Been thanked: 31 times
A to czujnik ruchu. Dokładnie taki (ZP01): https://pl.aliexpress.com/item/1005006627166271.html
00:34:32.085>
00:34:32.555> [685074][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x79be) is open for 180 seconds
00:34:32.555>
00:34:35.148> [687666][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
00:34:35.148>
00:34:35.148> [687668][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
00:34:35.148>
00:34:35.684> [688186][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x19f8)
00:34:35.684>
00:34:35.684> [688187][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
00:34:35.684>
00:34:35.871> [688304][I][ZigbeeGateway.cpp:87] find_Cb(): Found sensor
00:34:35.871>
00:34:35.871> [688304][D][ZigbeeGateway.cpp:96] find_Cb(): Sensor found: short address(0x19f8), endpoint(1)
00:34:35.871>
00:34:35.871> [688318][I][ZigbeeGateway.cpp:159] printJoinedDevices(): joined devices:
00:34:35.871>
00:34:35.871> [688318][I][ZigbeeGateway.cpp:162] printJoinedDevices(): Device on endpoint 1, short address: 0x19f8
00:34:35.871>
00:34:35.871> [688319][D][Zigbee_Gateway_2.ino:161] loop(): getJoinedDEvices 1 0 357913941 before
00:34:35.871>
00:34:35.871> [688320][D][Zigbee_Gateway_2.ino:164] loop(): getJoinedDEvices 1 0 357913941 after
00:34:35.871>
00:34:35.871> [688320][I][ZigbeeGateway.cpp:159] printJoinedDevices(): joined devices:
00:34:35.871>
00:34:36.550> [688419][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
00:34:36.550>
00:34:36.550> [688419][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19f8) src endpoint(1)
00:34:36.550> to dst endpoint(1) cluster(0x0)
00:34:36.550>
00:34:36.550> [688420][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
00:34:36.550> 4), type(0x42), value(16)
00:34:36.550>
00:34:36.550> [688421][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_lf56vpxj"
00:34:36.550>
00:34:36.550> [688321][I][Zigbee_Gateway_2.ino:167] loop(): manufacturer _TZ3000_lf56vpxj
00:34:36.550>
00:34:36.550> [688539][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
00:34:36.550>
00:34:36.550> [688539][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x19f8) src endpoint(1)
00:34:36.550>
00:34:36.550> [688540][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
00:34:36.550> 5), type(0x42), value(6)
00:34:36.550>
00:34:36.550> [688541][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0202"
00:34:36.550>
00:34:36.550> [688542][I][Zigbee_Gateway_2.ino:169] loop(): model TS0202
00:34:36.550>
00:34:36.550> [688542][D][Zigbee_Gateway_2.ino:186] loop(): Unknown model TS0202, no binding is possible
00:34:36.550>
00:34:37.693> [689606][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
00:34:37.693>
00:34:37.693> [689690][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x79be) is open for 180 seconds
00:34:37.693>
00:34:48.141> [700641][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:34:48.141>
00:34:48.141> [700641][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x19f8) src endpoint(1) to dst e
00:34:48.141> ndpoint(1) cluster(0x500)
00:34:48.141>
00:34:48.141> [700642][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 1280
00:34:48.141>
00:34:48.141> [700642][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 61441
00:34:48.141>
00:34:48.578> [700765][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:34:48.578>
00:34:48.578> [700765][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x19f8) src endpoint(1) to dst e
00:34:48.578> ndpoint(1) cluster(0x500)
00:34:48.578>
00:34:48.578> [700766][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 1280
00:34:48.578>
00:34:48.578> [700766][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 19
00:34:48.578>
00:35:13.063> -----------------------------------------
00:35:13.063> Monitoring stopped (02.01.2025 00:35:13).
I jeszcze gniazdko, takie (aukcja przykładowa): https://pl.aliexpress.com/item/1005007003484197.html
Mam wersję 20A (w co oczywiście mało wierzę), ale kosztowało mnie niecałe 11 zł (choice) i o dziwo (po kalibracji) pokazuje zużycie prądu tak samo jak SP111.
00:41:50.425> [1122902][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
00:41:50.426>
00:41:50.426> [1122905][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
00:41:50.426>
00:41:50.694> [1122983][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x7cb5)
00:41:50.694>
00:41:50.694> [1122984][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x8e
00:41:50.694>
00:41:50.694> [1122989][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x7cb5)
00:41:50.694>
00:41:50.694> [1122989][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x8e
00:41:50.694>
00:41:50.694> [1123072][I][ZigbeeGateway.cpp:87] find_Cb(): Found sensor
00:41:50.694>
00:41:50.694> [1123073][D][ZigbeeGateway.cpp:96] find_Cb(): Sensor found: short address(0x7cb5), endpoint(1)
00:41:50.694>
00:41:50.694> [1123078][I][ZigbeeGateway.cpp:159] printJoinedDevices(): joined devices:
00:41:50.694>
00:41:50.694> [1123078][I][ZigbeeGateway.cpp:162] printJoinedDevices(): Device on endpoint 1, short address: 0x7cb5
00:41:50.694>
00:41:50.694> [1123079][D][Zigbee_Gateway_2.ino:161] loop(): getJoinedDEvices 1 0 357913941 before
00:41:50.694>
00:41:50.694> [1123079][D][Zigbee_Gateway_2.ino:164] loop(): getJoinedDEvices 1 0 357913941 after
00:41:50.694>
00:41:50.694> [1123080][I][ZigbeeGateway.cpp:159] printJoinedDevices(): joined devices:
00:41:50.694>
00:41:50.694> [1123095][I][ZigbeeGateway.cpp:87] find_Cb(): Found sensor
00:41:50.694>
00:41:50.694> [1123095][D][ZigbeeGateway.cpp:96] find_Cb(): Sensor found: short address(0x7cb5), endpoint(1)
00:41:50.694>
00:41:50.694> [1123140][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
00:41:50.694>
00:41:50.694> [1123141][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x7cb5) src endpoint(1)
00:41:50.694>  to dst endpoint(1) cluster(0x0)
00:41:50.694>
00:41:50.694> [1123141][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0
00:41:50.694> x4), type(0x42), value(16)
00:41:50.694>
00:41:50.694> [1123142][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_5f43h46b"
00:41:50.694>
00:41:50.694> [1123080][I][Zigbee_Gateway_2.ino:167] loop(): manufacturer _TZ3000_5f43h46b
00:41:50.694>
00:41:52.284> [1123191][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
00:41:52.284>
00:41:52.284> [1123191][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x7cb5) src endpoint(1)
00:41:52.284>  to dst endpoint(1) cluster(0x0)
00:41:52.284>
00:41:52.284> [1123192][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0
00:41:52.284> x5), type(0x42), value(6)
00:41:52.284>
00:41:52.284> [1123192][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS011F"
00:41:52.284>
