Hello everybody.
I have a doubt, can I put 3 relays in the same channel in supla and control them independently?
Thanks in advance
Fredy
3 relays same channel
frmauricio
I want to control 3 relays on the same supla channel, just that.
You have few options:
1. Use one relay per channel and group them in Supla, so you can control group instead of single channel
2. You can write your own implementatiotion of Supla::Control::Relay class and make it control as many GPIOs as you want, then compile your program for your device and flash it.
- Has thanked: 37 times
- Been thanked: 27 times
You can also electrically connect 3 relays to one GPIO.
The author must specify what he wants to achieve.
frmauricio
Hello Klee,
How can I do the first option that you suggested?
One relay per channel and group in Supla
Thanks in advance
Thanks in advance
klew wrote: Tue Jun 27, 2023 8:26 am You have few options:
frmauricio
Thanks Robert
Robert Błaszczak wrote: Tue Jun 27, 2023 11:56 am You can also electrically connect 3 relays to one GPIO.
Channel grouping is available at Cloud. So basically you will have 3 separate Relay channels and in Cloud you can group them. Then in app you'll see it in "groups" tab and you can control them together (turn on/off all at once)frmauricio wrote: Fri Jun 30, 2023 2:39 am Hello Klee,
Thanks in advance
