GUI-Generic Arduino IDE
@krycha88 - Ratuj !!!
Kompilacja w Arduino IDE
v3.1.5
To zakomentowałem:
https://github.com/krycha88/GUI-Generic ... nfig.h#L44
Ale sypie błędami MDNS
Arduino:1.8.13 (Windows 10), Płytka:"Generic ESP8266 Module, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, Basic SSL ciphers (lower ROM use), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, dtr (aka nodemcu), 26 MHz, 40MHz, DOUT (compatible), 1MB (FS:64KB OTA:~470KB), 2, nonos-sdk 2.2.1+100 (190703), v2 Lower Memory, Disabled, None, All Flash Contents, 115200"
sketch\SuplaConfigESP.cpp: In member function 'virtual void SuplaConfigESP::iterateAlways()':
SuplaConfigESP.cpp:174:26: error: 'MDNS' was not declared in this scope
  174 |         MDNSConfigured = MDNS.begin("supla", WiFi.localIP());
SuplaConfigESP.cpp:181:7: error: 'MDNS' was not declared in this scope
  181 |       MDNS.update();
Znaleziono wiele bibliotek w "WiFiUdp.h"
Wykorzystane: C:\Users\Patrycjusz\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.1\libraries\ESP8266WiFi
Niewykorzystane: D:\arduino-1.8.13\libraries\WiFi
exit status 1
Been thanked: 5 times
poprawiłem.
v3.1.7
Jeżeli zakomentuję:
soft się kompiluje :D
W przeciwnym razie sypie błędami.
Patryk wrote: Thu Jul 29, 2021 7:38 am v3.1.7
Jeżeli zakomentuję:
a jakie te błędy dostajesz?
Coś takiego:
sketch\SuplaConfigESP.cpp: In member function 'int SuplaConfigESP::getGpio(int, int)':
SuplaConfigESP.cpp:348:15: error: 'getAdressMCP23017' was not declared in this scope
  348 |       switch (getAdressMCP23017(nr, function)) {
sketch\SuplaConfigESP.cpp: At global scope:
SuplaConfigESP.cpp:533:6: error: no declaration matches 'bool SuplaConfigESP::checkBusyGpioMCP23017(uint8_t, uint8_t, uint8_t)'
  533 | bool SuplaConfigESP::checkBusyGpioMCP23017(uint8_t gpio, uint8_t nr, uint8_t function) {
sketch\SuplaConfigESP.cpp:533:6: note: no functions named 'bool SuplaConfigESP::checkBusyGpioMCP23017(uint8_t, uint8_t, uint8_t)'
In file included from sketch\SuplaConfigESP.cpp:19:
sketch\SuplaConfigESP.h:49:7: note: 'class SuplaConfigESP' defined here
   49 | class SuplaConfigESP : public Supla::ActionHandler, public Supla::Element {
SuplaConfigESP.cpp:560:9: error: no declaration matches 'uint8_t SuplaConfigESP::getGpioMCP23017(uint8_t, uint8_t)'
  560 | uint8_t SuplaConfigESP::getGpioMCP23017(uint8_t nr, uint8_t function) {
sketch\SuplaConfigESP.cpp:560:9: note: no functions named 'uint8_t SuplaConfigESP::getGpioMCP23017(uint8_t, uint8_t)'
SuplaConfigESP.cpp:575:9: error: no declaration matches 'uint8_t SuplaConfigESP::getAdressMCP23017(uint8_t, uint8_t)'
  575 | uint8_t SuplaConfigESP::getAdressMCP23017(uint8_t nr, uint8_t function) {
sketch\SuplaConfigESP.cpp:575:9: note: no functions named 'uint8_t SuplaConfigESP::getAdressMCP23017(uint8_t, uint8_t)'
SuplaConfigESP.cpp:598:6: error: no declaration matches 'void SuplaConfigESP::setGpioMCP23017(uint8_t, uint8_t, uint8_t, uint8_t)'
