Widziałem, że leciało coś od docker chyba plugin i zabrakło miejsca jak leciał update kernela.
./supla-docker/supla.sh start
Starting SUPLA containers
[+] Running 3/0
⠿ Container supla-server Running 0.0s
⠿ Container supla-db Started 0.0s
⠿ Container supla-cloud Started 0.0s
SUPLA containers has been started.
root@ubuntu-supla:~# docker logs --since=5m supla-cloud
In ConnectionFactory.php line 79:
An exception occured while establishing a connection to figure out your pla
tform version.
You can circumvent this by setting a 'server_version' configuration value
For further information have a look at:
https://github.com/doctrine/DoctrineBundle/issues/673
In AbstractMySQLDriver.php line 112:
An exception occurred in driver: SQLSTATE[HY000] [2002] php_network_getaddr
esses: getaddrinfo failed: Temporary failure in name resolution
In Exception.php line 18:
SQLSTATE[HY000] [2002] php_network_getaddresses: getaddrinfo failed: Tempor
In PDOConnection.php line 40:
PDO::__construct(): php_network_getaddresses: getaddrinfo failed: Temporary
tform version.
tform version.
tform version.
root@ubuntu-supla:~# docker logs --since=5m supla-server
error from daemon in stream: Error grabbing logs: invalid character '\x00' looking for beginning of value
root@ubuntu-supla:~# docker logs --since=5m supla-db
2023-07-26T17:56:51.854861Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
2023-07-26T17:56:51.860389Z 0 [Note] mysqld (mysqld 5.7.20) starting as process 1 ...
2023-07-26T17:56:51.872898Z 0 [Note] InnoDB: PUNCH HOLE support available
2023-07-26T17:56:51.872986Z 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2023-07-26T17:56:51.873003Z 0 [Note] InnoDB: Uses event mutexes
2023-07-26T17:56:51.873019Z 0 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2023-07-26T17:56:51.873034Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.3
2023-07-26T17:56:51.873048Z 0 [Note] InnoDB: Using Linux native AIO
2023-07-26T17:56:51.873988Z 0 [Note] InnoDB: Number of pools: 1
2023-07-26T17:56:51.874383Z 0 [Note] InnoDB: Not using CPU crc32 instructions
2023-07-26T17:56:51.880918Z 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2023-07-26T17:56:51.913436Z 0 [Note] InnoDB: Completed initialization of buffer pool
2023-07-26T17:56:51.921061Z 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2023-07-26T17:56:51.938372Z 0 [Note] InnoDB: Highest supported file format is Barracuda.
2023-07-26T17:56:51.943023Z 0 [Note] InnoDB: Log scan progressed past the checkpoint lsn 2606589801
2023-07-26T17:56:51.943109Z 0 [Note] InnoDB: Doing recovery: scanned up to log sequence number 2606590649
2023-07-26T17:56:51.943600Z 0 [ERROR] InnoDB: Ignoring the redo log due to missing MLOG_CHECKPOINT between the checkpoint 2606589801 and the end 2606590649.
2023-07-26T17:56:51.943650Z 0 [ERROR] InnoDB: Plugin initialization aborted with error Generic error
2023-07-26T17:56:52.544451Z 0 [ERROR] Plugin 'InnoDB' init function returned error.
2023-07-26T17:56:52.544528Z 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
2023-07-26T17:56:52.544545Z 0 [ERROR] Failed to initialize plugins.
2023-07-26T17:56:52.544555Z 0 [ERROR] Aborting
2023-07-26T17:56:52.544568Z 0 [Note] Binlog end
2023-07-26T17:56:52.545076Z 0 [Note] Shutting down plugin 'MyISAM'
2023-07-26T17:56:52.545124Z 0 [Note] Shutting down plugin 'CSV'
2023-07-26T17:56:52.548631Z 0 [Note] mysqld: Shutdown complete
2023-07-26T17:57:54.702135Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
2023-07-26T17:57:54.707602Z 0 [Note] mysqld (mysqld 5.7.20) starting as process 1 ...
2023-07-26T17:57:54.720259Z 0 [Note] InnoDB: PUNCH HOLE support available
2023-07-26T17:57:54.720341Z 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2023-07-26T17:57:54.720358Z 0 [Note] InnoDB: Uses event mutexes
2023-07-26T17:57:54.720373Z 0 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2023-07-26T17:57:54.720395Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.3
2023-07-26T17:57:54.720410Z 0 [Note] InnoDB: Using Linux native AIO
2023-07-26T17:57:54.721833Z 0 [Note] InnoDB: Number of pools: 1
2023-07-26T17:57:54.722365Z 0 [Note] InnoDB: Not using CPU crc32 instructions
2023-07-26T17:57:54.728834Z 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2023-07-26T17:57:54.761237Z 0 [Note] InnoDB: Completed initialization of buffer pool
2023-07-26T17:57:54.768888Z 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2023-07-26T17:57:54.786284Z 0 [Note] InnoDB: Highest supported file format is Barracuda.
2023-07-26T17:57:54.791160Z 0 [Note] InnoDB: Log scan progressed past the checkpoint lsn 2606589801
2023-07-26T17:57:54.791458Z 0 [Note] InnoDB: Doing recovery: scanned up to log sequence number 2606590649
2023-07-26T17:57:54.791947Z 0 [ERROR] InnoDB: Ignoring the redo log due to missing MLOG_CHECKPOINT between the checkpoint 2606589801 and the end 2606590649.
2023-07-26T17:57:54.792032Z 0 [ERROR] InnoDB: Plugin initialization aborted with error Generic error
2023-07-26T17:57:55.392870Z 0 [ERROR] Plugin 'InnoDB' init function returned error.
