how to change nodemcu host name
Mirageiot
how can i chage the wifi name it 's called esp8266xxxx i wan to change it to something else
i'm trying to find the specific file in the supla iot sdk (virtual machine)
Mirageiot
I have changed it but nothing happend
You can check if this define is added in some other place of your board source files.
Name from link provided by pzygmunt is taken only if that define is not declared earlier in your file.
Btw. do you want to change "host name" or "wifi name"?
Mirageiot
i want to change the host name
Mirageiot wrote: Thu Mar 31, 2022 10:00 am i want to change the host name
Hostname (i.e. name visible on DHCP server on router) is configured here:
https://github.com/SUPLA/supla-espressi ... ain.c#L220
Current implementation set it to the same name as Wi-Fi SSID of AP when device is in config mode.
Return to “General discussion”
