W .env tryb proxy
W cloud domain ma być tylko TwojaDomena.pl bez portu
effendi_pl
env
docker ps
NPM
nadal 502
GNU nano 7.2 .env
# Where the SUPLA Cloud will be accessible? Put domain or IP address here with port.
CLOUD_DOMAIN=xxx.xxx.org
# Initial user account details; delete these settings after the first launch
[email protected]
FIRST_USER_PASSWORD=xxx
# Google ReCaptcha settings
RECAPTCHA_ENABLED=false
RECAPTCHA_PUBLIC_KEY=
RECAPTCHA_PRIVATE_KEY=
# Mailer settings
# For Gmail as a transport, use: "gmail://username:password@localhost"
# For a generic SMTP server, use: "smtp://localhost:25?encryption=&auth_mode="
# With username and password, use: "smtp://username:password@localhost:25?encryption=&auth_mode="
MAILER_DSN=null://null
MAILER_FROM=
# If you want to be notified about some server errors, set this
[email protected]
# Where to store SUPLA Cloud's data
VOLUME_DATA=./var
# On which ports the SUPLA Cloud should listen (only if standalone mode)
PORT_HTTP=80
PORT_HTTPS=443
REQUIRE_REGULATIONS_ACCEPTANCE=false
REQUIRE_COOKIE_POLICY_ACCEPTANCE=false
BRUTE_FORCE_AUTH_PREVENTION_ENABLED=true
ACCOUNTS_REGISTRATION_ENABLED=true
# MQTT Broker settings (you have to run the broker yourself)
MQTT_BROKER_ENABLED=true
MQTT_BROKER_HOST=xxx
MQTT_BROKER_PORT=1883
MQTT_BROKER_TLS=false
MQTT_BROKER_USERNAME=xx
MQTT_BROKER_PASSWORD=xxx
MQTT_BROKER_CLIENT_ID=supla
# These options protect your application
DB_PASSWORD=yejrqCU3Fxz4OHCvRA3MVtnEvsZ2ZloX
SECRET=cv5Er8Ndg2IxgZEdIZVfCRZe6Uxo5wJw
COMPOSE_PROJECT_NAME=supla
COMPOSE_PATH_SEPARATOR=:
COMPOSE_FILE=docker-compose.yml:docker-compose.proxy.yml:docker-compose.arm32v7.yml
supla/supla-cloud:arm32v7 "docker-php-entrypoi…" 3 minutes ago Up 3 minutes (healthy) 80/tcp
http://supla-cloud:80
effendi_pl
czy ten wpis powinien wskazywać na katalog z supla-docker/var?
VOLUME_DATA=./var-
effendi_pl
Wielkie THX dla @lesny8, zaczarował na backstage ... i działa!!!
Podsumowując.... potencjalnych problemów było kilka
1. Domena nie wskazywała na lokalny adres IP serwera (nie jest to konieczne, ale przy braku internetu pomaga rozwiązywać nazwę i kierować ruch gdzie trzeba). Wpis lokalny dodany na PiHole.
2. NPM nie był podpięty do sieci webproxy - główna przyczyna.
3. SUPLA_PROTOCOL zmieniony na https, bez tej zmiany nie chciał się wczytać Cloud przy konfiguracji SSL w NPM. Bez SSL Cloud się wczytywał.
4. Chrome czytał stronę cały czas z cachu, nawet w trybie incognito. Dopiero po wyczyszczeniu całego cachu zaczęło działać także w Chrome.
Tyle z księgi czarów
SOP 2023
SOP 2024
cz->b
+ila
SOP 2024
