Problemy z DHCP
Misiektt
Hej,
Od początku używam NETGEAR Orbi, system działa ale urządzenia co jakiś czas gubią DHCP widać to po tym :
[DHCP IP: (192.168.2.28)] to MAC address 9B:0D:59, Tuesday, Sep 13,2022 07:41:41
[DHCP IP: (192.168.2.26)] to MAC address 14:B6:70, Tuesday, Sep 13,2022 07:41:39
[DHCP IP: (192.168.2.17)] to MAC address 07:D7:A8, Tuesday, Sep 13,2022 07:41:38
[DHCP IP: (192.168.2.10)] to MAC address AC:43:7B, Tuesday, Sep 13,2022 07:41:36
[DHCP IP: (192.168.2.27)] to MAC address D6:E6:74, Tuesday, Sep 13,2022 07:41:35
[DHCP IP: (192.168.2.14)] to MAC address 13:C7:2C, Tuesday, Sep 13,2022 07:41:32
[DHCP IP: (192.168.2.19)] to MAC address 14:5E:74, Tuesday, Sep 13,2022 07:41:29
[DHCP IP: (192.168.2.21)] to MAC address B0:CA:2C, Tuesday, Sep 13,2022 07:41:24
[DHCP IP: (192.168.2.15)] to MAC address 87:B0:7D, Tuesday, Sep 13,2022 07:39:31
[DHCP IP: (192.168.2.16)] to MAC address 5B:4F:E8, Tuesday, Sep 13,2022 07:39:30
[DHCP IP: (192.168.2.13)] to MAC address B4:0F:EB, Tuesday, Sep 13,2022 07:39:23
[DHCP IP: (192.168.2.12)] to MAC address 89:3F:EE, Tuesday, Sep 13,2022 07:39:23
[DHCP IP: (192.168.2.18)] to MAC address D6:A9:DA, Tuesday, Sep 13,2022 07:38:01
[DHCP IP: (192.168.2.34)] to MAC address 99:DF:5D, Tuesday, Sep 13,2022 07:33:46
[DHCP IP: (192.168.2.33)] to MAC address 9A:EC:32, Tuesday, Sep 13,2022 07:33:04
[DHCP IP: (192.168.2.22)] to MAC address 92:9F:DB, Tuesday, Sep 13,2022 07:31:31
[DHCP IP: (192.168.2.20)] to MAC address 5A:32:72, Tuesday, Sep 13,2022 07:31:01
[DHCP IP: (192.168.2.23)] to MAC address A5:30:AB, Tuesday, Sep 13,2022 07:29:27
[DHCP IP: (192.168.2.24)] to MAC address D3:EA:62, Tuesday, Sep 13,2022 07:28:21
[DHCP IP: (192.168.2.25)] to MAC address AC:69:82, Tuesday, Sep 13,2022 07:28:03
[DHCP IP: (192.168.2.11)] to MAC address B0:CA:D1, Tuesday, Sep 13,2022 07:28:01
[DHCP IP: (192.168.2.35)] to MAC address D2:91:3C, Tuesday, Sep 13,2022 07:26:41
[DHCP IP: (192.168.2.28)] to MAC address 9B:0D:59, Tuesday, Sep 13,2022 07:26:34
[DHCP IP: (192.168.2.26)] to MAC address 4:B6:70, Tuesday, Sep 13,2022 07:26:32
[DHCP IP: (192.168.2.17)] to MAC address 07:D7:A8, Tuesday, Sep 13,2022 07:26:31,.
