Silnik do rolet wewnętrznych RSD-M01 Aqara [bramka ZigBee]
LukiSpajder
Has thanked: 25 times
Been thanked: 34 times
Próbuje odczytać numer softu w tym silniku ale mi się nie udaje . Czy ja coś robię źle czy coś innego ;)
Zamieszczam logi , wybudziłem silnik i potem w GUI daje Read Software Build ID
Using 'COM10' as serial port.
Unexpected error: could not open port 'COM10': PermissionError(13, 'Odmowa dostępu.', None, 5)
[15:24:34][141508][D][ZigbeeCore.cpp:515] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[15:24:34][141509][D][ZigbeeCore.cpp:519] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[15:24:34]APSDE INDICATION - src_addr_mode: 117, cluster_id: 0x0000, asdu_length: 28
[15:24:34]APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xab75
[15:24:34]APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 71, rx_time: 0
[15:24:34][141510][I][ZigbeeHandlers.cpp:246] zb_raw_cmd_handler(): cluster id: 0x0, command id: 10
[15:24:34][141511][I][ZigbeeHandlers.cpp:249] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[15:24:34][141511][I][ZigbeeHandlers.cpp:253] zb_raw_cmd_handler(): is common comand 1, disable_default_response 0, is_manuf_specific 1
[15:24:34][141512][I][ZigbeeHandlers.cpp:257] zb_raw_cmd_handler(): manuf_specific 0x115f
[15:24:34][141512][I][ZigbeeHandlers.cpp:261] zb_raw_cmd_handler(): RAW bufid: 19 size: 23
[15:24:34][141513][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x05
[15:24:34][141513][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[15:24:34][141513][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x42
[15:24:34][141514][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x13
[15:24:34][141514][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x6C
[15:24:34][141514][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x75
[15:24:34][141515][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x6D
[15:24:34][141515][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x69
[15:24:34][141515][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x2E
[15:24:34][141516][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x63
[15:24:34][141516][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x75
[15:24:34][141516][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x72
[15:24:34][141517][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x74
[15:24:34][141517][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x61
[15:24:34][141517][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x69
[15:24:34][141517][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x6E
[15:24:34][141518][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x2E
[15:24:34][141518][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x61
[15:24:34][141518][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x63
[15:24:34][141519][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x6E
[15:24:34][141519][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x30
[15:24:34][141520][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x32
[15:24:34][141520][I][ZigbeeHandlers.cpp:274] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xab75, 0xab75, 0x0, 0x0
[15:24:34][141521][I][z2s_devices_table.cpp:6662] Z2S_onUpdateDeviceLastRssi(): short addr 0xAB75, rssi -66
[15:24:34][141521][I][z2s_devices_table.cpp:6667] Z2S_onUpdateDeviceLastRssi(): short addr 0xAB75, rssi -66
[15:24:34][141522][I][z2s_devices_table.cpp:6675] Z2S_onUpdateDeviceLastRssi(): short addr 0xAB75, rssi -66
[15:24:34][141522][I][z2s_devices_table.cpp:5995] Z2S_onCustomCmdReceive(): , endpoint 0x1, cluster 0x0, cmd id 0xa
[15:24:34][141523][I][z2s_devices_table.cpp:281] Z2S_findChannelNumberSlot(): sub id -1
[15:24:34][141523][I][z2s_devices_table.cpp:6009] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x5
[15:24:34][141524][I][ZigbeeHandlers.cpp:301] zb_raw_cmd_handler(): -----------------raw command not processed------------------
[15:24:34][141524][I][ZigbeeHandlers.cpp:89] zb_action_handler(): Receive Zigbee action(0x2000) callback
[15:24:34][141525][V][ZigbeeHandlers.cpp:344] zb_attribute_reporting_handler(): Received report from address(0xab75) src endpoint(1) to dst endpoint(1) cluster(0x0)
[15:24:34][141525][I][ZigbeeGateway.cpp:715] zbReadBasicCluster(): Peer Model is "lumi.curtain.acn002"
[15:24:34][141529][D][ZigbeeCore.cpp:515] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[15:24:34][141530][D][ZigbeeCore.cpp:519] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[15:24:34]APSDE INDICATION - src_addr_mode: 117, cluster_id: 0xfcc0, asdu_length: 64
[15:24:34][141531][I][ZigbeeHandlers.cpp:246] zb_raw_cmd_handler(): cluster id: 0xfcc0, command id: 10
[15:24:35][141532][I][ZigbeeHandlers.cpp:249] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[15:24:35][141532][I][ZigbeeHandlers.cpp:253] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 1
[15:24:35][141533][I][ZigbeeHandlers.cpp:257] zb_raw_cmd_handler(): manuf_specific 0x115f
[15:24:35][141533][I][ZigbeeHandlers.cpp:261] zb_raw_cmd_handler(): RAW bufid: 22 size: 59