2023-07-26T17:57:55.392941Z 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
2023-07-26T17:57:55.392957Z 0 [ERROR] Failed to initialize plugins.
2023-07-26T17:57:55.392968Z 0 [ERROR] Aborting
2023-07-26T17:57:55.392982Z 0 [Note] Binlog end
2023-07-26T17:57:55.393287Z 0 [Note] Shutting down plugin 'MyISAM'
2023-07-26T17:57:55.393325Z 0 [Note] Shutting down plugin 'CSV'
2023-07-26T17:57:55.397211Z 0 [Note] mysqld: Shutdown complete
2023-07-26T17:58:57.203281Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
2023-07-26T17:58:57.208808Z 0 [Note] mysqld (mysqld 5.7.20) starting as process 1 ...
2023-07-26T17:58:57.221693Z 0 [Note] InnoDB: PUNCH HOLE support available
2023-07-26T17:58:57.221797Z 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2023-07-26T17:58:57.221817Z 0 [Note] InnoDB: Uses event mutexes
2023-07-26T17:58:57.221833Z 0 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2023-07-26T17:58:57.221849Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.3
2023-07-26T17:58:57.221864Z 0 [Note] InnoDB: Using Linux native AIO
2023-07-26T17:58:57.222932Z 0 [Note] InnoDB: Number of pools: 1
2023-07-26T17:58:57.223664Z 0 [Note] InnoDB: Not using CPU crc32 instructions
2023-07-26T17:58:57.230254Z 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2023-07-26T17:58:57.263161Z 0 [Note] InnoDB: Completed initialization of buffer pool
2023-07-26T17:58:57.270756Z 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2023-07-26T17:58:57.288161Z 0 [Note] InnoDB: Highest supported file format is Barracuda.
2023-07-26T17:58:57.293112Z 0 [Note] InnoDB: Log scan progressed past the checkpoint lsn 2606589801
2023-07-26T17:58:57.293199Z 0 [Note] InnoDB: Doing recovery: scanned up to log sequence number 2606590649
2023-07-26T17:58:57.293495Z 0 [ERROR] InnoDB: Ignoring the redo log due to missing MLOG_CHECKPOINT between the checkpoint 2606589801 and the end 2606590649.
2023-07-26T17:58:57.293560Z 0 [ERROR] InnoDB: Plugin initialization aborted with error Generic error
2023-07-26T17:58:57.894622Z 0 [ERROR] Plugin 'InnoDB' init function returned error.
2023-07-26T17:58:57.894696Z 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
2023-07-26T17:58:57.894712Z 0 [ERROR] Failed to initialize plugins.
2023-07-26T17:58:57.894722Z 0 [ERROR] Aborting
2023-07-26T17:58:57.894735Z 0 [Note] Binlog end
2023-07-26T17:58:57.894870Z 0 [Note] Shutting down plugin 'MyISAM'
2023-07-26T17:58:57.895042Z 0 [Note] Shutting down plugin 'CSV'
2023-07-26T17:58:57.898586Z 0 [Note] mysqld: Shutdown complete
2023-07-26T17:59:59.713927Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
2023-07-26T17:59:59.719479Z 0 [Note] mysqld (mysqld 5.7.20) starting as process 1 ...
2023-07-26T17:59:59.732936Z 0 [Note] InnoDB: PUNCH HOLE support available
2023-07-26T17:59:59.733048Z 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2023-07-26T17:59:59.733067Z 0 [Note] InnoDB: Uses event mutexes
2023-07-26T17:59:59.733082Z 0 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2023-07-26T17:59:59.733096Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.3
2023-07-26T17:59:59.733110Z 0 [Note] InnoDB: Using Linux native AIO
2023-07-26T17:59:59.734619Z 0 [Note] InnoDB: Number of pools: 1
2023-07-26T17:59:59.735249Z 0 [Note] InnoDB: Not using CPU crc32 instructions
2023-07-26T17:59:59.743343Z 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2023-07-26T17:59:59.776267Z 0 [Note] InnoDB: Completed initialization of buffer pool
2023-07-26T17:59:59.783944Z 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2023-07-26T17:59:59.801202Z 0 [Note] InnoDB: Highest supported file format is Barracuda.
2023-07-26T17:59:59.806034Z 0 [Note] InnoDB: Log scan progressed past the checkpoint lsn 2606589801
2023-07-26T17:59:59.806121Z 0 [Note] InnoDB: Doing recovery: scanned up to log sequence number 2606590649
2023-07-26T17:59:59.806398Z 0 [ERROR] InnoDB: Ignoring the redo log due to missing MLOG_CHECKPOINT between the checkpoint 2606589801 and the end 2606590649.
2023-07-26T17:59:59.806441Z 0 [ERROR] InnoDB: Plugin initialization aborted with error Generic error
2023-07-26T18:00:00.407477Z 0 [ERROR] Plugin 'InnoDB' init function returned error.
2023-07-26T18:00:00.407539Z 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
2023-07-26T18:00:00.407556Z 0 [ERROR] Failed to initialize plugins.
2023-07-26T18:00:00.407567Z 0 [ERROR] Aborting
2023-07-26T18:00:00.407581Z 0 [Note] Binlog end
2023-07-26T18:00:00.407711Z 0 [Note] Shutting down plugin 'MyISAM'
2023-07-26T18:00:00.407803Z 0 [Note] Shutting down plugin 'CSV'
2023-07-26T18:00:00.411332Z 0 [Note] mysqld: Shutdown complete
root@ubuntu-supla:~# ./supla-docker/supla.sh upgrade
Making database backup
Error response from daemon: Container bb00cc3df17ea5add1709c91b39c068371dd1dc55388ae4b6064b1f5c718acc7 is restarting, wait until the container is running
Could not create the database backup. Is the application started?
