Własny serwer supla - od czego zacząć
jureg2
I dalej nic
pi@raspberrypi:~ $ sudo apt update
Get:1 file:/var/cache/openmediavault/archives InRelease
Ign:1 file:/var/cache/openmediavault/archives InRelease
Get:2 file:/var/cache/openmediavault/archives Release
Ign:2 file:/var/cache/openmediavault/archives Release
Get:3 file:/var/cache/openmediavault/archives Packages
Ign:3 file:/var/cache/openmediavault/archives Packages
Get:4 file:/var/cache/openmediavault/archives Translation-en
Ign:4 file:/var/cache/openmediavault/archives Translation-en
Hit:5 http://security.debian.org/debian-security buster/updates InRelease
Hit:6 http://httpredir.debian.org/debian buster-backports InRelease
Hit:7 http://packages.openmediavault.org/public usul InRelease
Hit:8 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:9 https://download.docker.com/linux/raspbian buster InRelease
Hit:10 https://download.docker.com/linux/debian buster InRelease
Ign:11 https://dl.bintray.com/openmediavault-p ... opers/usul buster InRelease
Hit:12 https://openmediavault.github.io/packages usul InRelease
Get:13 https://dl.bintray.com/openmediavault-p ... opers/usul buster Release [4363 B]
Hit:14 http://archive.raspberrypi.org/debian buster InRelease
Fetched 4363 B in 4s (1074 B/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
37 packages can be upgraded. Run 'apt list --upgradable' to see them.
pi@raspberrypi:~ $ sudo apt install -y python3-pip
python3-pip is already the newest version (18.1-5+rpt1).
0 upgraded, 0 newly installed, 0 to remove and 37 not upgraded.
pi@raspberrypi:~ $ sudo pip3 install docker-compose
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting docker-compose
Using cached https://files.pythonhosted.org/packages ... ne-any.whl
Collecting docker[ssh]<5,>=4.3.1 (from docker-compose)
Requirement already satisfied: requests<3,>=2.20.0 in /usr/lib/python3/dist-packages (from docker-compose) (2.21.0)
Collecting websocket-client<1,>=0.32.0 (from docker-compose)
Collecting texttable<2,>=0.9.0 (from docker-compose)
Collecting dockerpty<1,>=0.4.1 (from docker-compose)
Using cached https://www.piwheels.org/simple/dockerp ... ne-any.whl
Requirement already satisfied: cached-property<2,>=1.2.0 in /usr/lib/python3/dist-packages (from docker-compose) (1.5.1)
Collecting docopt<1,>=0.6.1 (from docker-compose)
Using cached https://www.piwheels.org/simple/docopt/ ... ne-any.whl
Collecting distro<2,>=1.5.0 (from docker-compose)
Requirement already satisfied: PyYAML<6,>=3.10 in /usr/lib/python3/dist-packages (from docker-compose) (3.13)
Collecting jsonschema<4,>=2.5.1 (from docker-compose)
Collecting python-dotenv<1,>=0.13.0 (from docker-compose)
Requirement already satisfied: six>=1.4.0 in /usr/lib/python3/dist-packages (from docker[ssh]<5,>=4.3.1->docker-compose) (1.12.0)
Collecting paramiko>=2.4.2; extra == "ssh" (from docker[ssh]<5,>=4.3.1->docker-compose)
Collecting pyrsistent>=0.14.0 (from jsonschema<4,>=2.5.1->docker-compose)
Using cached https://files.pythonhosted.org/packages ... 7.3.tar.gz
Complete output from command python setup.py egg_info:
Traceback (most recent call last):
File "<string>", line 1, in <module>
ModuleNotFoundError: No module named 'setuptools'
Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-install-2hrkai_c/pyrsistent/
pi@raspberrypi:~ $
Been thanked: 9 times
sudo apt install python3-setuptools
SOP 2023 :heavy_check_mark:
SOP 2024 :heavy_check_mark:
🧩: 🔑cz->b ⛴️+ila
jureg2
Poszło, serdeczne dzięki
Simono
Been thanked: 6 times
Panowie chciałem zaktualizować dockera na malinie i wywala mi takie coś:
pi@raspberrypi:~/supla-docker $ ./supla.sh upgrade                              Making database backup
Database backup saved to ./var/backups/supla09232021175527.sql.gz
Stopping SUPLA containers
  File "/usr/local/bin/docker-compose", line 7, in <module>
    from compose.cli.main import main
  File "/usr/local/lib/python2.7/dist-packages/compose/cli/main.py", line 17, in <module>
    import docker
  File "/usr/local/lib/python2.7/dist-packages/docker/__init__.py", line 2, in <module>
    from .api import APIClient