[15:24:35][141534][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0xF7
[15:24:35][141534][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[15:24:35][141534][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x41
[15:24:35][141535][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x37
[15:24:35][141535][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x03
[15:24:35][141535][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x28
[15:24:35][141536][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x14
[15:24:35][141536][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x05
[15:24:35][141536][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x21
[15:24:35][141537][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x02
[15:24:35][141537][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[15:24:35][141537][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x09
[15:24:35][141538][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x21
[15:24:35][141538][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[15:24:35][141539][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x01
[15:24:35][141539][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x0A
[15:24:35][141539][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x21
[15:24:35][141540][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[15:24:35][141540][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x0B
[15:24:35][141541][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x20
[15:24:35][141541][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[15:24:35][141541][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x0C
[15:24:35][141542][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x20
[15:24:35][141542][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x01
[15:24:35][141542][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x0D
[15:24:35][141543][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x23
[15:24:35][141543][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x20
[15:24:35][141543][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x0E
[15:24:35][141544][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[15:24:35][141544][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x11
[15:24:35][141545][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x23
[15:24:35][141545][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x01
[15:24:35][141545][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[15:24:35][141546][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[15:24:35][141546][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x64
[15:24:35][141547][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x20
[15:24:35][141547][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0xFF
[15:24:35][141547][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x65
[15:24:35][141548][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x20
[15:24:35][141548][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x47
[15:24:35][141548][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x66
[15:24:35][141549][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x20
[15:24:35][141549][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[15:24:35][141549][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x67
[15:24:35][141550][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x20
[15:24:35][141550][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[15:24:35][141550][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x69
[15:24:35][141551][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x20
[15:24:35][141551][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x02
[15:24:35][141552][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x6A
[15:24:35][141552][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x21
[15:24:35][141552][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x20
[15:24:35][141553][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x1E
[15:24:35][141553][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x6B
[15:24:35][141553][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x20
[15:24:35][141554][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[15:24:35][141554][I][ZigbeeHandlers.cpp:274] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xab75, 0xab75, 0x0, 0x0
[15:24:35][141554][I][z2s_devices_table.cpp:6662] Z2S_onUpdateDeviceLastRssi(): short addr 0xAB75, rssi -66
[15:24:35][141555][I][z2s_devices_table.cpp:6667] Z2S_onUpdateDeviceLastRssi(): short addr 0xAB75, rssi -66
[15:24:35][141555][I][z2s_devices_table.cpp:6675] Z2S_onUpdateDeviceLastRssi(): short addr 0xAB75, rssi -66
[15:24:35][141556][I][z2s_devices_table.cpp:5995] Z2S_onCustomCmdReceive(): , endpoint 0x1, cluster 0xfcc0, cmd id 0xa
[15:24:35][141556][I][z2s_devices_table.cpp:281] Z2S_findChannelNumberSlot(): sub id -1
[15:24:35][141557][I][z2s_devices_table.cpp:6009] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x5
