Is there any support for potentiometer as an input channel
For example dimming a light bulb or rgb?
Potentiometer
elmaya
using a potentiometer in those cases doesn't make sense.
You will not be able to set the level from the cloud/App and the potentiometer.
have you considered a rotary encoder?
Antonio
Hello @elmayaelmaya wrote: Sat Jul 09, 2022 12:49 pm using a potentiometer in those cases doesn't make sense.
You have an idea how to apply such control via encoder to cloud for remote dimmer ?. This increased functionality
ritual
I don't have any experience with rotary encoder,i will check it out.elmaya wrote: Sat Jul 09, 2022 12:49 pm using a potentiometer in those cases doesn't make sense.
Do action triggers support rotary encoder?
ritual
I haven't come accross any firmware for rotary encoder in supla.elmaya wrote: Sat Jul 09, 2022 12:49 pm using a potentiometer in those cases doesn't make sense.
Are there any firmware available for it?
