Hi am trying to connect a new VariLight dimmer switch but it fails when it reaches the point of setting up a temporary network.
Error of Incorrect Input Parameters appears every time and then left with Exit option only.
Photos attached with info.
Any help appreciated!!
James
Incorrect Input Parameters VariLight
JamesGareh
- Been thanked: 59 times
This is a bug in our app version 23.05.
The fix has already been uploaded to Google Play (v23.05.01) but is not available yet. You can also install the patch app by downloading the APK file.
https://drive.google.com/file/d/1hmb2a3 ... sp=sharing
You can also configure/add the dimmer manually. To do this, switch the dimmer to configuration mode. Then you need to connect to the wifi network of the dimmer and open http://192.168.4.1. Fill out the form there. You can read the server address needed to fill out the form in advance from cloud.supla.org (after logging in, click on the logo).
I see that v23.05.01 is now available on Google Play.
Upgrade and check if it works. You may have to remove the profile from the application and add it again after the update.