[15:24:35][141557][I][ZigbeeHandlers.cpp:301] zb_raw_cmd_handler(): -----------------raw command not processed------------------
[15:24:35][141558][I][ZigbeeHandlers.cpp:89] zb_action_handler(): Receive Zigbee action(0x2000) callback
[15:24:35][141559][V][ZigbeeHandlers.cpp:344] zb_attribute_reporting_handler(): Received report from address(0xab75) src endpoint(1) to dst endpoint(1) cluster(0xfcc0)
[15:24:35][141559][I][ZigbeeGateway.cpp:1107] zbAttributeReporting(): short address 0xAB75
[15:24:35][141560][I][ZigbeeGateway.cpp:1115] zbAttributeReporting(): ieee_addr[0] = 54
[15:24:35][141560][I][ZigbeeGateway.cpp:1115] zbAttributeReporting(): ieee_addr[1] = EF
[15:24:35][141560][I][ZigbeeGateway.cpp:1115] zbAttributeReporting(): ieee_addr[2] = 44
[15:24:35][141561][I][ZigbeeGateway.cpp:1115] zbAttributeReporting(): ieee_addr[3] = 10
[15:24:35][141561][I][ZigbeeGateway.cpp:1115] zbAttributeReporting(): ieee_addr[4] = 01
[15:24:35][141562][I][ZigbeeGateway.cpp:1115] zbAttributeReporting(): ieee_addr[5] = 4A
[15:24:35][141562][I][ZigbeeGateway.cpp:1115] zbAttributeReporting(): ieee_addr[6] = FC
[15:24:35][141562][I][ZigbeeGateway.cpp:1115] zbAttributeReporting(): ieee_addr[7] = 9F
[15:24:35][141563][I][ZigbeeGateway.cpp:1297] zbAttributeReporting(): LUMI custom cluster (0xfcc0), attribute id (0xf7), attribute data type (0x41)
[15:24:35][141564][I][z2s_devices_table.cpp:3793] Z2S_onLumiCustomClusterReceive(): , endpoint 0x1, attribute id 0xf7, size 56
[15:24:35][141564][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[0] = 0x37(55)
[15:24:35][141565][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[1] = 0x03(3)
[15:24:35][141565][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[2] = 0x28(40)
[15:24:35][141566][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[3] = 0x14(20)
[15:24:35][141566][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[4] = 0x05(5)
[15:24:35][141567][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[5] = 0x21(33)
[15:24:35][141567][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[6] = 0x02(2)
[15:24:35][141568][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[7] = 0x00(0)
[15:24:35][141568][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[8] = 0x09(9)
[15:24:35][141568][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[9] = 0x21(33)
[15:24:35][141569][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[10] = 0x00(0)
[15:24:35][141570][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[11] = 0x01(1)
[15:24:35][141570][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[12] = 0x0A(10)
[15:24:35][141571][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[13] = 0x21(33)
[15:24:35][141571][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[14] = 0x00(0)
[15:24:35][141572][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[15] = 0x00(0)
[15:24:35][141572][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[16] = 0x0B(11)
[15:24:35][141573][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[17] = 0x20(32)
[15:24:35][141573][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[18] = 0x00(0)
[15:24:35][141574][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[19] = 0x0C(12)
[15:24:35][141574][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[20] = 0x20(32)
[15:24:35][141575][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[21] = 0x01(1)
[15:24:35][141575][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[22] = 0x0D(13)
[15:24:35][141576][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[23] = 0x23(35)
[15:24:35][141576][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[24] = 0x20(32)
[15:24:35][141577][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[25] = 0x0E(14)
[15:24:35][141577][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[26] = 0x00(0)
[15:24:35][141578][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[27] = 0x00(0)
[15:24:35][141578][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[28] = 0x11(17)
[15:24:35][141579][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[29] = 0x23(35)
[15:24:35][141579][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[30] = 0x01(1)
[15:24:35][141580][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[31] = 0x00(0)
[15:24:35][141580][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[32] = 0x00(0)
[15:24:35][141581][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[33] = 0x00(0)
[15:24:35][141581][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[34] = 0x64(100)
[15:24:35][141582][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[35] = 0x20(32)
[15:24:35][141582][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[36] = 0xFF(255)
[15:24:35][141583][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[37] = 0x65(101)
[15:24:35][141583][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[38] = 0x20(32)
[15:24:35][141584][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[39] = 0x47(71)
[15:24:35][141584][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[40] = 0x66(102)
