Próbowałem uruchomić supla-device-linux na raspberryPI wg instrukcji z tego posta:
viewtopic.php?t=10735
ale dostaje wciąż komunikat:
ERR[0.1680547348] Config file YAML error: bad file
INFO[0.1680547348] *** Starting supla-device ***
INFO[0.1680547348] Using config file etc/supla-device.yaml
ERR[0.1680547348] Config: "channels" section missing in file
ERR[0.1680547348] Loading channels failed. Exitmam umieszczony plik last_state.txt w /var/local/supla-device zgodnie z state_files_path w pliku etc/supla-device.yaml
plik supla-device.yaml ma sekcję channels
supa-device.yaml
# Example supla-device config file for Linux device
# https://github.com/SUPLA/supla-device
name: My fancy device
log_level: debug
state_files_path: "/var/local/supla-device"
security_level: 2 # disable certyficate verification
supla:
server: svr123.supla.org
mail: [email protected]
channels:
- type: VirtualRelay
name: vr1 # optional, can be used as reference for adding actions (TBD)
- type: Fronius
ip: 192.168.1.7
port: 80
device_id: 1
- type: ThermometerParsed
temperature: 0
multiplier: 1
parser:
type: Simple
refresh_time_ms: 200
source:
type: File
file: temp.txt
temperature: 3
multiplier: 1
parser:
use: parser_1
- type: ImpulseCounterParsed
counter: total_m3
multiplier: 1000
source:
type: File
file: "/var/log/wmbusmeters/meter_readings/water.json"
parser:
type: Json
- type: ElectricityMeterParsed
parser:
type: Json
source:
type: File
file: tauron.json
phase_1:
- voltage: voltage_at_phase_1_v
multiplier: 1
- fwd_act_energy: total_energy_consumption_tariff_1_kwh
multiplier: 1
- rvr_act_energy: total_energy_production_tariff_1_kwh
multiplier: 1
- power_active: current_power_consumption_kw
multiplier: 1000
- rvr_power_active: current_power_production_kw
multiplier: 1000
phase_2:
- voltage: voltage_at_phase_2_v
multiplier: 1
- fwd_act_energy: total_energy_consumption_tariff_2_kwh
multiplier: 1
- rvr_act_energy: total_energy_production_tariff_2_kwh
multiplier: 1
phase_3:
- voltage: voltage_at_phase_3_v
multiplier: 1
temperature: 0
source:
type: Cmd
# call sensors, take line with word "temp3", split it on ":" and return second
# value
command: "sensors | grep temp3 | cut -d : -f2"
parser:
type: Simple
- type: BinaryParsed
state: 1
parser:
use: parser_1Dzięki z góry za pomoc
