lukasz06
Has thanked: 46 times
Been thanked: 21 times
Witam, poproszę o dodanie czujnika dymu https://inteligentnydom.co/bezpieczenst ... n-hs1sa-e/
Peer Model is "SmokeSensor-EF-3.0"
Peer Manufacturer is "HEIMAN"
Logi ze skanera
         ============ After Setup End =============
                                                   [  2859][I][ZigbeeCore.cpp:38        6] esp_zb_app_signal_handler(): Network(0xf85f) is open for 180 seconds
[160586][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[160586][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[175108][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[175109][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[182859][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0xf85f) closed, devices joining not allowed.
[189647][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[189647][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[293353][V][ZigbeeCore.cpp:254] openNetwork(): Opening network for joining for 180 seconds
[293820][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0xf85f) is open for 180 seconds
[309497][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[309500][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[311522][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
[311524][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
[311567][I][ZigbeeCore.cpp:354] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x49d1)
[311568][V][ZigbeeCore.cpp:358] esp_zb_app_signal_handler(): Device capabilities: 0x80
[311568][D][ZigbeeGateway.cpp:475] zbDeviceAnnce(): zbDeviceAnnce short address (0x49d1), ieee_addr (0xf8):(0x44):(0x77):(0xff):(0xfe):(0xa3):(0xc9):(0x6d)
[311569][D][ZigbeeGateway.cpp:478] zbDeviceAnnce(): zbDeviceAnnce joined device short address (0x49d1), ieee_addr (0xf8):(0x44):(0x77):(0xff):(0xfe):(0xa3):(0xc9):(0x6d)
[311570][I][ZigbeeGateway.cpp:502] zbDeviceAnnce(): Tuya magic last hope
[311798][I][ZigbeeGateway.cpp:545] printJoinedDevices(): joined devices:
[311798][I][ZigbeeGateway.cpp:548] printJoinedDevices(): Device on endpoint 1, short address: 0x49d1
[312025][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[312025][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x49d1) src endpoint(1) to dst endpoint(1) cluster(0x0)
[312026][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(6)
[312027][I][ZigbeeGateway.cpp:346] zbReadBasicCluster(): Peer Manufacturer is "HEIMAN"
[312027][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x0), type(0x20), value(3)
[312028][I][ZigbeeGateway.cpp:359] zbReadBasicCluster(): ZCL version id is "3"
[312028][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x1), type(0x20), value(17)
[312029][I][ZigbeeGateway.cpp:365] zbReadBasicCluster(): ZCL application version id is "17"
[312030][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(18)
[312030][I][ZigbeeGateway.cpp:353] zbReadBasicCluster(): Peer Model is "SmokeSensor-EF-3.0"
[312031][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x7), type(0x30), value(3)
[312031][I][ZigbeeGateway.cpp:371] zbReadBasicCluster(): ZCL power source id is "3"
[312032][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0xfffe), type(0x0), value(0)
[312036][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1005) callback
[312037][V][ZigbeeHandlers.cpp:271] zb_cmd_default_resp_handler(): Received default response: from address(0x49d1), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x3) with status 0xc3
[312037][V][ZigbeeHandlers.cpp:275] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
[312038][I][ZigbeeGateway.cpp:1372] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn 0x1[0x2]
[312039][I][ZigbeeGateway.cpp:1374] zbCmdDefaultResponse(): custom cmd rssi -53
[312199][I][ZigbeeGateway.cpp:313] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4
[312602][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[312602][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x49d1) src endpoint(1) to dst endpoint(1) cluster(0x0)
[312603][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x4), type(0x42), value(6)
[312604][I][ZigbeeGateway.cpp:346] zbReadBasicCluster(): Peer Manufacturer is "HEIMAN"
[312700][I][ZigbeeGateway.cpp:319] zbQueryDeviceBasicCluster(): basic tsn 0x2
[312700][I][ZigbeeGateway.cpp:313] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x5
[313201][I][ZigbeeGateway.cpp:319] zbQueryDeviceBasicCluster(): basic tsn 0x3
[313599][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1000) callback
[313599][V][ZigbeeHandlers.cpp:151] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x49d1) src endpoint(1) to dst endpoint(1) cluster(0x0)
[313600][V][ZigbeeHandlers.cpp:160] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x5), type(0x42), value(18)
[313601][I][ZigbeeGateway.cpp:353] zbReadBasicCluster(): Peer Model is "SmokeSensor-EF-3.0"
[313604][I][ZigbeeGateway.cpp:1065] sendAttributeWrite(): Sending 'write attribute' command - id (0xffde), type (0x20), size (0x1), value (0x13)
[313655][I][ZigbeeHandlers.cpp:58] zb_raw_cmd_handler(): cluster id: 0x0, command id: 241
[313655][I][ZigbeeHandlers.cpp:59] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[313656][I][ZigbeeHandlers.cpp:60] zb_raw_cmd_handler(): is common comand 0, disable_default_response 0, is_manuf_specific 1
[313656][I][ZigbeeHandlers.cpp:61] zb_raw_cmd_handler(): manuf_specific 0x120b
[313657][I][ZigbeeHandlers.cpp:63] zb_raw_cmd_handler(): RAW bufid: 26 size: 39
[313657][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xC8
[313657][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x53
[313658][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x6D
[313658][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x6F
[313658][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x6B
[313659][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x65