[15:24:35][141585][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[41] = 0x20(32)
[15:24:35][141585][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[42] = 0x00(0)
[15:24:35][141586][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[43] = 0x67(103)
[15:24:35][141586][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[44] = 0x20(32)
[15:24:35][141587][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[45] = 0x00(0)
[15:24:35][141587][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[46] = 0x69(105)
[15:24:35][141588][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[47] = 0x20(32)
[15:24:35][141588][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[48] = 0x02(2)
[15:24:35][141589][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[49] = 0x6A(106)
[15:24:35][141589][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[50] = 0x21(33)
[15:24:35][141590][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[51] = 0x20(32)
[15:24:35][141590][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[52] = 0x1E(30)
[15:24:35][141591][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[53] = 0x6B(107)
[15:24:35][141591][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[54] = 0x20(32)
[15:24:35][141592][I][z2s_devices_table.cpp:3802] Z2S_onLumiCustomClusterReceive(): F7 attribute[55] = 0x00(0)
[15:24:35][141592][I][z2s_devices_table.cpp:281] Z2S_findChannelNumberSlot(): sub id -1
[15:24:35][141593][I][z2s_devices_table.cpp:281] Z2S_findChannelNumberSlot(): sub id -1
[15:24:35][141593][I][z2s_devices_table.cpp:426] Z2S_findChannelNumberNextSlot(): , endpoint 0xffffffff, channel type 0xffffffff
[15:24:35]Send: [53 55 50 4C 41 1C 1D 00 00 00 28 00 00 00 10 00 00 00 31 73 D6 69 00 00 00 00 2E D8 0D 00 00 00 00 00 ]
[15:24:35]Send: [53 55 50 4C 41 ]
[15:24:35]Recv: [53 55 50 4C 41 1C 18 00 00 00 32 00 00 00 10 00 00 00 12 57 D6 69 00 00 00 00 6F 8C 09 00 00 00 00 00 53 55 50 4C 41 ]
[15:24:37][143753][I][z2s_web_gui.cpp:5719] getZigbeeDeviceQueryCallback(): device_selector value 2
[15:24:37][143754][I][ZigbeeGateway.cpp:631] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4000
[15:24:37][144320][D][ZigbeeCore.cpp:515] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[15:24:37][144321][D][ZigbeeCore.cpp:519] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[15:24:37]APSDE INDICATION - src_addr_mode: 117, cluster_id: 0x0000, asdu_length: 6
[15:24:37]APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xab75
[15:24:37]APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 66, rx_time: 0
[15:24:37][144323][I][ZigbeeHandlers.cpp:246] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1
[15:24:37][144323][I][ZigbeeHandlers.cpp:249] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[15:24:37][144324][I][ZigbeeHandlers.cpp:253] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[15:24:37][144324][I][ZigbeeHandlers.cpp:257] zb_raw_cmd_handler(): manuf_specific 0x0
[15:24:37][144325][I][ZigbeeHandlers.cpp:261] zb_raw_cmd_handler(): RAW bufid: 9 size: 3
[15:24:37][144325][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[15:24:37][144326][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x40
[15:24:37][144326][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x86
[15:24:37][144326][I][ZigbeeHandlers.cpp:274] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xab75, 0xab75, 0x0, 0x0
[15:24:37][144327][I][z2s_devices_table.cpp:6662] Z2S_onUpdateDeviceLastRssi(): short addr 0xAB75, rssi -67
[15:24:37][144327][I][z2s_devices_table.cpp:6667] Z2S_onUpdateDeviceLastRssi(): short addr 0xAB75, rssi -67
[15:24:37][144328][I][z2s_devices_table.cpp:6675] Z2S_onUpdateDeviceLastRssi(): short addr 0xAB75, rssi -67
[15:24:37][144328][I][z2s_devices_table.cpp:5995] Z2S_onCustomCmdReceive(): , endpoint 0x1, cluster 0x0, cmd id 0x1
[15:24:37][144329][I][z2s_devices_table.cpp:281] Z2S_findChannelNumberSlot(): sub id -1
[15:24:37][144329][I][z2s_devices_table.cpp:6009] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x5
[15:24:37][144330][I][ZigbeeHandlers.cpp:301] zb_raw_cmd_handler(): -----------------raw command not processed------------------
[15:24:37][144330][I][ZigbeeHandlers.cpp:89] zb_action_handler(): Receive Zigbee action(0x1000) callback
[15:24:37][144331][V][ZigbeeHandlers.cpp:374] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xab75) src endpoint(1) to dst endpoint(1) cluster(0x0)
[15:24:37][144332][V][ZigbeeHandlers.cpp:382] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0x4000), type(0x0), value(0)
[15:24:37][144332][I][ZigbeeGateway.cpp:767] zbReadBasicCluster(): Basic cluster: attribute(0x4000), type (0x00), size (0x00)
[15:24:37][144333][I][z2s_devices_table.cpp:4342] Z2S_onBasicReceive(): short address 0xAB75 endpoint 0x1, attribute id 0x4000, size 0
[15:24:38][144754][I][ZigbeeGateway.cpp:637] zbQueryDeviceBasicCluster(): basic tsn 0x13
[15:24:38][144757][D][AsyncTCP.cpp:246] _get_async_event(): coalescing polls, network congestion or async callbacks might be too slow!