00:41:52.284> [1123194][I][Zigbee_Gateway_2.ino:169] loop(): model TS011F
00:41:52.284>
00:41:52.284> [1123195][D][Zigbee_Gateway_2.ino:186] loop(): Unknown model TS011F, no binding is possible
00:41:52.284>
00:41:52.285> [1123195][D][Zigbee_Gateway_2.ino:161] loop(): getJoinedDEvices 1 0 357913941 before
00:41:52.285>
00:41:52.285> [1123196][D][Zigbee_Gateway_2.ino:164] loop(): getJoinedDEvices 1 0 357913941 after
00:41:52.285>
00:41:52.285> [1123196][I][ZigbeeGateway.cpp:159] printJoinedDevices(): joined devices:
00:41:52.285>
00:41:52.285> [1123242][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
00:41:52.285>
00:41:52.285> [1123242][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x7cb5) src endpoint(1)
00:41:52.285>  to dst endpoint(1) cluster(0x0)
00:41:52.285>
00:41:52.285> [1123243][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0
00:41:52.285> x4), type(0x42), value(16)
00:41:52.285>
00:41:52.285> [1123244][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_5f43h46b"
00:41:52.285>
00:41:52.285> [1123197][I][Zigbee_Gateway_2.ino:167] loop(): manufacturer _TZ3000_5f43h46b
00:41:52.285>
00:41:52.285> [1123301][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
00:41:52.285>
00:41:52.285> [1123301][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x7cb5) src endpoint(1)
00:41:52.285>
00:41:52.285> [1123302][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0
00:41:52.285> x5), type(0x42), value(6)
00:41:52.285>
00:41:52.285> [1123303][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS011F"
00:41:52.285>
00:41:52.285> [1123304][I][Zigbee_Gateway_2.ino:169] loop(): model TS011F
00:41:52.285>
00:41:52.285> [1123305][D][Zigbee_Gateway_2.ino:186] loop(): Unknown model TS011F, no binding is possible
00:41:52.285>
00:41:52.285> [1123405][I][ZigbeeGateway.cpp:159] printJoinedDevices(): joined devices:
00:41:52.285>
00:41:52.285> [1123530][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
00:41:52.285>
00:41:52.285> [1123609][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x79be) is open for 180 seconds
00:41:52.285>
00:41:56.336> [1128815][I][ZigbeeGateway.cpp:150] printGatewayDevices(): gateway devices:
00:41:56.337>
00:41:56.337> [1128815][I][ZigbeeGateway.cpp:153] printGatewayDevices(): Device on endpoint 1, short address: 0xf20c
00:41:56.337>
00:41:56.337> [1128816][I][ZigbeeGateway.cpp:159] printJoinedDevices(): joined devices:
00:41:56.337>
00:41:56.801> [1129284][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:41:56.801>
00:41:56.802> [1129285][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x7cb5) src endpoint(1) to dst
00:41:56.802> endpoint(1) cluster(0x6)
00:41:56.802>
00:41:56.802> [1129285][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 6
00:41:56.802>
00:41:56.802> [1129286][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 0
00:41:56.802>
00:41:57.376> [1129291][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:41:57.376>
00:41:57.376> [1129291][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x7cb5) src endpoint(1) to dst
00:41:57.376> endpoint(1) cluster(0xe001)
00:41:57.377>
00:41:57.377> [1129292][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 57345
00:41:57.377>
00:41:57.377> [1129292][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 53264
00:41:57.377>
00:41:57.377> [1129299][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
00:41:57.377>
00:41:57.377> [1129300][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x7cb5) src endpoint(1) to dst
00:41:57.377> endpoint(1) cluster(0xe001)
00:41:57.377>
00:41:57.377> [1129300][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 57345
00:41:57.377>
00:41:57.377> [1129301][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 53296
00:41:57.377>
00:42:00.957> [1133441][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
00:42:00.958>
00:42:56.386> [1188867][I][ZigbeeGateway.cpp:150] printGatewayDevices(): gateway devices:
00:42:56.386>
00:42:56.386> [1188867][I][ZigbeeGateway.cpp:153] printGatewayDevices(): Device on endpoint 1, short address: 0xf20c
00:42:56.386>
00:42:56.386> [1188868][I][ZigbeeGateway.cpp:159] printJoinedDevices(): joined devices:
00:42:56.386>
00:43:01.684> -----------------------------------------
A na koniec czujnik temperatury i wilgotności. Taki: https://pl.aliexpress.com/item/1005006469579613.html
01:02:16.216> [ 18235][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
01:02:16.216>
01:02:16.216> [ 18239][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
01:02:16.216>
01:02:16.735> [ 18757][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x4e41)
01:02:16.735>
01:02:16.735> [ 18757][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
01:02:16.735>
01:02:16.998> [ 18873][I][ZigbeeGateway.cpp:87] find_Cb(): Found sensor
01:02:16.998>
01:02:16.998> [ 18873][D][ZigbeeGateway.cpp:96] find_Cb(): Sensor found: short address(0x4e41), endpoint(1)
01:02:16.998>
01:02:16.998> [ 18913][I][ZigbeeGateway.cpp:159] printJoinedDevices(): joined devices:
01:02:16.998>
01:02:16.998> [ 18913][I][ZigbeeGateway.cpp:162] printJoinedDevices(): Device on endpoint 1, short address: 0x4e41
01:02:16.998>
01:02:16.998> [ 18914][D][Zigbee_Gateway_2.ino:161] loop(): getJoinedDEvices 1 0 357913941 before
01:02:16.998>
01:02:16.998> [ 18914][D][Zigbee_Gateway_2.ino:164] loop(): getJoinedDEvices 1 0 357913941 after
01:02:16.998>
01:02:16.998> [ 18915][I][ZigbeeGateway.cpp:159] printJoinedDevices(): joined devices:
01:02:16.998>
01:02:16.998> [ 18989][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
01:02:16.998>
01:02:16.998> [ 18989][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x4e41) src endpoint(1)
01:02:16.998> to dst endpoint(1) cluster(0x0)
01:02:16.998>
01:02:16.998> [ 18990][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
01:02:16.998> 4), type(0x42), value(16)
01:02:16.998>
01:02:16.998> [ 18991][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_fllyghyj"
01:02:16.998>
01:02:16.998> [ 18915][I][Zigbee_Gateway_2.ino:167] loop(): manufacturer _TZ3000_fllyghyj
01:02:16.998>
01:02:17.943> [ 19108][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
01:02:17.943>
01:02:17.943> [ 19108][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x4e41) src endpoint(1)
01:02:17.943> to dst endpoint(1) cluster(0x0)
01:02:17.943>
01:02:17.943> [ 19109][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
01:02:17.943> 5), type(0x42), value(6)
01:02:17.943>
01:02:17.943> [ 19110][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0201"
01:02:17.943>
01:02:17.943> [ 19111][I][Zigbee_Gateway_2.ino:169] loop(): model TS0201
01:02:17.943>
01:02:17.943> [ 19111][D][Zigbee_Gateway_2.ino:186] loop(): Unknown model TS0201, no binding is possible
01:02:17.943>