[313659][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x53
[313660][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x6E
[313660][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x73
[313660][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x6F
[313661][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x72
[313661][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x2D
[313661][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x45
[313662][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x46
[313662][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x2D
[313662][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x33
[313663][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x11
[313663][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x02
[313663][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xC0
[313664][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[313665][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x01
[313665][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x02
[313665][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x04
[313666][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xFF
[313666][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x28
[313666][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[313667][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x20
[313667][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0x00
[313667][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xFF
[313668][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xFF
[313669][I][ZigbeeHandlers.cpp:65] zb_raw_cmd_handler(): 0xFF
[313670][I][ZigbeeHandlers.cpp:70] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x49d1, 0x49d1, 0x0, 0x0
[313670][I][ZigbeeHandlers.cpp:84] zb_raw_cmd_handler(): ----------------------------raw command not processed---------------------------------------------------------------
[314105][I][ZigbeeGateway.cpp:275] zbPrintDeviceDiscovery(): short_addr_req 18897
[314650][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1001) callback
[314650][V][ZigbeeHandlers.cpp:187] zb_cmd_write_attr_resp_handler(): Write attribute response: from address(0x49d1) src endpoint(1) to dst endpoint(1) cluster(0x0)
[314651][V][ZigbeeHandlers.cpp:194] zb_cmd_write_attr_resp_handler(): Write attribute response: status(134), cluster(0x0), attribute(0xffde)
[314677][I][ZigbeeGateway.cpp:209] Z2S_active_ep_req_cb(): Z2S active_ep_req: device address 18897, endpoints count 1
[314678][I][ZigbeeGateway.cpp:212] Z2S_active_ep_req_cb(): Endpont # 1, id 1
[315623][V][ZigbeeCore.cpp:412] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
[315626][I][ZigbeeGateway.cpp:228] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: device address 18897, endpoint # 1
[315627][I][ZigbeeGateway.cpp:229] Z2S_simple_desc_req_cb(): Z2S simple_desc_req: in clusters # 7, out clusters # 1
[315627][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 1, id 0
[315628][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 2, id 1
[315629][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 3, id 3
[315629][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 4, id 32
[315629][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 5, id 1280
[315630][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 6, id 1282
[315630][I][ZigbeeGateway.cpp:233] Z2S_simple_desc_req_cb(): In cluster # 7, id 2821
[315631][I][ZigbeeGateway.cpp:248] Z2S_simple_desc_req_cb(): Out cluster # 1, id 25
[316706][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[316718][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[316729][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[316740][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[316751][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[316761][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[316772][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[316781][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1004) callback
[319003][I][ZigbeeCore.cpp:386] esp_zb_app_signal_handler(): Network(0xf85f) is open for 180 seconds
[325672][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[325672][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[330679][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[330680][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[335689][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[335690][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[340694][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[340695][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[345702][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[345703][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[350711][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[350712][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[355721][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[355721][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[360730][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[360730][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[365739][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[365739][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[370746][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[370747][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[375756][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[375756][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[380764][I][ZigbeeHandlers.cpp:35] zb_action_handler(): Receive Zigbee action(0x1030) callback
[380764][W][ZigbeeHandlers.cpp:49] zb_action_handler(): Receive unhandled Zigbee action(0x1030) callback
[499004][I][ZigbeeCore.cpp:388] esp_zb_app_signal_handler(): Network(0xf85f) closed, devices joining not allowed.
