Unit not turning on
Pert Bubik
Hi,
I just bought and installed the MEW01 power monitoring device, wired in voltage and current inputs and the unit doesn’t come on.
I tried pressing and holding the only button it has, nothing
What’s wrong?
I checked voltage on the inputs - there is 236v on each phase compared to the neutral / ground
Has that happened to anyone here?
Mirosław F.
Been thanked: 22 times
Hi. Maybe a damaged piece? They are calibrated and tested by us, but I do not exclude such a possibility. Request from the seller. If this is a problem, please send it to us.
43-200 Pszczyna
ul. Zielona 27
Pert Bubik
Thank you for your reply- it got resolved.
Turned out there was no ground where it was. Supposed to be.
Thank you
Return to “General discussion”