01:02:18.428> [ 20178][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
01:02:18.428>
01:02:18.428> [ 20257][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x79be) is open for 180 seconds
01:02:18.428>
01:02:23.393> [ 25401][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
01:02:23.393>
01:02:23.393> [ 25401][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e41) src endpoint(1) to dst e
01:02:23.393> ndpoint(1) cluster(0x402)
01:02:23.393>
01:02:23.393> [ 25402][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 1026
01:02:23.393>
01:02:23.393> [ 25402][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 0
01:02:23.393>
01:02:23.711> [ 25526][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
01:02:23.711>
01:02:23.711> [ 25526][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e41) src endpoint(1) to dst e
01:02:23.711> ndpoint(1) cluster(0x405)
01:02:23.711>
01:02:23.711> [ 25527][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 1029
01:02:23.711>
01:02:23.711> [ 25527][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 0
01:02:23.711>
01:02:28.387> [ 30406][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
01:02:28.387>
01:02:28.387> [ 30406][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e41) src endpoint(1) to dst e
01:02:28.387> ndpoint(1) cluster(0x402)
01:02:28.387>
01:02:28.387> [ 30407][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 1026
01:02:28.387>
01:02:28.387> [ 30407][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 0
01:02:28.387>
01:02:28.812> [ 30530][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
01:02:28.812>
01:02:28.812> [ 30530][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e41) src endpoint(1) to dst e
01:02:28.812> ndpoint(1) cluster(0x405)
01:02:28.812>
01:02:28.812> [ 30531][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 1029
01:02:28.812>
01:02:28.812> [ 30531][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 0
01:02:28.812>
01:02:33.387> [ 35407][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
01:02:33.387>
01:02:33.387> [ 35408][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e41) src endpoint(1) to dst e
01:02:33.387> ndpoint(1) cluster(0x402)
01:02:33.387>
01:02:33.387> [ 35409][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 1026
01:02:33.387>
01:02:33.387> [ 35409][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 0
01:02:33.387>
01:02:33.772> [ 35533][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
01:02:33.772>
01:02:33.772> [ 35533][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e41) src endpoint(1) to dst e
01:02:33.772> ndpoint(1) cluster(0x405)
01:02:33.772>
01:02:33.772> [ 35534][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 1029
01:02:33.772>
01:02:33.772> [ 35534][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 0
01:02:33.772>
01:02:38.392> [ 40410][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
01:02:38.392>
01:02:38.392> [ 40411][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e41) src endpoint(1) to dst e
01:02:38.392> ndpoint(1) cluster(0x402)
01:02:38.392>
01:02:38.392> [ 40411][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 1026
01:02:38.392>
01:02:38.392> [ 40412][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 0
01:02:38.392>
01:02:38.760> [ 40534][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
01:02:38.760>
01:02:38.760> [ 40535][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e41) src endpoint(1) to dst e
01:02:38.760> ndpoint(1) cluster(0x405)
01:02:38.760>
01:02:38.760> [ 40535][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 1029
01:02:38.760>
01:02:38.760> [ 40536][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 0
01:02:38.760>
01:02:43.390> [ 45412][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
01:02:43.391>
01:02:43.391> [ 45413][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e41) src endpoint(1) to dst e
01:02:43.391> ndpoint(1) cluster(0x402)
01:02:43.391>
01:02:43.391> [ 45413][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 1026
01:02:43.391>
01:02:43.391> [ 45414][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 0
01:02:43.391>
01:02:43.778> [ 45537][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
01:02:43.778>
01:02:43.778> [ 45538][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e41) src endpoint(1) to dst e
01:02:43.778> ndpoint(1) cluster(0x405)
01:02:43.778>
01:02:43.778> [ 45538][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 1029
01:02:43.778>
01:02:43.778> [ 45539][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 0
01:02:43.778>
01:02:48.404> [ 50417][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
01:02:48.404>
01:02:48.404> [ 50418][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e41) src endpoint(1) to dst e
01:02:48.404> ndpoint(1) cluster(0x402)
01:02:48.404>
01:02:48.404> [ 50418][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 1026
01:02:48.404>
01:02:48.404> [ 50419][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 0
01:02:48.404>
01:02:48.750> [ 50541][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
01:02:48.750>
01:02:48.750> [ 50542][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e41) src endpoint(1) to dst e
01:02:48.750> ndpoint(1) cluster(0x405)
01:02:48.750>
01:02:48.750> [ 50543][I][ZigbeeGateway.cpp:170] zbAttributeRead(): cluster_id 1029
01:02:48.750>
01:02:48.750> [ 50543][I][ZigbeeGateway.cpp:171] zbAttributeRead(): attribute->id 0
01:02:48.750>
01:02:51.118> -----------------------------------------
01:02:51.118> Monitoring stopped (02.01.2025 01:02:51).
Mam jeszcze pod ręką czujnik zalania, głowicę termostatyczną i przycisk z pokrętłem. I kilka innych rzeczy mogę sprawdzić (ale dostęp do nich mam utrudniony). Myślę też, że poczekam jak ustalimy gdzie to wrzucać, bo może tego trochę być...
lukasz06
Has thanked: 45 times
Been thanked: 21 times
Możecie podpowiedzieć czy w samym Arduino należy coś odkomentować lub, wpisac?
Program wgrałem ale logi tylko takie: 08:20:29.960 -> ESP-ROM:esp32c6-20220919
08:20:29.960 -> Build:Sep 19 2022
08:20:29.960 -> rst:0xc (SW_CPU),boot:0x1e (SPI_FAST_FLASH_BOOT)
08:20:29.960 -> Saved PC:0x4001975a
08:20:29.960 -> SPIWP:0xee
08:20:29.960 -> mode:DIO, clock div:2
08:20:29.960 -> load:0x4086c410,len:0xcf8
08:20:29.960 -> load:0x4086e610,len:0x2e30
08:20:29.960 -> load:0x40875728,len:0x113c
08:20:29.960 -> entry 0x4086c410
Has thanked: 289 times
lukasz06 wrote: Thu Jan 02, 2025 7:28 am Możecie podpowiedzieć czy w samym Arduino należy coś odkomentować lub, wpisac?
zrób screen ustawień płytki
@Zibi_007 - sprawdź w wolnej chwili, co teraz wypluwa ten przycisk x4 (sprawdź każdy z przycisków, proszę), czujnik ruchu i ten od temperatury.