[15:24:48][155007][I][z2s_web_gui.cpp:5719] getZigbeeDeviceQueryCallback(): device_selector value 2
[15:24:48][155008][I][ZigbeeGateway.cpp:631] zbQueryDeviceBasicCluster(): Query basic cluster attribute 0x4000
[15:24:48][155253][D][ZigbeeCore.cpp:515] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
[15:24:48][155253][D][ZigbeeCore.cpp:519] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
[15:24:48]APSDE INDICATION - src_addr_mode: 117, cluster_id: 0x0000, asdu_length: 6
[15:24:48]APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0xab75
[15:24:48]APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 66, rx_time: 0
[15:24:48][155255][I][ZigbeeHandlers.cpp:246] zb_raw_cmd_handler(): cluster id: 0x0, command id: 1
[15:24:48][155256][I][ZigbeeHandlers.cpp:249] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
[15:24:48][155256][I][ZigbeeHandlers.cpp:253] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
[15:24:48][155257][I][ZigbeeHandlers.cpp:257] zb_raw_cmd_handler(): manuf_specific 0x0
[15:24:48][155257][I][ZigbeeHandlers.cpp:261] zb_raw_cmd_handler(): RAW bufid: 16 size: 3
[15:24:48][155258][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x00
[15:24:48][155258][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x40
[15:24:48][155258][I][ZigbeeHandlers.cpp:264] zb_raw_cmd_handler(): 0x86
[15:24:48][155259][I][ZigbeeHandlers.cpp:274] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0xab75, 0xab75, 0x0, 0x0
[15:24:48][155259][I][z2s_devices_table.cpp:6662] Z2S_onUpdateDeviceLastRssi(): short addr 0xAB75, rssi -67
[15:24:48][155260][I][z2s_devices_table.cpp:6667] Z2S_onUpdateDeviceLastRssi(): short addr 0xAB75, rssi -67
[15:24:48][155260][I][z2s_devices_table.cpp:6675] Z2S_onUpdateDeviceLastRssi(): short addr 0xAB75, rssi -67
[15:24:48][155261][I][z2s_devices_table.cpp:5995] Z2S_onCustomCmdReceive(): , endpoint 0x1, cluster 0x0, cmd id 0x1
[15:24:48][155261][I][z2s_devices_table.cpp:281] Z2S_findChannelNumberSlot(): sub id -1
[15:24:48][155262][I][z2s_devices_table.cpp:6009] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x5
[15:24:48][155262][I][ZigbeeHandlers.cpp:301] zb_raw_cmd_handler(): -----------------raw command not processed------------------
[15:24:48][155263][I][ZigbeeHandlers.cpp:89] zb_action_handler(): Receive Zigbee action(0x1000) callback
[15:24:48][155264][V][ZigbeeHandlers.cpp:374] zb_cmd_read_attr_resp_handler(): Read attribute response: from address(0xab75) src endpoint(1) to dst endpoint(1) cluster(0x0)
[15:24:48][155264][V][ZigbeeHandlers.cpp:382] zb_cmd_read_attr_resp_handler(): Read attribute response: status(134), cluster(0x0), attribute(0x4000), type(0x0), value(0)
[15:24:48][155265][I][ZigbeeGateway.cpp:767] zbReadBasicCluster(): Basic cluster: attribute(0x4000), type (0x00), size (0x00)
[15:24:48][155266][I][z2s_devices_table.cpp:4342] Z2S_onBasicReceive(): short address 0xAB75 endpoint 0x1, attribute id 0x4000, size 0
[15:24:49][156009][I][ZigbeeGateway.cpp:637] zbQueryDeviceBasicCluster(): basic tsn 0x14
[15:24:51][158009][E][ZigbeeGateway.cpp:650] zbQueryDeviceBasicCluster(): Error while querying basic cluster attribute 0x4000
[15:24:51][158012][D][AsyncTCP.cpp:246] _get_async_event(): coalescing polls, network congestion or async callbacks might be too slow!
