Tuya-convert
Has thanked: 3 times
Been thanked: 3 times
Cześć,
potrzebuje pomocy z tuya-convert. Jestem zielony z linuxa ale poszedłem po linii instrukcji znalezionych na tym forum i innych internetach.
  1. Zainstalowałem Ubuntu 22.04 LTS
  2. Zainstalowałem wszystkie sugerowane aktualizacje
  3. W terminalu wykonałem polecenia:
    1. sudo apt-get update
    2. sudo apt-get upgrade
    3. sudo apt-get install git
    4. git clone https://github.com/ct-Open-Source/tuya-convert
    5. cd tuya-convert
    6. sudo ./install_prereq.sh
    7. sudo ./start_flash.sh
Po tym wszystkim (i po wielu róznych komunikatach instalacyjnych) dostałem takie coś:
fatal: unsafe repository ('/home/ja/tuya-convert' is owned by someone else)
To add an exception for this directory, call:
	git config --global --add safe.directory /home/****/tuya-convert
tuya-convert
TUYA-CONVERT
TUYA-CONVERT was developed by Michael Steigerwald from the IT security company VTRUST (https://www.vtrust.de/) in collaboration with the techjournalists Merlin Schumacher, Pina Merkert, Andrijan Moecker and Jan Mahn at c't Magazine. (https://www.ct.de/)
PLEASE READ THIS CAREFULLY!
TUYA-CONVERT creates a fake update server environment for ESP8266/85 based tuya devices. It enables you to backup your devices firmware and upload an alternative one (e.g. ESPEasy, Tasmota, Espurna) without the need to open the device and solder a serial connection (OTA, Over-the-air).
Please make sure that you understand the consequences of flashing an alternative firmware, since you might lose functionality!
Flashing an alternative firmware can cause unexpected device behavior and/or render the device unusable. Be aware that you do use this software at YOUR OWN RISK! Please acknowledge that VTRUST and c't Magazine (or Heise Medien GmbH & Co. KG) CAN NOT be held accountable for ANY DAMAGE or LOSS OF FUNCTIONALITY by typing yes + Enter
Cleaning up...
No screen session found.
Closing AP
Exiting...
i nic się nie dzieje :(
Prośba do bardziej zaawansowanych linuxusers możecie podpowiedzieć o co chodzi i czego nie zrobiłem?
Has thanked: 135 times
Wpisałeś: "yes" i nacisnąłeś enter zgodnie z poleceniem na ekranie?
klew wrote: Tue Jun 21, 2022 7:11 pm Wpisałeś: "yes" i nacisnąłeś enter zgodnie z poleceniem na ekranie?
no faktycznie z rozpędu po prostu walnałem enter ale .... to nic nie zmieniło poza komunikatem, że brakuje wlan0 ale nie wiem o co chodzi i co zmienic/wprowadzic:
ja@ja-ko:~/tuya-convert$ sudo ./start_flash.sh
	git config --global --add safe.directory /home/ja/tuya-convert
tuya-convert
TUYA-CONVERT
yes
Checking for network interface wlan0... Not found!
Please edit WLAN in config.txt to one of: docker0, enp2s0, lo, wlp3s0
Cleaning up...
Closing AP
Exiting...
Yepestis
Has thanked: 19 times
Masz wi-fi w tym komputerze? Wlan0 to bezprzewodowa karta sieciowa, albo jej nie masz albo brakuje Ci sterowników do niej.
Yepestis wrote: Tue Jun 21, 2022 7:27 pm Masz wi-fi w tym komputerze? Wlan0 to bezprzewodowa karta sieciowa, albo jej nie masz albo brakuje Ci sterowników do niej.
no właśnie z tego komputeraz tutaj piszę ;) .... i jestem na wifi
Yepestis
Nie możesz być połączony z żadną siecią jak uruchamiasz tuya-convert
Może też być tak że Twoja karta sieciowa nie jest wspierana
On szuka interfejsu karty sieciowej wlan0 (to najczęściej używaną nazwa na wifi pod Linuxem). Ty nie masz takiego interfejsu więc prosi abyś edytował plik config.txt i podał nazwę interfejsu Wi-Fi Twojego komputera.
Wpisz polecenie: ifconfig i poszukaj przy którym interfejsie jest Twój adres IP - następnie podaj tą nazwę w pliku config
Yepestis wrote: Tue Jun 21, 2022 8:04 pm Nie możesz być połączony z żadną siecią jak uruchamiasz tuya-convert
może tak być bo odłączenie od sieci nic nie zmieniło
s_pol
Wydaje mi się, że twoja karta wifi nie ma możliwości przełączania się w tryb AP.
Tuya-convert tworzy sieć o nazwie "vtrust-flash".
Kwicol
Witam.
A można ustawić nazwę sieci w routerze vtrust-flash i robić to w sieci lokalnej po lan ?
edit:
Oczywiście router nie może mieć internetu żeby urządzenie nie pobrało najnowszego softu.Się pobawie w wolnej chwili jeśli nikt tego nie próbował.Wydaje mi się że wystarczy po mac adresie dhcp na sztywno ustawić np. gniazdko na 10.42.42.42 itp. itd.