Przy okazji - podobno ten przycisk 4x sprawia problemy przy słabych bateriach a on wysyłał jakieś atrybuty dla klastra 0x1 (power management).
EDIT - naniosłem jeszcze kolejne poprawki - również w kwestii tego gniazdka z pomiarem.
Daj znać czy się kompiluje bo nadal wrzucam to z komórki.
lukasz06
Ja zaktualizowałem, lecz teraz się nie kompiluje. Poniżej screen ustawień płytki
vajera wrote: Thu Jan 02, 2025 9:00 pm @Zibi_007 - sprawdź w wolnej chwili, co teraz wypluwa ten przycisk x4 (sprawdź każdy z przycisków, proszę), czujnik ruchu i ten od temperatury.
Kod się nie kompiluje, wypluwa błędy:
C:\Users\xxx\Documents\Arduino\Zigbee_Gateway_2\Zigbee_Gateway_2.ino: In function 'void loop()':
C:\Users\xxx\Documents\Arduino\Zigbee_Gateway_2\Zigbee_Gateway_2.ino:171:38: error: expected ';' before '{' token
  171 |       strcmp(zbd_model_name,"TS0201") {
C:\Users\xxx\Documents\Arduino\Zigbee_Gateway_2\Zigbee_Gateway_2.ino:175:9: error: expected primary-expression before 'else'
  175 |       } else
C:\Users\xxx\Documents\Arduino\Zigbee_Gateway_2\Zigbee_Gateway_2.ino:175:8: error: expected ')' before 'else'
  175 |       } else
C:\Users\xxx\Documents\Arduino\Zigbee_Gateway_2\Zigbee_Gateway_2.ino:170:10: note: to match this '('
  170 |       if ((strcmp(zbd_model_name,"ZigbeeTempSensor") == 0)||
exit status 1
Compilation error: expected ';' before '{' token
Poprawiłem linię 171 na:
          strcmp(zbd_model_name,"TS0201") ==0) {
Skompilowałem. Uruchomiłem. Sprawdziłem przycisk. Może i baterie są słabe, nie mam pod ręką teraz nowych. W każdym razie takie coś teraz loguje:
03:58:18.406> pp_signal_handler(): Network(0x1880) is open for 180 seconds
03:58:18.406>
03:58:18.406> [  4432][V][ZigbeeCore.cpp:200] openNetwork(): Opening network for joining for 180 seconds
03:58:18.406>
03:58:18.406> [  4899][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x1880) is open for 180 seconds
03:58:18.406>
03:58:26.102> [ 17804][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:58:26.102>
03:58:26.102> [ 17805][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:58:26.102> ize(1)
03:58:26.102>
03:58:33.882> [ 25586][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Leave Indication (0x13), status: ESP_OK
03:58:33.882>
03:58:37.693> [ 29393][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
03:58:37.693>
03:58:37.693> [ 29395][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
03:58:37.693>
03:58:38.208> [ 29914][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0xa212)
03:58:38.208>
03:58:38.208> [ 29914][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
03:58:38.208>
03:58:38.725> [ 30420][I][ZigbeeGateway.cpp:91] find_Cb(): Found sensor
03:58:38.725>
03:58:38.725> [ 30420][D][ZigbeeGateway.cpp:100] find_Cb(): Sensor found: short address(0xa212), endpoint(1)
03:58:38.725>
03:58:38.826> [ 30502][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
03:58:38.826>
03:58:38.826> [ 30503][I][ZigbeeGateway.cpp:166] printJoinedDevices(): Device on endpoint 1, short address: 0xa212
03:58:38.826>
03:58:38.826> [ 30503][D][Zigbee_Gateway_2.ino:161] loop(): getJoinedDEvices 1 0 357913941 before
03:58:38.827>
03:58:38.827> [ 30504][D][Zigbee_Gateway_2.ino:164] loop(): getJoinedDEvices 1 0 357913941 after
03:58:38.827>
03:58:38.827> [ 30504][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
03:58:38.827>
03:58:39.228> [ 30922][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
03:58:39.228>
03:58:39.228> [ 30922][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xa212) src endpoint(1)
03:58:39.228> to dst endpoint(1) cluster(0x0)
03:58:39.228>
03:58:39.228> [ 30923][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
03:58:39.228> 4), type(0x42), value(16)
03:58:39.228>
03:58:39.228> [ 30924][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_wkai4ga5"
03:58:39.228>
03:58:39.228> [ 30505][I][Zigbee_Gateway_2.ino:167] loop(): manufacturer _TZ3000_wkai4ga5
03:58:39.228>
03:58:39.725> [ 31426][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
03:58:39.725>
03:58:39.725> [ 31427][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xa212) src endpoint(1)
03:58:39.725> to dst endpoint(1) cluster(0x0)
03:58:39.725>
03:58:39.725> [ 31427][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
03:58:39.725> 5), type(0x42), value(6)
03:58:39.725>
03:58:39.725> [ 31428][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0044"
03:58:39.725>
03:58:39.725> [ 31430][I][Zigbee_Gateway_2.ino:169] loop(): model TS0044
03:58:39.725>
03:58:39.725> [ 31431][D][ZigbeeGateway.cpp:112] bindDeviceCluster(): Request sensor to bind us
03:58:39.725>
03:58:39.725> [ 31435][V][ZigbeeGateway.cpp:73] bindCb(): Binding success (ZC side)
03:58:39.725>
03:58:39.725> [ 31435][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
03:58:39.725>
03:58:40.168> [ 31524][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
03:58:40.168>
03:58:40.168> [ 31534][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
03:58:40.168>
03:58:40.317> [ 32020][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x1880) is open for 180 seconds
03:58:40.317>
03:58:48.635> [ 40335][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
03:58:48.635>
03:58:48.635> [ 40336][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0xa212) src endpoint(1) to dst e
03:58:48.635> ndpoint(1) cluster(0x1)
03:58:48.635>
03:58:48.635> [ 40337][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1
03:58:48.635>
03:58:48.635> [ 40337][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 33
03:58:48.635>
03:58:48.635> [ 40337][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
03:58:48.635>
03:58:48.635> [ 40338][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0xa212) src endpoint(1) to dst e
03:58:48.635>
03:58:48.635> [ 40338][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1
03:58:48.635>
03:58:48.635> [ 40339][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 32
03:58:48.635>
03:58:58.664> [ 50372][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
03:58:58.664>
03:58:58.664> [ 50372][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0xa212) src endpoint(1) to dst e
03:58:58.664> ndpoint(1) cluster(0x1)
03:58:58.664>
03:58:58.664> [ 50373][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1
03:58:58.664>
03:58:58.664> [ 50373][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 33
03:58:58.664>
03:58:58.664> [ 50374][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
03:58:58.664>
03:58:58.941> [ 50374][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0xa212) src endpoint(1) to dst e
03:58:58.941> ndpoint(1) cluster(0x1)
03:58:58.941>
03:58:58.941> [ 50375][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1
03:58:58.941>
03:58:58.941> [ 50375][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 32
03:58:58.941>
03:59:05.864> [ 57569][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:05.864>
03:59:05.864> [ 57569][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:05.864> ize(1)
03:59:05.864>
03:59:08.977> [ 60674][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
03:59:08.977>
03:59:08.977> [ 60674][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0xa212) src endpoint(1) to dst e
03:59:08.977> ndpoint(1) cluster(0x1)
03:59:08.977>
03:59:08.977> [ 60675][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1