[15:24:51][158013][D][AsyncTCP.cpp:246] _get_async_event(): coalescing polls, network congestion or async callbacks might be too slow!
[15:24:51][158014][D][AsyncTCP.cpp:246] _get_async_event(): coalescing polls, network congestion or async callbacks might be too slow!
[15:25:00]Send: [53 55 50 4C 41 1C 1E 00 00 00 28 00 00 00 10 00 00 00 4A 73 D6 69 00 00 00 00 37 F5 0D 00 00 00 00 00 ]
[15:25:00]Send: [53 55 50 4C 41 ]
[15:25:00]
Serial port closed!
Has thanked: 291 times
LukiSpajder wrote: Wed Apr 08, 2026 1:32 pm Próbuje odczytać numer softu w tym silniku ale mi się nie udaje . Czy ja coś robię źle czy coś innego ;)
[15:25:00]
Serial port closed!
Aqara inaczej raportuje numer wersji, nie korzysta z tego rozwiązania, którego obecnie używa bramka (klaster BASIC, atrybut SW_BUILD_ID).
LukiSpajder
vajera wrote: Wed Apr 08, 2026 3:49 pm
Czy ja dobrze to zrobiłem ?😉. Bo wszędzie mam tą samą odpowiedź a w jednym silniku jest soft 1432 a w innych 1530
LukiSpajder wrote: Wed Apr 08, 2026 5:52 pm
To rozwiązanie z BASIC i 0x4000 bramka stosuje po naciśnięciu przycisku Read Software Id, ale tak jak pisałem Aqara nie chce go raportować.
Jest opcja odczytania wersji z klastra OTA, ale muszę się temu przyjrzeć.
LukiSpajder
vajera wrote: Wed Apr 08, 2026 6:02 pm
Dobra ja to źle zrozumiałem 😁. Że nie raportuje przed tem przycisk a żeby sprawdzić to co w nawiasie - dobra nie było tematu 😉.
Jak coś to nie aktualizuje narazie tego jednego w razie jak coś wykombinujesz z tym sprawdzaniem ( chyba że to ciężki temat )
LukiSpajder
Nie śmiało pytam czy coś udało się zmienić w temacie odczytu numeru softu ?
Chociaż nie sprawdziłem najnowszej wersji bramki 😉
LukiSpajder wrote: Thu Apr 30, 2026 3:07 pm
A spróbuj odczytać atrybut 2 z klastra OTA UPGRADE?
LukiSpajder
vajera wrote: Thu Apr 30, 2026 5:05 pm
coś takiego dostałem w odpowiedzi
Reading attribute successful!
Data value is 4648295357585817600(0x4082100000000000)
Data type is NULL(0x0)
Data size is 0x0
LukiSpajder wrote: Thu Apr 30, 2026 5:47 pm
Data size is 0x0
Spróbuj może chwilę wcześniej obudzić urządzenie (jakiś przycisk?)?
Znalazłem miejsce, gdzie on raportuje wersję, ale to jest w tej paczce F7, więc nie da się tego odczytać na żądanie - musiałbym gdzieś to zapisywać.
LukiSpajder
vajera wrote: Thu Apr 30, 2026 6:28 pm
Data size is 0x0
wybudziłem napęd tym przyciskiem na dole reset ale za każdym razem otrzymuje tą samą odpowiedz . Wersja softu przydała by się do aktualizacji czy mamy najnowszy czy robić ota. Co prawda ja mam bramkę aquara ale w Zigbee+Supla jest ota do po co kombinować :D . Jedyny problem to jak wersja softu siedzi w urządzeniu . Bramka aquara zaraz po parowaniu pokazuje numer oprogramowania - ale jak to jest rozwiązane :D ;)
Rozumie że ten problem odczytu dotyczy całej grupy urządzeni aquara ?
