Błąd przy generowaniu
cinas
Has thanked: 3 times
Been thanked: 7 times
Witam , usiłuję wygenerować soft czy dla esp32 czy 8266 wywala jakieś błędy
Błąd generowania
GUI-Generic_bv4.21_gv5.2.10_pl_38dd650f3eb69347c11e6bb6cb3dd449/src/network/SuplaGuiWiFi.cpp: In member function 'virtual void Supla::GUIESPWifi::setup()':
GUI-Generic_bv4.21_gv5.2.10_pl_38dd650f3eb69347c11e6bb6cb3dd449/src/network/SuplaGuiWiFi.cpp:66:10: error: 'class WiFiClass' has no member named 'setSleepMode'; did you mean 'setSleep'?
WiFi.setSleepMode(WIFI_NONE_SLEEP);
setSleep
GUI-Generic_bv4.21_gv5.2.10_pl_38dd650f3eb69347c11e6bb6cb3dd449/src/network/SuplaGuiWiFi.cpp:66:23: error: 'WIFI_NONE_SLEEP' was not declared in this scope
GUI-Generic_bv4.21_gv5.2.10_pl_38dd650f3eb69347c11e6bb6cb3dd449/src/network/SuplaGuiWiFi.cpp:66:23: note: suggested alternative: 'WIFI_MODE_AP'
WIFI_MODE_AP
Error during build: exit status 1
xxxxxxxxxxxxxxxxxx
BOARD esp32:esp32:d32:PartitionScheme=min_spiffs
BOARD_NAME
TEMPLATE_JSON
JSON_DEFINITION
OPTIONS -DATOMIC_FS_UPDATE -DBEARSSL_SSL_BASIC -DSUPLA_ACTION_TRIGGER -DSUPLA_BUTTON -DSUPLA_CONFIG -DSUPLA_ENABLE_GUI -DSUPLA_IMPULSE_COUNTER -DSUPLA_OTA
-DSUPLA_PUSHOVER
Been thanked: 5 times
zobacz teraz.
gbiel
To samo u mnie :
GUI-Generic_bv4.21_gv5.3.0_pl_c7e0ea9e0564a988452d64139aa8aaa5/SuplaWebPageControl.cpp: In function 'void handleButtonSet(int)':
GUI-Generic_bv4.21_gv5.3.0_pl_c7e0ea9e0564a988452d64139aa8aaa5/SuplaWebPageControl.cpp:288:63: error: 'S_CONDITION' was not declared in this scope; did you mean 'S_CORRECTION'?
  288 |         addNumberBox(webContentBuffer, INPUT_ANALOG_EXPECTED, S_CONDITION, "0", false,
      |                                                               S_CORRECTION
Multiple libraries were found for "SoftwareSerial.h"
  Used: .arduino15/packages/esp8266/hardware/esp8266/3.0.2/libraries/SoftwareSerial
  Not used: /var/www/html/github/GUI-Generic/lib/espsoftwareserial
xxxxxxxxxxxxxxxxxx
BOARD esp8266:esp8266:generic:eesz=1M64,xtal=160
BOARD_NAME
TEMPLATE_JSON
JSON_DEFINITION
OPTIONS -DATOMIC_FS_UPDATE -DBEARSSL_SSL_BASIC -DSUPLA_BUTTON -DSUPLA_CONFIG -DSUPLA_DHT22 -DSUPLA_ENABLE_GUI -DSUPLA_LED -DSUPLA_LIMIT_SWITCH -DSUPLA_OTA
-DSUPLA_RELAY
cinas
Dziś wygenerowało bez problemu
Return to “GUI Generic”
