Coś takiego:
Arduino:1.8.13 (Windows 10), Płytka:"Generic ESP8266 Module, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, Basic SSL ciphers (lower ROM use), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, All Flash Contents, 115200"
UWAGA: biblioteka NewPing działa na architekturze(/architekturach) avr, arm i może nie być kompatybilna z obecną płytką która działa na architekturze(/architekturach) esp8266.
sketch\SuplaWebPageOther.cpp: In function 'void handleOther(int)':
SuplaWebPageOther.cpp:168:68: error: 'S_CODES' was not declared in this scope
168 | addLinkBox(webContentBuffer, String(S_CALIBRATION) + S_SPACE + S_CODES, PATH_BRIDGE);
sketch\SuplaWebPageOther.cpp: In function 'void receiveCodeRFBridge()':
SuplaWebPageOther.cpp:503:69: error: 'S_CODES' was not declared in this scope
503 | addFormHeader(webContentBuffer, String(S_SETTING_FOR) + S_SPACE + S_CODES);
SuplaWebPageOther.cpp:510:32: error: 'S_NO' was not declared in this scope; did you mean 'S_ON'?
510 | webContentBuffer += String(S_NO) + S_SPACE + S_CODES;
| S_ON
SuplaWebPageOther.cpp:514:31: error: 'S_READ' was not declared in this scope; did you mean 'S_LED'?
514 | addButton(webContentBuffer, S_READ, getParameterRequest(PATH_BRIDGE, ARG_PARM_URL, "read"));
| S_LED
exit status 1
