Zgłoszenia nowych urządzeń 2026 [bramka ZigBee]
Has thanked: 289 times
Robinson74 wrote: Sat Apr 04, 2026 1:54 pm Drugi czujnik wibracji dodał się, ale żaden z nich nie zmienia stanu czujnika binarnego 0-1.
A może to moja bramka już nie daje rady? ;)
Na razie 24 urządzenia i 60 kanałów.
memory
Memory information:
Flash chip real size: 8388608 B
Free Sketch Space: 3407872 B
HeapSize: 357020 B
Free Heap: 58192 B
MaxAllocHeap: 16372 B
Minimal Free Heap: 2596 B
Supla uptime: 839 s
>tasks
>TASKS CPU USAGE
loopTask        566517164               62%
IDLE            95838747                10%
tiT             1859765         <1%
async_tcp       2054451         <1%
Zigbee_main     196266648               21%
arduino_events  817             <1%
Tmr Svc         238             <1%
mdns            60885           <1%
wifi            9905767         1%
esp_timer       33408302                3%
sys_evt         1387            <1%
>dir
>FILE SYSTEM
-- FILE: custom_ca.pem
-- SIZE: 0
-- LAST WRITE: 1970-01-01 00:07:05
-- FILE: supla-dev.cfg.bak
-- SIZE: 2193
-- LAST WRITE: 2026-04-04 15:41:42
-- SIZE: 2193
- DIR : supla
- LAST WRITE: 1969-12-31 23:59:59
-- FILE: 0_bs_cfg
-- SIZE: 32
-- LAST WRITE: 2026-03-19 21:14:00
-- FILE: 13_bs_cfg
-- SIZE: 32
-- LAST WRITE: 2026-03-19 22:41:45
-- FILE: 22_bs_cfg
-- SIZE: 32
-- LAST WRITE: 2026-03-24 10:41:46
-- FILE: 23_gpm_common
-- SIZE: 53
-- LAST WRITE: 2026-03-23 21:42:22
-- FILE: 24_gpm_common
-- SIZE: 53
-- FILE: 25_bs_cfg
-- SIZE: 32
-- LAST WRITE: 2026-03-29 15:47:50
-- FILE: 28_bs_cfg
-- SIZE: 32
-- LAST WRITE: 2026-03-29 16:31:05
-- FILE: 31_bs_cfg
-- SIZE: 32
-- LAST WRITE: 2026-03-29 16:48:54
-- FILE: 38_gpm_common
-- SIZE: 53
-- LAST WRITE: 2026-03-31 17:45:11
-- FILE: 43_gpm_common
-- SIZE: 53
-- LAST WRITE: 2026-03-31 17:47:37
-- FILE: 47_bs_cfg
-- SIZE: 32
-- LAST WRITE: 2026-04-02 21:25:01
-- FILE: 49_bs_cfg
-- SIZE: 32
-- LAST WRITE: 2026-04-03 10:05:06
-- FILE: 50_bs_cfg
-- SIZE: 32
-- LAST WRITE: 2026-04-02 21:23:59
-- FILE: 53_bs_cfg
-- SIZE: 32
-- LAST WRITE: 2026-04-02 21:39:28
-- FILE: 56_bs_cfg
-- SIZE: 32
-- LAST WRITE: 2026-04-04 15:41:37
-- FILE: 57_gpm_common
-- SIZE: 53
-- LAST WRITE: 2026-04-04 15:36:43
-- FILE: 58_gpm_common
-- SIZE: 53
-- FILE: 8_bs_cfg
-- SIZE: 32
-- LAST WRITE: 2026-03-19 21:58:46
- DIR : z2s_gateway
-- FILE: actions_index_table.z2s
-- SIZE: 32
-- LAST WRITE: 1970-01-01 00:00:00
-- FILE: channel_ext_data_004_01.z2s
-- SIZE: 120
-- LAST WRITE: 2026-03-29 18:50:13
-- FILE: channel_ext_data_006_01.z2s
-- SIZE: 120
-- LAST WRITE: 2026-03-29 19:03:08
-- FILE: channel_ext_data_012_01.z2s
-- SIZE: 120
-- LAST WRITE: 2026-03-24 14:17:39
-- FILE: channel_ext_data_017_01.z2s
-- SIZE: 120
-- LAST WRITE: 2026-03-24 14:17:53
-- FILE: channel_ext_data_019_01.z2s
-- SIZE: 120
-- LAST WRITE: 2026-03-24 14:18:16
-- FILE: channel_ext_data_021_01.z2s
-- SIZE: 120
-- LAST WRITE: 2026-03-24 14:18:30
-- FILE: channels_table_v2.bak
-- SIZE: 15360
-- FILE: channels_table_v2.z2s
-- SIZE: 15360
-- LAST WRITE: 2026-04-04 15:36:42
-- FILE: zb_devices_table_v2.bak
-- SIZE: 3840
-- LAST WRITE: 2026-04-04 15:39:33
-- FILE: zb_devices_table_v2.z2s
-- SIZE: 3840
Edycja: Zauważyłem, że przynajmniej zmienia się wartość ostatniego kanału STATE: 0-1-2-3. :)
Ilość urządzeń i kanałów imponująca, ale zapas RAMu jeszcze jest - używasz wersji NO_LOGS?
