[2023-11-24 12:00:02] console.CRITICAL: Error thrown while running command "supla:dispatch-cyclic-tasks". Message: "Argument 1 passed to SuplaBundle\Command\Cyclic\SynchronizeEspUpdatesCommand::insertUpdate() must be of the type array, string given, called in /var/www/cloud/src/SuplaBundle/Command/Cyclic/SynchronizeEspUpdatesCommand.php on line 51" {"exception":"[object] (TypeError(code: 0): Argument 1 passed to SuplaBundle\\Command\\Cyclic\\SynchronizeEspUpdatesCommand::insertUpdate() must be of the type array, string given, called in /var/www/cloud/src/SuplaBundle/Command/Cyclic/SynchronizeEspUpdatesCommand.php on line 51 at /var/www/cloud/src/SuplaBundle/Command/Cyclic/SynchronizeEspUpdatesCommand.php:69)","command":"supla:dispatch-cyclic-tasks","message":"Argument 1 passed to SuplaBundle\\Command\\Cyclic\\SynchronizeEspUpdatesCommand::insertUpdate() must be of the type array, string given, called in /var/www/cloud/src/SuplaBundle/Command/Cyclic/SynchronizeEspUpdatesCommand.php on line 51"} []
Some of the devices are already installed and will be quite a hassle to reregister just for updates so I would very much prefer to fix this. Could you recommend some troubleshooting steps?
thank you
