Wziąłem gotowy przykład roller shutter z biblioteki supli na arduino. Mogę uruchomić jedynie 11 szt rolet. Przy próbie dodania 12 rolety tracę komunikację z cloudem.
Poniżej wklejam kod. Może ktoś ma pomysł w czym może być problem?
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
#include <SuplaDevice.h>
#include <supla/control/roller_shutter.h>
#include <supla/control/pin_status_led.h>
// Choose where Supla should store roller shutter data in persistant memory
// We recommend to use external FRAM memory
#define STORAGE_OFFSET 100
Supla::Eeprom eeprom(STORAGE_OFFSET);
// #include <supla/storage/fram_spi.h>
// Supla::FramSpi fram(STORAGE_OFFSET);
// Choose proper network interface for your card:
#ifdef ARDUINO_ARCH_AVR
// Arduino Mega with EthernetShield W5100:
#include <supla/network/ethernet_shield.h>
// Ethernet MAC address
Supla::EthernetShield ethernet(mac);
// Arduino Mega with ENC28J60:
// #include <supla/network/ENC28J60.h>
// Supla::ENC28J60 ethernet(mac);
#elif defined(ARDUINO_ARCH_ESP8266) || defined(ARDUINO_ARCH_ESP32)
// ESP8266 and ESP32 based board:
Supla::ESPWifi wifi("your_wifi_ssid", "your_wifi_password");
#endif
void setup() {
Serial.begin(115200);
char GUID[SUPLA_GUID_SIZE] = {0xBC,0x08,0x26,0xF7,0x86,0x53,0x59,0xDB,0xCE,0x3A,0x5};
char AUTHKEY[SUPLA_AUTHKEY_SIZE] = {0xEA,0xF6,0x11,0x46,0x07,0x62,0xC7,0x47,0xAC,};
Supla::Control::RollerShutter *rs = new Supla::Control::RollerShutter(14, 15, true);
Supla::Control::RollerShutter *rs2 = new Supla::Control::RollerShutter(16, 17, true);
Supla::Control::RollerShutter *rs3 = new Supla::Control::RollerShutter(18, 19, true);
Supla::Control::RollerShutter *rs4 = new Supla::Control::RollerShutter(20, 21, true);
Supla::Control::RollerShutter *rs5 = new Supla::Control::RollerShutter(22, 23, true);
Supla::Control::RollerShutter *rs6 = new Supla::Control::RollerShutter(24, 25, true);
Supla::Control::RollerShutter *rs7 = new Supla::Control::RollerShutter(26, 27, true);
Supla::Control::RollerShutter *rs8 = new Supla::Control::RollerShutter(28, 29, true);
Supla::Control::RollerShutter *rs9 = new Supla::Control::RollerShutter(30, 31, true);
Supla::Control::RollerShutter *rs10 = new Supla::Control::RollerShutter(32, 33, true);
Supla::Control::RollerShutter *rs11 = new Supla::Control::RollerShutter(34, 35, true);
//Supla::Control::RollerShutter *rs12 = new Supla::Control::RollerShutter(46, 47, true);
//Supla::Control::Button *buttonOpen = new Supla::Control::Button(28, true, true);
//Supla::Control::Button *buttonClose = new Supla::Control::Button(29, true, true);
// Add two LEDs to inform about roller shutter relay status
// If inverted value is required, please add third parameter with true value
new Supla::Control::PinStatusLed(14, 13); // pin 30 status to be informed on pin 24
// new Supla::Control::PinStatusLed(39, 13); // pin 31 status to be informed on pin 25
//buttonOpen->addAction(Supla::OPEN_OR_STOP, *rs, Supla::ON_PRESS);
//buttonClose->addAction(Supla::CLOSE_OR_STOP, *rs, Supla::ON_PRESS);
* SuplaDevice Initialization.
* Server address is available at https://cloud.supla.org
"s.supla.org", // SUPLA server address
"[email protected]", // Email address used to login to Supla Cloud
void loop() {
SuplaDevice.iterate();