Has thanked: 290 times
lukasz06 wrote: Wed Apr 02, 2025 6:59 pm Witam, poproszę o dodanie czujnika dymu https://inteligentnydom.co/bezpieczenst ... n-hs1sa-e/
Logi ze skanera
+BWNU
Czujnik ma klaster POLL - ciekawe czy będzie w związku z tym raportował stan regularnie?
trozwadowski89 wrote: Tue Apr 01, 2025 7:37 pm
trozwadowski89 wrote: Thu Mar 27, 2025 9:20 pm Mogę prosić o dodanie żarówki z IKEA?
Żarówka LED E14 806 lumenów z RGBW
https://www.ikea.com/pl/pl/p/tradfri-za ... -80547464/
Producent - IKEA of Sweden
Model urządzenia - TRADFRI bulb E14 CWS globe 806lm
+BWNU
lukasz06
vajera wrote: Wed Apr 02, 2025 9:43 pm
Logi ze skanera
+BWNU
Czujnik dodał się do Supli, jako czujnik binarny, zmieniłem na czujnik zalania, ale niestety nie reaguje na zmianę stanu, czyli dym,
Nie działa też przycisk testowy, za to stan baterii pokazuje od razu.
Czy coś jeszcze można zrobić? Bo jakby co mam 7 dni na oddanie go :).
lukasz06 wrote: Thu Apr 03, 2025 6:21 pm
Logi ze skanera
+BWNU
Przydałyby się logi z zadymiania i przycisku testowego.
Z moich źródeł wynika, że to jest prosty czujnik 0/1, bez pomiarów ilościowych czy możliwości ustawienia np. progu czułości.
EDIT A zareagował alarmem optycznym lub dźwiękowym?
lukasz06
Tak, alarm optyczny i dźwiękowy zadziałał, ale zadymienie musiało być dość duże.
Spróbuję jutro zebrać logi z zadymienia i przycisku testowego.
Been thanked: 31 times
lukasz06 wrote: Thu Apr 03, 2025 7:19 pm Tak, alarm optyczny i dźwiękowy zadziałał, ale zadymienie musiało być dość duże.
Pamiętaj, że aby poprawnie raportował stan, to musi być połączony z podstawą. Inaczej nie zadziała.
endrju_88 wrote: Fri Mar 28, 2025 9:27 pm Super !! Jeśli była by taka możliwość to proszę dodaj ten kanał. Oczywiście jeśli to nie problem. Teraz powiedzmy , że jest dość spora wilgotność wieczorem to stan kanału zmienia się na pada deszcz a tak nie jest. Jeśli wprowadzisz ten update to może w reakcjach będzie można ustawić próg zadziałania i reakcje na wysłanie powiadomienia czy pada deszcz ,czy leje deszcz itd.
Chciałem się za to zabrać, ale oświeciło mnie, że chyba będę wyważał otarte na oścież drzwi - przecież dla każdego kanału GPM możesz ustawić dowolną ilość reakcji w zależności od zmiany wartości, więc po co dublować te kanały?
Wchodzisz w np. kanał RAIN INTENSITY (w Cloud), dodajesz reakcję "gdy wartość > 3000" to zrób coś tam...
endrju_88
Has thanked: 3 times
Been thanked: 4 times
vajera wrote: Thu Apr 03, 2025 8:19 pm
No faktycznie dajmy sobie spokój z tym pomysłem. Chciałem móc zmieniać progi zadziałania zmiany ikony deszczu w tym czujniku ale to był by przerost formy nad treścią. Reakcjami mogę wysyłać powiadomienia , a czy się ikona zmieni wcześniej czy nie to już tam pikuś. Masz rację , lepiej nie dublować kanałów. Niech zostanie tak jak jest.
trozwadowski89
vajera wrote: Wed Apr 02, 2025 9:44 pm
+BWNU
Działa super - dziękuje