03:59:08.977>
03:59:08.977> [ 60675][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 33
03:59:08.977>
03:59:08.977> [ 60676][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
03:59:08.977>
03:59:08.977> [ 60676][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0xa212) src endpoint(1) to dst e
03:59:08.977>
03:59:08.977> [ 60677][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1
03:59:08.977>
03:59:08.977> [ 60677][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 32
03:59:08.977>
03:59:10.808> [ 62515][I][ZigbeeGateway.cpp:154] printGatewayDevices(): gateway devices:
03:59:10.808>
03:59:10.808> [ 62515][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x5a7d
03:59:10.808>
03:59:10.808> [ 62516][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0xa212
03:59:10.808>
03:59:10.808> [ 62517][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
03:59:10.808>
03:59:18.928> [ 70636][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
03:59:18.928>
03:59:18.928> [ 70637][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0xa212) src endpoint(1) to dst e
03:59:18.928> ndpoint(1) cluster(0x1)
03:59:18.928>
03:59:18.928> [ 70637][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1
03:59:18.928>
03:59:18.928> [ 70638][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 33
03:59:18.929>
03:59:18.929> [ 70638][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
03:59:18.929>
03:59:19.200> [ 70638][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0xa212) src endpoint(1) to dst e
03:59:19.200> ndpoint(1) cluster(0x1)
03:59:19.200>
03:59:19.200> [ 70639][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1
03:59:19.200>
03:59:19.200> [ 70639][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 32
03:59:19.200>
03:59:25.759> [ 77467][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:25.759>
03:59:25.759> [ 77468][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:25.759> ize(1)
03:59:25.759>
03:59:26.272> [ 77967][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:26.272>
03:59:26.272> [ 77968][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:26.272> ize(1)
03:59:26.272>
03:59:26.772> [ 78467][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:26.772>
03:59:26.772> [ 78468][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:26.772> ize(1)
03:59:26.772>
03:59:31.385> [ 83089][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:31.385>
03:59:31.385> [ 83089][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:31.385> ize(1)
03:59:31.385>
03:59:31.881> [ 83590][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:31.881>
03:59:31.881> [ 83590][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:31.881> ize(1)
03:59:31.881>
03:59:33.239> [ 84941][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:33.239>
03:59:33.239> [ 84941][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:33.239> ize(1)
03:59:33.239>
03:59:34.131> [ 85838][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:34.131>
03:59:34.131> [ 85838][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:34.131> ize(1)
03:59:34.131>
03:59:37.669> [ 89378][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:37.669>
03:59:37.669> [ 89379][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:37.669> ize(1)
03:59:37.669>
03:59:38.181> [ 89879][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:38.181>
03:59:38.181> [ 89880][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:38.181> ize(1)
03:59:38.181>
03:59:42.988> [ 94695][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:42.988>
03:59:42.988> [ 94696][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:42.988> ize(1)
03:59:42.988>
03:59:43.498> [ 95195][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:43.498>
03:59:43.498> [ 95196][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:43.498> ize(1)
03:59:43.498>
03:59:43.993> [ 95698][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:43.993>
03:59:43.993> [ 95699][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:43.993> ize(1)
03:59:43.993>
03:59:44.488> [ 96198][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:44.488>
03:59:44.488> [ 96198][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:44.488> ize(1)
03:59:44.488>
03:59:48.648> [100350][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:48.648>
03:59:48.648> [100350][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:48.648> ize(1)
03:59:48.648>
03:59:49.152> [100850][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x0) callback
03:59:49.152>
03:59:49.152> [100850][V][ZigbeeHandlers.cpp:42] zb_attribute_set_handler(): Received message: endpoint(1), cluster(0x6), attribute(0x0), data s
03:59:49.152> ize(1)
03:59:49.152>
Czujnik temperatury i wilgotności:
04:09:57.230> [  3518][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x0655) is open for 180 seconds
04:09:57.230>
04:09:57.230> [  3520][I][ZigbeeCore.cpp:276] esp_zb_app_signal_handler(): Network steering started
04:09:57.230>
04:10:38.459> [ 45962][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
04:10:38.459>
04:10:38.459> [ 45964][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
04:10:38.459>
04:10:38.991> [ 46484][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x6b4c)
04:10:38.991>
04:10:38.991> [ 46485][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x80
04:10:38.991>
04:10:39.148> [ 46602][I][ZigbeeGateway.cpp:91] find_Cb(): Found sensor
04:10:39.148>
04:10:39.148> [ 46602][D][ZigbeeGateway.cpp:100] find_Cb(): Sensor found: short address(0x6b4c), endpoint(1)
04:10:39.148>
04:10:39.148> [ 46630][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
04:10:39.148>
04:10:39.149> [ 46631][I][ZigbeeGateway.cpp:166] printJoinedDevices(): Device on endpoint 1, short address: 0x6b4c
04:10:39.149>
04:10:39.149> [ 46631][D][Zigbee_Gateway_2.ino:161] loop(): getJoinedDEvices 1 0 357913941 before
04:10:39.149>
04:10:39.149> [ 46632][D][Zigbee_Gateway_2.ino:164] loop(): getJoinedDEvices 1 0 357913941 after
04:10:39.149>
04:10:39.149> [ 46633][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
04:10:39.149>
04:10:39.749> [ 46723][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
04:10:39.749>
04:10:39.749> [ 46723][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x6b4c) src endpoint(1)
04:10:39.749> to dst endpoint(1) cluster(0x0)
04:10:39.749>
04:10:39.749> [ 46724][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
04:10:39.749> 4), type(0x42), value(16)
04:10:39.749>
04:10:39.749> [ 46725][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_fllyghyj"
04:10:39.749>
04:10:39.749> [ 46633][I][Zigbee_Gateway_2.ino:167] loop(): manufacturer _TZ3000_fllyghyj
04:10:39.749>
04:10:39.749> [ 46838][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
04:10:39.749>
04:10:39.749> [ 46839][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x6b4c) src endpoint(1)
04:10:39.749>
04:10:39.749> [ 46840][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
04:10:39.749> 5), type(0x42), value(6)
04:10:39.749>
04:10:39.749> [ 46840][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS0201"
04:10:39.750>
04:10:39.750> [ 46841][I][Zigbee_Gateway_2.ino:169] loop(): model TS0201
04:10:39.750>
04:10:39.750> [ 46842][D][ZigbeeGateway.cpp:112] bindDeviceCluster(): Request sensor to bind us