  File "/usr/local/lib/python2.7/dist-packages/docker/api/__init__.py", line 2, in <module>
    from .client import APIClient
  File "/usr/local/lib/python2.7/dist-packages/docker/api/client.py", line 10, in <module>
    from .build import BuildApiMixin
  File "/usr/local/lib/python2.7/dist-packages/docker/api/build.py", line 6, in <module>
    from .. import auth
  File "/usr/local/lib/python2.7/dist-packages/docker/auth.py", line 9, in <module>
    from .utils import config
  File "/usr/local/lib/python2.7/dist-packages/docker/utils/__init__.py", line 3, in <module>
    from .decorators import check_resource, minimum_version, update_headers
  File "/usr/local/lib/python2.7/dist-packages/docker/utils/decorators.py", line 4, in <module>
    from . import utils
  File "/usr/local/lib/python2.7/dist-packages/docker/utils/utils.py", line 12, in <module>
    from .. import tls
  File "/usr/local/lib/python2.7/dist-packages/docker/tls.py", line 5, in <module>
    from .transport import SSLAdapter
  File "/usr/local/lib/python2.7/dist-packages/docker/transport/__init__.py", line 3, in <module>
    from .ssladapter import SSLAdapter
  File "/usr/local/lib/python2.7/dist-packages/docker/transport/ssladapter.py", line 21, in <module>
    from backports.ssl_match_hostname import match_hostname
ImportError: No module named ssl_match_hostname
Pomoże ktoś?
Edyta:
Nieaktualne brakowało mi:
po aktualizacji maliny do bustera.
MrBaKTaMo
Witam powiem szczerze jestem kompletnym laikiem poleglem na samym poczateczku ogolnie zaczne od poczatku mam w planach kupic takie cos jak hp t630 thin client z tego co mi sie wydaje powinna na tym supla isc i to z zapasem w kazdym badz razie chcialem sprobowac postawic serwer na swoim lapku zeby sie podszkolic zatrzymalem sie na etapie instalacji dochuba i zalaczenia tego wsl chociaz nawet nwm co to jest w kazdym badz razie po wpisaniu komendy w terminalu
git clone https://github.com/SUPLA/supla-docker.git
wyskakuje mi to
S C:\Users\PC> git clone https://github.com/SUPLA/supla-docker.git
git : The term 'git' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the spelling of the name, or if a path was included, verify th
at the path is correct and try again.
At line:1 char:1
+ git clone https://github.com/SUPLA/supla-docker.git
+ CategoryInfo : ObjectNotFound: (git:String) [], CommandNotFoundException
+ FullyQualifiedErrorId : CommandNotFoundException
i wtym momencie zostalem pokonany szczerze moja znajomosc ang jest na poziomie podstawowym rozumiem z tego wszystkiego tyle ze dochub nie kmini komenty git gdyby ktos chcial mi pomoc bylbym cholernie wdzieczny nie wiem co zrobilem zle czego nie zrobilem prosze o pomoc
[email protected]
Has thanked: 18 times
Been thanked: 26 times
Domyślnie w Windowsie nie jest zainstalowany git i musisz go najpierw zainstalować
Has thanked: 289 times
MrBaKTaMo wrote: Sat Dec 14, 2024 10:44 pm Witam powiem szczerze jestem kompletnym laikiem poleglem na samym poczateczku ogolnie zaczne od poczatku mam w planach kupic takie cos jak hp t630 thin client z tego co mi sie wydaje powinna na tym supla isc i to z zapasem w kazdym badz razie chcialem sprobowac postawic serwer na swoim lapku zeby sie podszkolic zatrzymalem sie na etapie instalacji dochuba i zalaczenia tego wsl chociaz nawet nwm co to jest w kazdym badz razie po wpisaniu komendy w terminalu
wyskakuje mi to
At line:1 char:1
Instalacja własnego serwera ma sens jeżeli w miarę ogarniasz środowisko, w którym instalujesz serwer. Inaczej istnieje duże ryzyko, że będziesz miał wiecznie problemy albo ktoś włamie Ci się na serwer z zewnątrz.
Zapewniam Cię, że jest na tym forum sporo osób, które znają się bardzo dobrze np. na Linuksie a mimo to korzystają z serwerów publicznych...bo wygodnie, tanio (póki co 😉) a przede wszystkim bezpiecznie.
Zasada jest prosta - jeżeli nie masz jasno zdefiniowanego powodu dla posiadania prywatnego serwera to lepiej odpuść bo inaczej Twoi domownicy dojdą do wniosku, że ta Supla to jest...
robi05
Witaj ja też trochę walczyłem z własnym serwerem nieudane zakupy itp itd jak chcesz to odezwij się na priv pomogę opanować u mnie działa już od wiosny bez problemów.