  598 | void SuplaConfigESP::setGpioMCP23017(uint8_t gpio, uint8_t adress, uint8_t nr, uint8_t function) {
sketch\SuplaConfigESP.cpp:598:6: note: no functions named 'void SuplaConfigESP::setGpioMCP23017(uint8_t, uint8_t, uint8_t, uint8_t)'
SuplaConfigESP.cpp:614:6: error: no declaration matches 'void SuplaConfigESP::clearGpioMCP23017(uint8_t, uint8_t, uint8_t)'
  614 | void SuplaConfigESP::clearGpioMCP23017(uint8_t gpio, uint8_t nr, uint8_t function) {
sketch\SuplaConfigESP.cpp:614:6: note: no functions named 'void SuplaConfigESP::clearGpioMCP23017(uint8_t, uint8_t, uint8_t)'
SuplaConfigESP.cpp:635:6: error: no declaration matches 'void SuplaConfigESP::clearFunctionGpio(uint8_t)'
  635 | void SuplaConfigESP::clearFunctionGpio(uint8_t function) {
sketch\SuplaConfigESP.cpp:635:6: note: no functions named 'void SuplaConfigESP::clearFunctionGpio(uint8_t)'
SuplaConfigESP.cpp:646:6: error: no declaration matches 'bool SuplaConfigESP::checkActiveMCP23017(uint8_t)'
  646 | bool SuplaConfigESP::checkActiveMCP23017(uint8_t function) {
sketch\SuplaConfigESP.cpp:646:6: note: no functions named 'bool SuplaConfigESP::checkActiveMCP23017(uint8_t)'
SuplaConfigESP.cpp:651:9: error: no declaration matches 'uint8_t SuplaConfigESP::getFunctionMCP23017(uint8_t)'
  651 | uint8_t SuplaConfigESP::getFunctionMCP23017(uint8_t adress) {
sketch\SuplaConfigESP.cpp:651:9: note: no functions named 'uint8_t SuplaConfigESP::getFunctionMCP23017(uint8_t)'
SuplaConfigESP.cpp:669:9: error: no declaration matches 'uint8_t SuplaConfigESP::getNrMCP23017(uint8_t)'
  669 | uint8_t SuplaConfigESP::getNrMCP23017(uint8_t adress) {
sketch\SuplaConfigESP.cpp:669:9: note: no functions named 'uint8_t SuplaConfigESP::getNrMCP23017(uint8_t)'
exit status 1
już powinno być ok.
I teraz jest ok. :D
v4.0.8 - własna kompilacja.
Tak informacyjnie.
Ostatnią moją kompilacją była v3.1.29 i było ok.
Dziś pobrałem v4.0.8
Z uwagi, że widziałem dużo zmian w bibliotekach, podmieniłem cały swój folder
z bibliotekami na Twój.
No i upss.. (błędy kompilacji).
Metodą prób i błędów doszedłem do tego, że brakuje jednej biblioteki:
Adafruit Sensor-master
Po zainstalowaniu tej biblioteki, wszystko ładnie się kompiluje.
Edit:
Również zwiększył się rozmiar pliku przy tych samych ustawieniach.
Z 642KB na 660KB.
Dla jakiego sensora miałeś te błędy?
krycha88 wrote: Thu Sep 02, 2021 3:27 pm Dla jakiego sensora miałeś te błędy?
Coś takiego:
In file included from D:\Supla\Arduino IDE\libraries\SuplaDevice\src/supla/sensor/BME280.h:21,
                 from sketch\SuplaDeviceGUI.h:69,
                 from D:\Supla\Arduino IDE\GUI-Generic_4.0.8\GUI-Generic\GUI-Generic.ino:16:
D:\Supla\Arduino IDE\libraries\Adafruit_BME280/Adafruit_BME280.h:28:10: fatal error: Adafruit_Sensor.h: No such file or directory
   28 | #include <Adafruit_Sensor.h>
compilation terminated.
exit status 1
Błąd kompilacji dla płytki Generic ESP8266 Module.
Return to “GUI Generic”