04:10:39.750>
04:10:39.750> [ 46845][V][ZigbeeGateway.cpp:73] bindCb(): Binding success (ZC side)
04:10:39.750>
04:10:39.750> [ 46845][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
04:10:39.750>
04:10:39.750> [ 46970][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
04:10:39.750>
04:10:41.231> [ 47915][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
04:10:41.231>
04:10:41.231> [ 47986][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x0655) is open for 180 seconds
04:10:41.231>
04:10:45.648> [ 53142][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:10:45.648>
04:10:45.649> [ 53143][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:10:45.649> ndpoint(1) cluster(0x402)
04:10:45.649>
04:10:45.649> [ 53143][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1026
04:10:45.649>
04:10:45.649> [ 53144][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:10:45.649>
04:10:46.001> [ 53267][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:10:46.001>
04:10:46.001> [ 53267][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:10:46.001> ndpoint(1) cluster(0x405)
04:10:46.001>
04:10:46.002> [ 53268][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1029
04:10:46.002>
04:10:46.002> [ 53268][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:10:46.002>
04:10:50.556> [ 58053][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:10:50.556>
04:10:50.556> [ 58053][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:10:50.556> ndpoint(1) cluster(0x402)
04:10:50.556>
04:10:50.556> [ 58054][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1026
04:10:50.556>
04:10:50.556> [ 58054][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:10:50.556>
04:10:50.907> [ 58177][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:10:50.907>
04:10:50.907> [ 58178][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:10:50.907> ndpoint(1) cluster(0x405)
04:10:50.907>
04:10:50.907> [ 58178][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1029
04:10:50.907>
04:10:50.907> [ 58179][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:10:50.907>
04:10:53.180> [ 60680][I][ZigbeeGateway.cpp:154] printGatewayDevices(): gateway devices:
04:10:53.180>
04:10:53.180> [ 60681][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x6b4c
04:10:53.180>
04:10:53.180> [ 60681][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
04:10:53.180>
04:10:55.553> [ 63055][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:10:55.553>
04:10:55.553> [ 63056][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:10:55.553> ndpoint(1) cluster(0x402)
04:10:55.553>
04:10:55.553> [ 63056][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1026
04:10:55.553>
04:10:55.553> [ 63057][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:10:55.553>
04:10:55.792> [ 63180][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:10:55.792>
04:10:55.792> [ 63181][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:10:55.792> ndpoint(1) cluster(0x405)
04:10:55.792>
04:10:55.792> [ 63182][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1029
04:10:55.792>
04:10:55.792> [ 63182][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:10:55.792>
04:11:00.557> [ 68059][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:00.557>
04:11:00.557> [ 68060][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:00.557> ndpoint(1) cluster(0x402)
04:11:00.557>
04:11:00.557> [ 68061][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1026
04:11:00.557>
04:11:00.557> [ 68061][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:00.557>
04:11:00.789> [ 68184][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:00.789>
04:11:00.789> [ 68184][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:00.789> ndpoint(1) cluster(0x405)
04:11:00.789>
04:11:00.789> [ 68185][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1029
04:11:00.789>
04:11:00.789> [ 68185][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:00.789>
04:11:05.571> [ 73063][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:05.571>
04:11:05.571> [ 73063][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:05.571> ndpoint(1) cluster(0x402)
04:11:05.571>
04:11:05.571> [ 73064][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1026
04:11:05.571>
04:11:05.571> [ 73064][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:05.571>
04:11:05.804> [ 73187][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:05.805>
04:11:05.805> [ 73187][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:05.805> ndpoint(1) cluster(0x405)
04:11:05.805>
04:11:05.805> [ 73188][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1029
04:11:05.805>
04:11:05.805> [ 73188][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:05.805>
04:11:10.573> [ 78067][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:10.573>
04:11:10.573> [ 78067][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:10.573> ndpoint(1) cluster(0x402)
04:11:10.573>
04:11:10.573> [ 78068][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1026
04:11:10.573>
04:11:10.573> [ 78068][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:10.573>
04:11:10.805> [ 78191][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:10.805>
04:11:10.805> [ 78191][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:10.805> ndpoint(1) cluster(0x405)
04:11:10.805>
04:11:10.805> [ 78192][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1029
04:11:10.805>
04:11:10.805> [ 78192][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:10.805>
04:11:15.567> [ 83071][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:15.567>
04:11:15.567> [ 83072][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:15.567> ndpoint(1) cluster(0x402)
04:11:15.567>
04:11:15.567> [ 83072][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1026
04:11:15.567>
04:11:15.745> [ 83073][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:15.745>
04:11:15.745> [ 83196][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:15.745>
04:11:15.745> [ 83197][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:15.745> ndpoint(1) cluster(0x405)
04:11:15.745>
04:11:15.745> [ 83198][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1029
04:11:15.745>
04:11:15.745> [ 83198][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:15.745>
04:11:20.584> [ 88075][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:20.584>
04:11:20.584> [ 88076][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:20.584> ndpoint(1) cluster(0x402)
04:11:20.584>
04:11:20.584> [ 88077][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1026
04:11:20.584>
04:11:20.584> [ 88077][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:20.584>
04:11:20.807> [ 88200][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:20.807>
04:11:20.807> [ 88201][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:20.807> ndpoint(1) cluster(0x405)
04:11:20.807>
04:11:20.807> [ 88202][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1029
04:11:20.807>
04:11:20.807> [ 88202][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:20.807>
04:11:25.573> [ 93078][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:25.573>
04:11:25.573> [ 93078][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:25.649> ndpoint(1) cluster(0x402)
04:11:25.649>
