviceAnnce(): Tuya magic last hope
[ 49002][I][ZigbeeGateway.cpp:531] printJoinedDevices(): joined devices:
[ 49002][I][ZigbeeGateway.cpp:534] printJoinedDevices(): Device on endpoint 1, short address: 0x6c62
[ 49203][I][ZigbeeGateway.cpp:297] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[ 49279][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 49279][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x6c62) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 49280][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(7)
[ 49281][I][ZigbeeGateway.cpp:330] zbReadBasicCluster(): Peer Manufacturer is "zbeacon"
[ 49281][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[ 49282][I][ZigbeeGateway.cpp:343] zbReadBasicCluster(): ZCL version id is "3"
[ 49282][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(112)
[ 49283][I][ZigbeeGateway.cpp:349] zbReadBasicCluster(): ZCL application version id is "112"
[ 49284][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[ 49284][I][ZigbeeGateway.cpp:337] zbReadBasicCluster(): Peer Model is "TS0505"
[ 49285][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(1)
[ 49286][I][ZigbeeGateway.cpp:355] zbReadBasicCluster(): ZCL power source id is "1"
[ 49286][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
[ 49300][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[ 49301][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x6c62), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0xc3
[ 49302][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[ 49333][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 49333][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x6c62) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 49334][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[ 49335][I][ZigbeeGateway.cpp:343] zbReadBasicCluster(): ZCL version id is "3"
[ 49474][V][ZigbeeCore.cpp:372] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[ 49544][I][ZigbeeCore.cpp:356] esp_zb_app_signal_handler(): Network(0xb517) is open for 180 seconds
[ 49705][I][ZigbeeGateway.cpp:303] zbQueryDeviceBasicCluster(): basic tsn 0x2
[ 49705][I][ZigbeeGateway.cpp:297] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[ 49740][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 49741][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x6c62) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 49742][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(7)
[ 49742][I][ZigbeeGateway.cpp:330] zbReadBasicCluster(): Peer Manufacturer is "zbeacon"
[ 50206][I][ZigbeeGateway.cpp:303] zbQueryDeviceBasicCluster(): basic tsn 0x3
[ 50206][I][ZigbeeGateway.cpp:297] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x0
[ 50282][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 50283][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x6c62) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 50283][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[ 50284][I][ZigbeeGateway.cpp:343] zbReadBasicCluster(): ZCL version id is "3"
[ 50707][I][ZigbeeGateway.cpp:303] zbQueryDeviceBasicCluster(): basic tsn 0x4
[ 50707][I][ZigbeeGateway.cpp:297] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x1
[ 50757][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 50757][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x6c62) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 50758][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(112)
[ 50759][I][ZigbeeGateway.cpp:349] zbReadBasicCluster(): ZCL application version id is "112"
[ 51208][I][ZigbeeGateway.cpp:303] zbQueryDeviceBasicCluster(): basic tsn 0x5
[ 51208][I][ZigbeeGateway.cpp:297] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[ 51245][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 51245][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x6c62) src endpoint(1) to dst endpoint(1) cluster(0x0)
[ 51246][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(6)
[ 51247][I][ZigbeeGateway.cpp:337] zbReadBasicCluster(): Peer Model is "TS0505"
[ 51711][I][ZigbeeGateway.cpp:303] zbQueryDeviceBasicCluster(): basic tsn 0x6
[ 51711][I][ZigbeeGateway.cpp:297] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x7
[ 51765][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[ 51766][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x6c62) src endpoint(1) to dst endpoint(1) cluster(0x0)
Has thanked: 291 times
arqiu70 wrote: Fri Feb 28, 2025 11:05 am Bardzo proszę o dodanie żarówki RGBW-GU10.
Dodałem (0.4.1), ale ona może wymagać poprawek - pytanie czy jesteś chętny na testy?
arqiu70
vajera wrote: Fri Feb 28, 2025 12:58 pm
Oczywiście, będę testował. Z2S 0.4.1 to wersja do kompilowania, a ja nie mam takiej możliwości. Mogę tylko bin wgrać.
Sorki.
arqiu70 wrote: Fri Feb 28, 2025 1:02 pm
Sorki.
Musiałem poprawić kod bo @klew pozmieniał nazwy funkcji i na GitHubie nie chciało się kompilować ;) Release 0.4.1 właśnie się skompilował.
Has thanked: 135 times
vajera wrote: Fri Feb 28, 2025 2:17 pm Musiałem poprawić kod bo @klew pozmieniał nazwy funkcji i na GitHubie nie chciało się kompilować ;) Release 0.4.1 właśnie się skompilował.
Przepraszam :)
klew wrote: Fri Feb 28, 2025 3:21 pm
Przepraszam :)
Nie ma za co ;) - chciałem być sprytny i nie zaktualizowałem biblioteki u siebie, ale GitHub zaciągnął nową wersję.
arqiu70
Sorki.
Żarówka dodana.
Działa włącz, wyłącz na ściemniaczu ale nie ma reakcji na ustawienia procentowe.
Nie działa RGB.
arqiu70 wrote: Fri Feb 28, 2025 4:34 pm
Sorki.
Żarówka dodana.
Nie działa RGB.
Tak przypuszczałem - dimmer w tym modelu działa nie przez LEVEL_CONTROL a przez ustawienie Color_Temp, co do RGB podobno obsługuje tryb XY i HSV - ja zaimplementowałem póki co tylko HSV, ale może trzeba zmienić tryb.
Przygotuję wersję testową przez weekend.
arqiu70
vajera wrote: Fri Feb 28, 2025 4:39 pm
Żarówka dodana.
Nie działa RGB.
Spoko, jak coś mam kolejną. Tylko czy ten odczyt wystarczy, czy trzeba więcej?
[ 62033][I][ZigbeeGateway.cpp:337] zbReadBasicCluster(): Peer Model is "CK-BL702-AL-01(7009_Z102LG03-1)"
arqiu70 wrote: Fri Feb 28, 2025 4:48 pm Spoko, jak coś mam kolejną. Tylko czy ten odczyt wystarczy, czy trzeba więcej?
Jeszcze Manufacturer name.
