Varilight / Supla / PIR
ukinstall
I'm using Varilight Supla switches successfully and have it all tied into Alexa. What I would like to do is trigger the Supla lighting circuits with an outdoor PIR so as to switch the lights on for 5 minutes and then off. Is there a compatible PIR I can use for this?
- Been thanked: 59 times
You would have to use a Zamel RNW-01 module and connect any motion sensor to it. Then in cloud.supla.org you set the reaction that will turn on the lighting for a given time.
