Błąd generowania ESP32-C3
Duch__
Been thanked: 6 times
Błąd generowania
lib/SuplaDeviceExtensions/src/supla/sensor/AnalogReadingMap.cpp: In member function 'adc1_channel_t Supla::Sensor::AnalogRedingMap::get_adc1_chanel(uint8_t)':
lib/SuplaDeviceExtensions/src/supla/sensor/AnalogReadingMap.cpp:34:14: error: 'ADC1_CHANNEL_5' was not declared in this scope
       chan = ADC1_CHANNEL_5;
lib/SuplaDeviceExtensions/src/supla/sensor/AnalogReadingMap.cpp:34:14: note: suggested alternative: 'ADC1_CHANNEL_4'
              ADC1_CHANNEL_4
lib/SuplaDeviceExtensions/src/supla/sensor/AnalogReadingMap.cpp:37:14: error: 'ADC1_CHANNEL_6' was not declared in this scope
       chan = ADC1_CHANNEL_6;
lib/SuplaDeviceExtensions/src/supla/sensor/AnalogReadingMap.cpp:37:14: note: suggested alternative: 'ADC1_CHANNEL_4'
              ADC1_CHANNEL_4
lib/SuplaDeviceExtensions/src/supla/sensor/AnalogReadingMap.cpp:40:14: error: 'ADC1_CHANNEL_7' was not declared in this scope
       chan = ADC1_CHANNEL_7;
lib/SuplaDeviceExtensions/src/supla/sensor/AnalogReadingMap.cpp:40:14: note: suggested alternative: 'ADC1_CHANNEL_4'
              ADC1_CHANNEL_4
Error during build: exit status 1
xxxxxxxxxxxxxxxxxx
BOARD esp32:esp32:esp32c3:PartitionScheme=min_spiffs
BOARD_NAME
TEMPLATE_JSON
JSON_DEFINITION
OPTIONS -DATOMIC_FS_UPDATE -DBEARSSL_SSL_BASIC -DSUPLA_CONFIG -DSUPLA_ENABLE_GUI -DSUPLA_OTA
Zgłaszam
Goral64
Has thanked: 2 times
Nie ma urządzenia do testowania :(
Been thanked: 5 times
Duch__ wrote: Mon Dec 19, 2022 7:57 pm
Błąd generowania
              ADC1_CHANNEL_4
              ADC1_CHANNEL_4
              ADC1_CHANNEL_4
xxxxxxxxxxxxxxxxxx
BOARD_NAME
TEMPLATE_JSON
JSON_DEFINITION
Zgłaszam
Poprawiłem.
Duch__
W czasie wgrywania:
A tak się zgłasza w serialu po normalnym uruchomieniu:
22:27:04.905 -> ESP-ROM:esp32c3-api1-20210207
22:27:04.945 -> Build:Feb  7 2021
22:27:04.945 -> rst:0x1 (POWERON),boot:0xc (SPI_FAST_FLASH_BOOT)
22:27:04.945 -> SPIWP:0xee
22:27:04.945 -> mode:DIO, clock div:1
22:27:04.945 -> load:0x3fcd6268,len:0x1c4
22:27:04.945 -> load:0x3fcd642c,len:0x1aec
22:27:04.945 -> load:0x403ce000,len:0x700
22:27:04.945 -> load:0x403d0000,len:0x3ab0
22:27:04.945 -> entry 0x403ce000
22:27:04.985 -> 2nd stage bootloader v1.1
22:27:04.985 -> [Built]: 1.27.0 Jun 28 2022 08:43:22
22:27:05.185 -> wizclick state: 0, fav cnt: 1, pair cnt: 1, soft: 0, force mode: 0
22:27:05.185 -> current state: 1, scene: 11, temp: 2700, speed: 100, lumin: 100, red: 0, green: 0, blue: 0, warm: 255, cold: 0
A tak z BOOT zwartym do masy:
22:27:56.999 -> Build:Feb  7 2021
22:27:56.999 -> rst:0x1 (POWERON),boot:0x4 (DOWNLOAD(USB/UART0/1))
22:27:56.999 -> waiting for download
W czym problem?
Gdy dorabialiśmy pozostałe płytki ESP32 nie mieliśmy na stanie tej płytki więc zostało zrobione na czuja :) Prawdopodobnie trzeba wgrać do tej płytki innego bootloadera.
https://github.com/espressif/arduino-es ... sp32c3/bin
Patrząc po błędzie i logach z urządzenia, to tam nic się nie wgrało i ruszył stary program.
Może ta apka do wgrywania nie umie c3?
Builder nie umie wgrać takiej aplikacji a jedynie ją wygenerować. Trzeba ją wgrać ręcznie za pomocą najnowszego Flash Download Tools ale dodatkowo podmieniając prawdopodobnie bootlodera który pasuje dla tej płytki (ten wygenerowany z buildera prawdopodobnie jest błędny).
Duch__
Dodam że wczoraj robiłem próby wgrywania przez Flash download tool pod ESP32-C3, udało się, ale program wygenerowany w GGB nie uruchamia się. Zmienię bootlaoder i dam znać.
A to pacjent:
z tego wątku:
viewtopic.php?p=121445&hilit=WIZ#p121445
Duch__ wrote: Wed Dec 21, 2022 8:45 am Dodam że wczoraj robiłem próby wgrywania przez Flash download tool pod ESP32-C3, udało się, ale program wygenerowany w GGB nie uruchamia się.
Nie uruchomi się, przeczytaj post wyżej :)
Duch__
Ajj wyprzedziłeś mnie jak poprawiałem post :lol: Zmienię bootloader i dam znać.
Return to “GUI Generic”