04:11:25.649> [ 93079][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1026
04:11:25.649>
04:11:25.649> [ 93079][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:25.649>
04:11:25.800> [ 93203][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:25.800>
04:11:25.800> [ 93203][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:25.800> ndpoint(1) cluster(0x405)
04:11:25.800>
04:11:25.800> [ 93204][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1029
04:11:25.800>
04:11:25.800> [ 93204][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:25.800>
04:11:30.583> [ 98082][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:30.583>
04:11:30.583> [ 98082][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:30.583> ndpoint(1) cluster(0x402)
04:11:30.583>
04:11:30.583> [ 98083][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1026
04:11:30.583>
04:11:30.583> [ 98083][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:30.583>
04:11:30.809> [ 98206][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:30.809>
04:11:30.809> [ 98206][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:30.809> ndpoint(1) cluster(0x405)
04:11:30.809>
04:11:30.809> [ 98207][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1029
04:11:30.809>
04:11:30.809> [ 98207][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:30.809>
04:11:35.583> [103083][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:35.583>
04:11:35.583> [103083][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:35.583> ndpoint(1) cluster(0x402)
04:11:35.583>
04:11:35.583> [103084][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1026
04:11:35.583>
04:11:35.583> [103084][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:35.583>
04:11:35.808> [103208][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:35.808>
04:11:35.808> [103209][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:35.808> ndpoint(1) cluster(0x405)
04:11:35.808>
04:11:35.808> [103209][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1029
04:11:35.808>
04:11:35.808> [103210][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:35.808>
04:11:40.584> [108085][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:40.584>
04:11:40.584> [108085][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:40.584> ndpoint(1) cluster(0x402)
04:11:40.584>
04:11:40.584> [108086][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1026
04:11:40.584>
04:11:40.584> [108086][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:40.584>
04:11:40.834> [108210][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:40.834>
04:11:40.834> [108211][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:40.834> ndpoint(1) cluster(0x405)
04:11:40.834>
04:11:40.834> [108211][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1029
04:11:40.834>
04:11:40.834> [108212][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:40.835>
04:11:45.648> [113150][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:45.648>
04:11:45.649> [113150][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:45.649> ndpoint(1) cluster(0x402)
04:11:45.649>
04:11:45.649> [113151][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1026
04:11:45.649>
04:11:45.649> [113151][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:45.649>
04:11:45.868> [113274][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:11:45.868>
04:11:45.868> [113274][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x6b4c) src endpoint(1) to dst e
04:11:45.868> ndpoint(1) cluster(0x405)
04:11:45.868>
04:11:45.868> [113275][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 1029
04:11:45.868>
04:11:45.868> [113275][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:11:45.868>
04:11:50.860> -----------------------------------------
I gniazdko. Ostatnie kilkanaście linijek, to reakcja na przycisk (włącz/wyłącz) na obudowie. Działa (loguje) natychmiastowo (w przeciwieństwie do tego switch 4ch).
04:20:20.378>
04:20:20.378> [  3509][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x6401) is open for 180 seconds
04:20:20.378>
04:20:20.378> [  3511][I][ZigbeeCore.cpp:276] esp_zb_app_signal_handler(): Network steering started
04:20:20.378>
04:20:24.568> [  7956][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NWK Device Associated (0x12), status: ESP_OK
04:20:24.568>
04:20:24.568> [  7958][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Update (0x30), status: ESP_OK
04:20:24.568>
04:20:24.701> [  8034][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x4e25)
04:20:24.701>
04:20:24.701> [  8034][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x8e
04:20:24.701>
04:20:24.701> [  8039][I][ZigbeeCore.cpp:299] esp_zb_app_signal_handler(): New device commissioned or rejoined (short: 0x4e25)
04:20:24.701>
04:20:24.701> [  8039][V][ZigbeeCore.cpp:303] esp_zb_app_signal_handler(): Device capabilities: 0x8e
04:20:24.701>
04:20:24.928> [  8125][I][ZigbeeGateway.cpp:91] find_Cb(): Found sensor
04:20:24.928>
04:20:24.928> [  8125][D][ZigbeeGateway.cpp:100] find_Cb(): Sensor found: short address(0x4e25), endpoint(1)
04:20:24.928>
04:20:24.928> [  8127][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
04:20:24.928>
04:20:24.928> [  8127][I][ZigbeeGateway.cpp:166] printJoinedDevices(): Device on endpoint 1, short address: 0x4e25
04:20:24.928>
04:20:24.928> [  8128][D][Zigbee_Gateway_2.ino:161] loop(): getJoinedDEvices 1 0 357913941 before
04:20:24.928>
04:20:24.928> [  8129][D][Zigbee_Gateway_2.ino:164] loop(): getJoinedDEvices 1 0 357913941 after
04:20:24.928>
04:20:24.928> [  8129][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
04:20:24.928>
04:20:24.928> [  8154][I][ZigbeeGateway.cpp:91] find_Cb(): Found sensor
04:20:24.928>
04:20:24.928> [  8155][D][ZigbeeGateway.cpp:100] find_Cb(): Sensor found: short address(0x4e25), endpoint(1)
04:20:24.928>
04:20:24.928> [  8204][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
04:20:24.928>
04:20:24.928> [  8205][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x4e25) src endpoint(1)
04:20:24.928> to dst endpoint(1) cluster(0x0)
04:20:24.928>
04:20:24.928> [  8206][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
04:20:24.928> 4), type(0x42), value(16)
04:20:24.928>
04:20:24.928> [  8206][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_5f43h46b"
04:20:24.928>
04:20:24.928> [  8130][I][Zigbee_Gateway_2.ino:167] loop(): manufacturer _TZ3000_5f43h46b
04:20:24.928>
04:20:24.928> [  8250][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
04:20:24.928>
04:20:24.928> [  8250][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x4e25) src endpoint(1)
04:20:24.928>
04:20:24.928> [  8251][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
04:20:24.928> 5), type(0x42), value(6)
04:20:24.928>
04:20:24.928> [  8252][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS011F"
04:20:24.928>
04:20:24.928> [  8253][I][Zigbee_Gateway_2.ino:169] loop(): model TS011F
04:20:24.928>
04:20:24.928> [  8254][D][ZigbeeGateway.cpp:112] bindDeviceCluster(): Request sensor to bind us
04:20:24.928>
04:20:24.928>
04:20:24.929> [  8255][D][ZigbeeGateway.cpp:112] bindDeviceCluster(): Request sensor to bind us
04:20:24.929>
04:20:24.929> [  8264][V][ZigbeeGateway.cpp:73] bindCb(): Binding success (ZC side)
04:20:24.929>
04:20:24.929> [  8265][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