[DHCP IP: (192.168.2.22)] to MAC address 92:9F:DB, Tuesday, Sep 13,2022 07:26:29
[DHCP IP: (192.168.2.10)] to MAC address AC:43:7B, Tuesday, Sep 13,2022 07:26:28
[DHCP IP: (192.168.2.27)] to MAC address D6:E6:74, Tuesday, Sep 13,2022 07:26:27
[DHCP IP: (192.168.2.14)] to MAC address 13:C7:2C, Tuesday, Sep 13,2022 07:26:24
[DHCP IP: (192.168.2.19)] to MAC address 14:5E:74, Tuesday, Sep 13,2022 07:26:22
I tak w kółko, do tego stopnia zaśmieca to tablicę DHCP że urządzenia Appla przestają się łączyć, adresy MAC celowo skróciłem żeby nie publikować
klimasstudio
Pokaż config serwera DHCP w urządzeniu.
Misiektt wrote: Tue Sep 13, 2022 8:11 am Hej,
Co oznaczają te komunikaty? To jest przydzielnie adresu IP dla urządzenia?
Jeśli tak, to raczej nie widać tu niczego bardzo problematycznego. Np. urządzenie "D6:E6:74" dostaje za każdym razem ten sam adres IP, więc nic nie powinno "zaśmiecać".
O jakich urządzeniach mówimy? Jaką wersję oprogramowania tam masz?
Jaki masz czas dzierżawy adresu IP w serwerze DHCP ustawiony?
Misiektt
Problem w tym że urządzenie nie powinno co parę minut pytać o adres, wszystkie urządzenia są na 2.8.51 RNW ROW SRW i inne, żadne inne urządzenia tak z DHCP nie wariują
Misiektt wrote: Tue Sep 13, 2022 8:48 am Problem w tym że urządzenie nie powinno co parę minut pytać o adres, wszystkie urządzenia są na 2.8.51 RNW ROW SRW i inne, żadne inne urządzenia tak z DHCP nie wariują
Oczywiście, że nie powinno. Czy te 22 urządzenia, które widać w Twoich logach, to wszystkie są Supla Zamel?
Jak wejdziesz w aplikacji na telefonie i klikniesz na ikonę (i) to jaki jest "czas pracy" i "czas połączenia"?
Jak masz skonfigurowany serwer DHCP? A w szczególności jaki masz czas dzierżawy adresu?
Od jak dawna masz te urządzenia? Kiedy zauważyłeś problem?
Misiektt
Czas pracy jest 2 godziny ale tutaj widać że połączenie się nie zrywa bo zmieniłem ustawienia. Urządzeń mam 35 na osobnej podsieci bo siały.
Niestety rooter nie ma ustawień dhcp lease więc nie powiem ale tylko suple wariują, 20 innych urządzeń nie ma problemu :(
Misiektt wrote: Tue Sep 13, 2022 9:28 am Czas pracy jest 2 godziny ale tutaj widać że połączenie się nie zrywa bo zmieniłem ustawienia. Urządzeń mam 35 na osobnej podsieci bo siały.
A jakie ustawienia ma serwer DHCP u Ciebie? Możesz wrzucić zrzut ekranu.
Jaki czas pracy i połączenia pokazuje jakieś przykładowe urządzenie Supli?
Misiektt
Nie ma co wrzucać - start ip end ip i tyle :( ale niestety jak DHCP miałem z rootera innego sytuacja była ta sama moim zdaniem coś jest nie tak w pakietach ale niestety i na rooterze i na supli logów nie widzę i nie mam dostępu do konsoli żeby analizować co się dzieje. Może jakieś podstawy z jakiej wersji DHCP korzysta supla albo jakieś założenia które dam do producenta rootea - netgear i sprawdzą u siebie - nie mam pojęcia.
Misiektt
I nie wiem kto co ostatnio zmienił ale jak na cloud.supla.org zmieniam coś w jednym urządzeniu to resetują się wszystkie. To nie jest za mądre rozwiązanie,.
Misiektt wrote: Tue Sep 13, 2022 10:56 am I nie wiem kto co ostatnio zmienił ale jak na cloud.supla.org zmieniam coś w jednym urządzeniu to resetują się wszystkie. To nie jest za mądre rozwiązanie,.
Tak to było od zawsze. Pewnie kiedyś pojawią się jakieś usprawnienia w tej kwestii.
