@vajera, no to utrafiłem kawałek logów. Bramka działa i nagle zaczyna migać dioda na biało. Wklejam kawałek logów ale nie jestem pewien czy z tego coś wyczytasz. Generalnie logami pluje jak karabin
21:55:53.116 -> [718232][D][ZigbeeCore.cpp:494] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
21:55:53.116 -> [718233][D][ZigbeeCore.cpp:495] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
21:55:53.116 ->
APSDE INDICATION - src_addr_mode: 136, cluster_id: 0xef00, asdu_length: 5
21:55:53.116 ->
APSDE INDICATION - dst_short_addr: 0x0000, src_short_addr: 0x0388
21:55:53.116 ->
APSDE INDICATION - profile_id: 0x0104, security_status: 0, lqi: 0, rx_time: 0
21:55:53.116 -> [718234][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 11
21:55:53.116 -> [718235][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
21:55:53.116 -> [718235][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
21:55:53.116 -> [718236][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
21:55:53.116 -> [718236][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 7 size: 2
21:55:53.116 -> [718237][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
21:55:53.116 -> [718237][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x388, 0x388, 0x0, 0x0
21:55:53.116 -> [718238][I][z2s_devices_table.cpp:3933] Z2S_onCustomCmdReceive(): A4:C1:38:E8:22:60:0F:B4, endpoint 0x1, cluster 0xef00, cmd id 0xb
21:55:53.116 -> [718238][I][z2s_devices_table.cpp:161] Z2S_findChannelNumberSlot(): A4:C1:38:E8:22:60:0F:B4, endpoint 0x1, channel type 0xffffffff
21:55:53.116 -> [718239][I][z2s_devices_table.cpp:3943] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x3
21:55:53.116 -> [718240][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
21:55:53.116 -> [718240][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1005) callback
21:55:53.116 -> [718241][V][ZigbeeHandlers.cpp:388] zb_cmd_default_resp_handler(): Received default response: from address(0x388), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x0) with status 0x0
21:55:53.116 -> [718242][V][ZigbeeHandlers.cpp:392] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
21:55:53.116 -> [718242][I][ZigbeeGateway.cpp:2619] zbCmdDefaultResponse(): tsn = 213, _custom_cmd_last_tsn = 213, _custom_cmd_last_tsn_flag = 2
21:55:53.116 -> [718243][I][ZigbeeGateway.cpp:2634] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 213, _custom_cmd_last_tsn_flag = 2
21:55:53.116 -> [718244][I][ZigbeeGateway.cpp:2637] zbCmdDefaultResponse(): custom cmd rssi 297795584
21:55:53.194 -> [718342][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
21:55:53.194 -> [718342][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
21:55:53.240 -> [718343][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
21:55:53.332 -> [718452][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
21:55:53.332 -> [718452][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
21:55:53.332 -> [718453][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
21:55:53.641 -> [718762][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
21:55:53.641 -> [718762][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
21:55:53.641 -> [718763][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
21:55:53.724 -> [718872][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
21:55:53.766 -> [718872][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
21:55:53.766 -> [718873][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
21:55:53.897 -> [719045][I][Z2S_trv_interface.cpp:1329] iterateAlways(): TRV child lock difference detected hvac = 0, trv = 255
21:55:53.897 -> [719046][I][Z2S_trv_interface.cpp:944] sendTRVChildLock(): Z2S_TRVInterface::sendTRVChildLock = 0
21:55:53.935 -> [719047][I][ZigbeeGateway.cpp:2211] sendAttributeWrite(): Sending 'write attribute' command - id (0x0), type (0x10), size (0x1), value (0x0)
21:55:54.077 -> [719182][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
21:55:54.077 -> [719182][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
21:55:54.077 -> [719183][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
21:55:54.169 -> [719292][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
21:55:54.169 -> [719292][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
21:55:54.169 -> [719293][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
21:55:54.300 -> [719448][I][ZigbeeGateway.cpp:2114] sendAttributeRead(): Sending 'read attribute' command
21:55:54.481 -> [719602][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
21:55:54.481 -> [719602][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
21:55:54.481 -> [719603][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