Skoro zmienia się kanał STATE, to jakaś łączność z czujnikiem musi być - zmienia się ten parametr last seen? Po krótkim (1s) naciśnięciu przycisku parowania jesteś w stanie odczytać RSSI?
Może odwróć logikę i zobacz w jakim stanie jest wtedy to VIBRATION?
ps. Nie ustawiłeś mu przypadkiem parametru refresh w Channel timings?
RomanG
Has thanked: 26 times
Been thanked: 7 times
Hej! :) Jestem poza domem i teraz nie sprawdzę reakcji czujnika na jakieś konkretne komendy, ale do wczorajszego wieczora "vibration" nie zmieniał stanu. Próbowałem usuwać z bramki, parować z inną, wyjmować i zmieniać baterię i nic to nie dawało. Kilka dni temu @book walczył też ze swoim czujnikiem wibracji (brak reakcji "vibration") i u mnie zmienił się stan i tak już pozostało (u niego z resztą też, ale nie wiem, czy jemu teraz działa prawidłowo) - bardziej wygląda to na zmianę logiki kanału. Na razie nie mogę się zaangażować w jego badanie, więc leży na biurku. :(
Może po Świętach się uda.🥴
Może też być tak, że mocno już namieszałem w ustawieniach i nie potrafię tego cofnąć.🤬
Może go "zloguję" i - Łukaszu - coś z tego "wyciągniesz", ale to dopiero ...😀
"Na razie 24 urządzenia i 60 kanałów." To chyba już blisko rekordu ;) .
Wesołych świąt!
edit; Zapomniałem 😀dodać, że pozostałe dwa kanały działają prawidłowo.
Jest jakiś problem z tym czujnikiem:
https://github.com/Koenkk/zigbee2mqtt/discussions/29368
Przyjrzę się temu zjawisku, ale przydałyby się jakieś logi.
Been thanked: 31 times
RomanG wrote: Sat Apr 04, 2026 2:52 pm Hej! :) Jestem poza domem i teraz nie sprawdzę reakcji czujnika na jakieś konkretne komendy, ale do wczorajszego wieczora "vibration" nie zmieniał stanu. Próbowałem usuwać z bramki, parować z inną, wyjmować i zmieniać baterię i nic to nie dawało. Kilka dni temu @book walczył też ze swoim czujnikiem wibracji (brak reakcji "vibration") i u mnie zmienił się stan i tak już pozostało (u niego z resztą też, ale nie wiem, czy jemu teraz działa prawidłowo) - bardziej wygląda to na zmianę logiki kanału. Na razie nie mogę się zaangażować w jego badanie, więc leży na biurku. :(
Wesołych świąt!
Romku, to nie konkretnie do Ciebie, ale ogólnie.
Takie czujniki testuje się na osobnej bramce.
I na spokojnie.
One często mają tak, że się wzbudzają, a do stanu wyjściowego wracają po 30-40 minutach.
Trudno to tak od razu wyłapać, bo dodatkowo zazwyczaj należy jeszcze odwrócić logikę.
Myśmy to już wszystko tutaj przerabiali i podobnie się niektórym wydawało, że czujnik nie reaguje na wibracje.
Rada. Skrócić czas powrotu do stanu wyjściowego w GUI do 5-10 sekund, odwrócić logikę i wtedy obserwować.
Można też włączyć jakiś monitor i obserwować czy i co wysyła podczas potrząsania...
To nie jest żadne czary-mary, tylko zwykły czujnik wibracji ;-)
Tak na szybko:
1. Ustaw mu autoset na np. 5 sekund.
2. Jeżeli to nic nie da, to odwróć logikę, ale zostaw ten autoset ustawiony na 5.
vajera wrote: Sat Apr 04, 2026 3:03 pm Tak na szybko:
Jak to było o tych wielkich umysłach? :lol:
Zibi_007 wrote: Sat Apr 04, 2026 3:05 pm
Złoty a skromny...:lol:
Daj znać, czy to działa, bo mam jeszcze jeden trop.
RomanG
Zibi_007 wrote: Sat Apr 04, 2026 3:02 pm
Wesołych świąt!
I na spokojnie.
Spokojnie, ja wszystkie dobre rady przyjmuję, a przypomnienie czegoś też nie jest złe. ;)
Czujnik ten jest sparowany samotnie z bramką testową, więc tak, jak polecasz. Reakcję sprawdzam nawet po kilkunastu godzinach, to też czujnik i bramka mają "czas na dopasowanie się".
"Autoset" w "Channel timings..." ustawiałem na 5, 10, 15 sekund i nie zaobserwowałem poprawy.
Jeżeli chodzi o "logikę", to o tym myślałem, ale ...ponieważ nie wiem, co to mogłoby dać - według mnie tylko zmianę logiki😄 - to na razie (też z braku czasu) odpuściłem.
Jeszcze raz powtórzę; pozostałe dwa kanały działają prawidłowo.
... i dobrych rad nigdy za wiele😄.
RomanG
vajera wrote: Sat Apr 04, 2026 3:17 pm
Myślę, że tu @Roobinson74, jeżeli znajdzie czas - może coś zadziałać, bo ja zdalnie może dałbym radę, ale nie odważę się dzisiaj angażować żonę, żeby potrząsała czujnikami.🥴
