Zamel ROW-02m operation
David C
I've a query about Zamel ROW-02m operation.
I have one I'm testing now, but I've found an issue.
If the "IN" trigger inputs are set to bistable, for use with a normal switch, if you trigger it via WiFi it reverses the operation of the switch.
ie instead of the switch turning the relay on, it turns it off.
If you power reset the ROW-02m it returns to normal.
My hope was that if after turning the relay on with the switch, you turned it off via WiFi, that when you turned the switch off the relay would stay off until turned on again with the switch.
Firmware is the latest 2.8.50
The input always works as TOGGLE.
David C
pzygmunt wrote: Wed May 18, 2022 8:31 pm The input always works as TOGGLE.
Thank you, yes that explains it and that is exactly what I'd seen.
This was an extra thought I'd had to make use of the 2nd relay, my main reason for buying it is unaffected.
Thanks again for replying so quickly.
Return to “Help”