21:55:54.520 -> [719649][I][Z2S_trv_interface.cpp:1350] iterateAlways(): setpoint difference detected: hvac = 2100, trv = 0
21:55:54.520 -> [719650][I][Z2S_trv_interface.cpp:159] sendTRVTemperatureSetpoint(): Z2S_TRVInterface::sendTRVTemperatureSetpoint = 2100
21:55:54.520 -> [719651][I][ZigbeeGateway.cpp:2211] sendAttributeWrite(): Sending 'write attribute' command - id (0x12), type (0x29), size (0x2), value (0x34)
21:55:54.604 -> [719712][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
21:55:54.604 -> [719712][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
21:55:54.604 -> [719713][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
21:55:54.714 -> [719851][I][ZigbeeGateway.cpp:2114] sendAttributeRead(): Sending 'read attribute' command
21:55:54.901 -> [720022][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
21:55:54.901 -> [720022][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
21:55:54.901 -> [720023][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
21:55:54.948 -> [720051][I][Z2S_trv_interface.cpp:1361] iterateAlways(): trv mode difference detected: hvac=2, trv=0
21:55:54.948 -> [720052][I][Z2S_trv_interface.cpp:701] sendTRVSystemMode(): Z2S_TRVInterface::sendTRVMode = 1
21:55:54.948 -> [720053][I][ZigbeeGateway.cpp:2211] sendAttributeWrite(): Sending 'write attribute' command - id (0x1c), type (0x30), size (0x1), value (0x4)
21:55:54.984 -> [720132][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
21:55:54.984 -> [720132][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
21:55:55.026 -> [720133][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
21:55:55.120 -> [720253][I][Z2S_trv_interface.cpp:1388] iterateAlways(): _trv_external_sensor_detection_enabled = 1
21:55:55.120 ->
_trv_external_sensor_present = 0
21:55:55.120 ->
21:55:55.120 -> [720254][I][Z2S_trv_interface.cpp:1474] iterateAlways():
21:55:55.120 ->
_trv_fixed_temperature_calibration 0
21:55:55.120 ->
_trv_temperature_calibration 0
21:55:55.120 ->
_trv_fixed_temperature_calibration_updated 0
21:55:55.120 -> [720261][I][Z2S_trv_interface.cpp:1329] iterateAlways(): TRV child lock difference detected hvac = 0, trv = 255
21:55:55.120 -> [720261][I][Z2S_trv_interface.cpp:944] sendTRVChildLock(): Z2S_TRVInterface::sendTRVChildLock = 0
21:55:55.339 -> [720442][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
21:55:55.339 -> [720442][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
21:55:55.339 -> [720443][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
21:55:55.339 -> [720461][I][ZigbeeGateway.cpp:2673] sendCustomClusterCmd(): _custom_cmd_last_tsn = 219
21:55:55.431 -> [720552][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
21:55:55.431 -> [720552][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
21:55:55.431 -> [720553][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
21:55:55.570 -> [720661][I][ZigbeeGateway.cpp:2681] sendCustomClusterCmd(): _custom_cmd_last_tsn_flag = 2
21:55:55.570 -> [720662][I][Z2S_trv_interface.cpp:1361] iterateAlways(): trv mode difference detected: hvac=2, trv=0
21:55:55.570 -> [720663][I][Z2S_trv_interface.cpp:701] sendTRVSystemMode(): Z2S_TRVInterface::sendTRVMode = 1
21:55:55.772 -> [720862][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
21:55:55.772 -> [720862][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
21:55:55.772 -> [720863][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
21:55:55.772 -> [720865][I][ZigbeeGateway.cpp:2673] sendCustomClusterCmd(): _custom_cmd_last_tsn = 220
21:55:55.818 -> [720898][D][ZigbeeCore.cpp:494] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
21:55:55.818 -> [720899][D][ZigbeeCore.cpp:495] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
21:55:55.818 ->
21:55:55.818 ->
21:55:55.818 ->
21:55:55.818 -> [720901][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 11
21:55:55.818 -> [720901][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
21:55:55.818 -> [720902][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
21:55:55.818 -> [720902][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
21:55:55.818 -> [720903][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 14 size: 2
21:55:55.818 -> [720903][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
21:55:55.818 -> [720904][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x388, 0x388, 0x0, 0x0
21:55:55.818 -> [720904][I][z2s_devices_table.cpp:3933] Z2S_onCustomCmdReceive(): A4:C1:38:E8:22:60:0F:B4, endpoint 0x1, cluster 0xef00, cmd id 0xb
21:55:55.818 -> [720905][I][z2s_devices_table.cpp:161] Z2S_findChannelNumberSlot(): A4:C1:38:E8:22:60:0F:B4, endpoint 0x1, channel type 0xffffffff