04:20:24.929>
04:20:24.929> [  8265][V][ZigbeeGateway.cpp:73] bindCb(): Binding success (ZC side)
04:20:24.929>
04:20:24.929>
04:20:24.929> [  8266][V][ZigbeeGateway.cpp:73] bindCb(): Binding success (ZC side)
04:20:24.929>
04:20:24.929> [  8266][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
04:20:24.929>
04:20:24.929> [  8267][D][Zigbee_Gateway_2.ino:161] loop(): getJoinedDEvices 1 0 357913941 before
04:20:24.929>
04:20:24.929> [  8269][D][Zigbee_Gateway_2.ino:164] loop(): getJoinedDEvices 1 0 357913941 after
04:20:24.929>
04:20:24.929> [  8269][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
04:20:24.929>
04:20:26.896> [  8352][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
04:20:26.896>
04:20:26.896> [  8388][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
04:20:26.896>
04:20:26.896> [  8421][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
04:20:26.896>
04:20:26.896> [  8435][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
04:20:26.896>
04:20:26.896> [  8435][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x4e25) src endpoint(1)
04:20:26.896> to dst endpoint(1) cluster(0x0)
04:20:26.896>
04:20:26.896> [  8436][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
04:20:26.896> 4), type(0x42), value(16)
04:20:26.897>
04:20:26.897> [  8436][I][ZigbeeEP.cpp:223] zbReadBasicCluster(): Peer Manufacturer is "_TZ3000_5f43h46b"
04:20:26.897>
04:20:26.897> [  8270][I][Zigbee_Gateway_2.ino:167] loop(): manufacturer _TZ3000_5f43h46b
04:20:26.897>
04:20:26.897> [  8520][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x1000) callback
04:20:26.897>
04:20:26.898> [  8520][V][ZigbeeHandlers.cpp:87] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0x4e25) src endpoint(1)
04:20:26.898> to dst endpoint(1) cluster(0x0)
04:20:26.898>
04:20:26.898> [  8521][V][ZigbeeHandlers.cpp:96] zb_cmd_read_attr_resp_handler(): Read attribute response: status(0), cluster(0x0), attribute(0x
04:20:26.898> 5), type(0x42), value(6)
04:20:26.898>
04:20:26.898> [  8521][I][ZigbeeEP.cpp:232] zbReadBasicCluster(): Peer Model is "TS011F"
04:20:26.898>
04:20:26.898> [  8523][I][Zigbee_Gateway_2.ino:169] loop(): model TS011F
04:20:26.898>
04:20:26.898> [  8524][D][ZigbeeGateway.cpp:112] bindDeviceCluster(): Request sensor to bind us
04:20:26.898>
04:20:26.898>
04:20:26.898> [  8525][D][ZigbeeGateway.cpp:112] bindDeviceCluster(): Request sensor to bind us
04:20:26.898>
04:20:26.898> [  8534][V][ZigbeeGateway.cpp:73] bindCb(): Binding success (ZC side)
04:20:26.898>
04:20:26.898> [  8535][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
04:20:26.899>
04:20:26.899> [  8535][V][ZigbeeGateway.cpp:73] bindCb(): Binding success (ZC side)
04:20:26.899>
04:20:26.899> [  8535][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
04:20:26.899>
04:20:26.899> [  8536][V][ZigbeeGateway.cpp:73] bindCb(): Binding success (ZC side)
04:20:26.899>
04:20:26.899> [  8536][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
04:20:26.899>
04:20:26.899> [  8636][I][ZigbeeGateway.cpp:163] printJoinedDevices(): joined devices:
04:20:26.899>
04:20:26.899> [  8660][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
04:20:26.899>
04:20:26.899> [  8710][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
04:20:26.899>
04:20:26.899> [  8726][V][ZigbeeGateway.cpp:75] bindCb(): Binding success (ED side
04:20:26.899>
04:20:26.899> [  8749][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: ZDO Device Authorized (0x2f), status: ESP_OK
04:20:26.899>
04:20:26.899> [  8815][I][ZigbeeCore.cpp:327] esp_zb_app_signal_handler(): Network(0x6401) is open for 180 seconds
04:20:26.899>
04:20:31.897> [ 15284][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:20:31.897>
04:20:31.897> [ 15285][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e25) src endpoint(1) to dst e
04:20:31.897> ndpoint(1) cluster(0x6)
04:20:31.897>
04:20:31.897> [ 15286][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 6
04:20:31.897>
04:20:31.897> [ 15286][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:20:31.897>
04:20:31.897> [ 15290][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:20:31.897>
04:20:31.897> [ 15291][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e25) src endpoint(1) to dst e
04:20:31.897> ndpoint(1) cluster(0xe001)
04:20:31.897>
04:20:31.897> [ 15291][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 57345
04:20:31.897>
04:20:32.420> [ 15292][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 53264
04:20:32.420>
04:20:32.420> [ 15374][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:20:32.420>
04:20:32.420> [ 15375][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e25) src endpoint(1) to dst e
04:20:32.420> ndpoint(1) cluster(0xe001)
04:20:32.420>
04:20:32.420> [ 15376][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 57345
04:20:32.420>
04:20:32.420> [ 15376][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 53296
04:20:32.420>
04:20:35.294> [ 18679][V][ZigbeeCore.cpp:340] esp_zb_app_signal_handler(): ZDO signal: NLME Status Indication (0x32), status: ESP_OK
04:20:35.294>
04:20:58.917> [ 42309][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:20:58.918>
04:20:58.918> [ 42309][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e25) src endpoint(1) to dst e
04:20:58.918> ndpoint(1) cluster(0x6)
04:20:58.918>
04:20:58.918> [ 42310][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 6
04:20:58.918>
04:20:58.918> [ 42310][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:20:58.918>
04:21:03.728> [ 47112][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:21:03.728>
04:21:03.728> [ 47113][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e25) src endpoint(1) to dst e
04:21:03.728> ndpoint(1) cluster(0x6)
04:21:03.728>
04:21:03.728> [ 47113][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 6
04:21:03.728>
04:21:03.728> [ 47114][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:21:03.728>
04:21:05.396> [ 48787][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:21:05.396>
04:21:05.396> [ 48787][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e25) src endpoint(1) to dst e
04:21:05.396> ndpoint(1) cluster(0x6)
04:21:05.396>
04:21:05.396> [ 48788][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 6
04:21:05.396>
04:21:05.396> [ 48789][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:21:05.396>
04:21:06.603> [ 49998][I][ZigbeeHandlers.cpp:20] zb_action_handler(): Receive Zigbee action(0x2000) callback
04:21:06.603>
04:21:06.603> [ 49998][V][ZigbeeHandlers.cpp:67] zb_attribute_reporting_handler(): Received report from address(0x4e25) src endpoint(1) to dst e
04:21:06.603> ndpoint(1) cluster(0x6)
04:21:06.603>
04:21:06.773> [ 49999][I][ZigbeeGateway.cpp:174] zbAttributeRead(): cluster_id 6
04:21:06.773>
04:21:06.773> [ 49999][I][ZigbeeGateway.cpp:175] zbAttributeRead(): attribute->id 0
04:21:06.773>
04:21:17.271> [ 60666][I][ZigbeeGateway.cpp:154] printGatewayDevices(): gateway devices:
04:21:17.271>
04:21:17.272> [ 60667][I][ZigbeeGateway.cpp:157] printGatewayDevices(): Device on endpoint 1, short address: 0x4e25
lukasz06 wrote: Thu Jan 02, 2025 11:14 pm Ja zaktualizowałem, lecz teraz się nie kompiluje. Poniżej screen ustawień płytki
poprawiłem kod - tak to jest jak z komórki się pisze 😉