21:55:55.818 -> [720906][I][z2s_devices_table.cpp:3943] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x3
21:55:55.818 -> [720906][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
21:55:55.818 -> [720907][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1005) callback
21:55:55.818 -> [720908][V][ZigbeeHandlers.cpp:388] zb_cmd_default_resp_handler(): Received default response: from address(0x388), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x0) with status 0x0
21:55:55.818 -> [720909][V][ZigbeeHandlers.cpp:392] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
21:55:55.818 -> [720909][I][ZigbeeGateway.cpp:2619] zbCmdDefaultResponse(): tsn = 219, _custom_cmd_last_tsn = 220, _custom_cmd_last_tsn_flag = 2
21:55:55.818 -> [720910][I][ZigbeeGateway.cpp:2634] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 219, _custom_cmd_last_tsn_flag = 2
21:55:55.818 -> [720910][I][ZigbeeGateway.cpp:2637] zbCmdDefaultResponse(): custom cmd rssi -1119879168
21:55:55.818 -> [720913][D][ZigbeeCore.cpp:494] zb_apsde_data_indication_handler(): APSDE INDICATION - Received APSDE-DATA indication, status: 0
21:55:55.818 -> [720914][D][ZigbeeCore.cpp:495] zb_apsde_data_indication_handler(): APSDE INDICATION - dst_endpoint: 1, src_endpoint: 1, dst_addr_mode: 255
21:55:55.818 ->
21:55:55.818 ->
21:55:55.818 ->
21:55:55.818 -> [720916][I][ZigbeeHandlers.cpp:138] zb_raw_cmd_handler(): cluster id: 0xef00, command id: 11
21:55:55.818 -> [720916][I][ZigbeeHandlers.cpp:141] zb_raw_cmd_handler(): src endpoint (0x1, dst endpoint 0x1
21:55:55.818 -> [720917][I][ZigbeeHandlers.cpp:145] zb_raw_cmd_handler(): is common comand 1, disable_default_response 1, is_manuf_specific 0
21:55:55.818 -> [720917][I][ZigbeeHandlers.cpp:149] zb_raw_cmd_handler(): manuf_specific 0x0
21:55:55.818 -> [720917][I][ZigbeeHandlers.cpp:153] zb_raw_cmd_handler(): RAW bufid: 49 size: 2
21:55:55.818 -> [720918][I][ZigbeeHandlers.cpp:156] zb_raw_cmd_handler(): 0x00
21:55:55.818 -> [720919][I][ZigbeeHandlers.cpp:165] zb_raw_cmd_handler(): ZigbeeHandlers rawCMD 0x388, 0x388, 0x0, 0x0
21:55:55.818 -> [720919][I][z2s_devices_table.cpp:3933] Z2S_onCustomCmdReceive(): A4:C1:38:E8:22:60:0F:B4, endpoint 0x1, cluster 0xef00, cmd id 0xb
21:55:55.818 -> [720920][I][z2s_devices_table.cpp:161] Z2S_findChannelNumberSlot(): A4:C1:38:E8:22:60:0F:B4, endpoint 0x1, channel type 0xffffffff
21:55:55.818 -> [720920][I][z2s_devices_table.cpp:3943] Z2S_onCustomCmdReceive(): z2s_channels_table[channel_number_slot].Supla_channel 0x3
21:55:55.818 -> [720921][I][ZigbeeHandlers.cpp:191] zb_raw_cmd_handler(): ----------------------------raw command not processed------------------------------------------------------------
21:55:55.818 -> [720922][I][ZigbeeHandlers.cpp:42] zb_action_handler(): Receive Zigbee action(0x1005) callback
21:55:55.818 -> [720922][V][ZigbeeHandlers.cpp:388] zb_cmd_default_resp_handler(): Received default response: from address(0x388), src_endpoint(1) to dst_endpoint(1), cluster(0xef00) for command (0x0) with status 0x0
21:55:55.818 -> [720923][V][ZigbeeHandlers.cpp:392] zb_cmd_default_resp_handler(): command id (11), direction (1), is common (1)
21:55:55.818 -> [720924][I][ZigbeeGateway.cpp:2619] zbCmdDefaultResponse(): tsn = 220, _custom_cmd_last_tsn = 220, _custom_cmd_last_tsn_flag = 2
21:55:55.818 -> [720925][I][ZigbeeGateway.cpp:2634] zbCmdDefaultResponse(): zbCustomCmd default response async, tsn = 220, _custom_cmd_last_tsn_flag = 2
21:55:55.818 -> [720925][I][ZigbeeGateway.cpp:2637] zbCmdDefaultResponse(): custom cmd rssi -1149239296
21:55:55.866 -> [720972][V][esp32-hal-rmt.c:490] rmtInit(): GPIO 8 - TX MODE - MemSize[48] - Freq=10000000Hz
21:55:55.866 -> [720972][V][esp32-hal-rmt.c:307] _rmtWrite(): GPIO: 8 - Request: 24 RMT Symbols - Blocking - Timeout: -1
21:55:55.866 -> [720972][V][esp32-hal-rmt.c:315] _rmtWrite(): GPIO: 8 - Currently in Loop Mode: [NO] | Loop Request: [NO], LoopCancel: [NO]
21:55:55.942 -> [721065][I][ZigbeeGateway.cpp:2681] sendCustomClusterCmd(): _custom_cmd_last_tsn_flag = 2
21:55:55.942 -> [721066][I][Z2S_trv_interface.cpp:1388] iterateAlways(): _trv_external_sensor_detection_enabled = 1
21:55:55.942 ->
21:55:55.942 ->
21:55:55.942 -> [721067][I][Z2S_trv_interface.cpp:1474] iterateAlways():
21:55:55.942 ->
21:55:55.942 ->
21:55:55.942 ->
21:55:55.942 -> [721068][I][Z2S_trv_interface.cpp:1388] iterateAlways(): _trv_external_sensor_detection_enabled = 1
21:55:55.942 ->
21:55:55.942 ->
21:55:55.942 -> [721069][I][Z2S_trv_interface.cpp:1474] iterateAlways():
21:55:55.942 ->
21:55:55.942 ->
21:55:55.942 ->
21:55:55.942 -> [721070][I][Z2S_trv_interface.cpp:1388] iterateAlways(): _trv_external_sensor_detection_enabled = 1
21:55:55.942 ->
