Bład generowania na testowym dla ESP32
cinas
Has thanked: 3 times
Been thanked: 7 times
Błąd generowania dla ESP32 + Roleta + PCF8574
In file included from GUI-Generic_test_bv5.2_gv7.5.19_pl_600fb536082c756e49a6f09933553066/SuplaDeviceGUI.h:60,
                 from GUI-Generic_test_bv5.2_gv7.5.19_pl_600fb536082c756e49a6f09933553066/GUIGenericCommon.cpp:18:
GUI-Generic_test_bv5.2_gv7.5.19_pl_600fb536082c756e49a6f09933553066/SuplaConditions.h:113:5: error: 'S_CHANNEL_VALUE' was not declared in this scope
     S_CHANNEL_VALUE S_SPACE S_ON_LESS,
In file included from GUI-Generic_test_bv5.2_gv7.5.19_pl_600fb536082c756e49a6f09933553066/GUIGenericCommon.h:21,
                 from GUI-Generic_test_bv5.2_gv7.5.19_pl_600fb536082c756e49a6f09933553066/GUIGenericCommon.cpp:17:
GUI-Generic_test_bv5.2_gv7.5.19_pl_600fb536082c756e49a6f09933553066/src/language/common.h:5:17: error: expected '}' before string constant
 #define S_SPACE " "
GUI-Generic_test_bv5.2_gv7.5.19_pl_600fb536082c756e49a6f09933553066/SuplaConditions.h:113:21: note: in expansion of macro 'S_SPACE'
GUI-Generic_test_bv5.2_gv7.5.19_pl_600fb536082c756e49a6f09933553066/SuplaConditions.h:111:49: note: to match this '{'
 const char* const CONDITIONS_TYPE_P[] PROGMEM = {
GUI-Generic_test_bv5.2_gv7.5.19_pl_600fb536082c756e49a6f09933553066/SuplaConditions.h:136:1: error: expected declaration before '}' token
Error during build: exit status 1
xxxxxxxxxxxxxxxxxx
BOARD esp32:esp32:d32:PartitionScheme=min_spiffs
BOARD_NAME
TEMPLATE_JSON
JSON_DEFINITION
OPTIONS -DBUILDER_TEST -DATOMIC_FS_UPDATE -DMIMETYPE_MINIMAL -DBEARSSL_SSL_BASIC -DSUPLA_BUTTON -DSUPLA_CONFIG -DSUPLA_ENABLE_GUI -DSUPLA_OTA -DSUPLA_PCF8574
-DSUPLA_RELAY -DSUPLA_ROLLERSHUTTER
Been thanked: 5 times
Dlaczego korzystasz z wersji testowej? Generuje oficjalne wydania ...
cinas
Na oficjalnym coś nie działa z PCF chciałem sprawdzić
Tu opisałem zwiechę esp32
viewtopic.php?t=14415
cinas wrote: Mon Dec 11, 2023 8:39 pm Na oficjalnym coś nie działa z PCF chciałem sprawdzić
Przetestuj na esp8366.
cinas
To jest gotowa płyta z ESP 32 i PCF na pokładzie
Fajne HW do budowania
cinas wrote: Mon Dec 11, 2023 9:37 pm To jest gotowa płyta z ESP 32 i PCF na pokładzie
Nie mam tej płytki więc ciężko coś powiedzieć. Chociaż napisz jak to skonfigurowałeś oraz podeślij dokumentację do tej płytki co na jakim gpio jest.
cinas
Wczoraj builder strasznie mulił i może to było powodem błędów w kompilacji
Dziś na nowo wygenerowałem soft i działa, ale jest efekt klikania przekaźników przy starcie ( ale to obstawiam wina PCF )
IIC SDA:4
IIC SCL:5
Relay_IIC_address 0x20
Relay1 = pcf8574.pinMode(P0, OUTPUT);
Relay2 = pcf8574.pinMode(P1, OUTPUT);
Relay3 = pcf8574.pinMode(P2, OUTPUT);
Relay4 = pcf8574.pinMode(P3, OUTPUT);
Relay5 = pcf8574.pinMode(P4, OUTPUT);
Relay6 = pcf8574.pinMode(P5, OUTPUT);
Relay7 = pcf8574.pinMode(P6, OUTPUT);
Relay8 = pcf8574.pinMode(P7, OUTPUT);
Input_IIC_address 0x22
Input1 = pcf8574.pinMode(P0, INPUT);
Input2 = pcf8574.pinMode(P1, INPUT);
Input3 = pcf8574.pinMode(P2, INPUT);
Input4 = pcf8574.pinMode(P3, INPUT);
Input5 = pcf8574.pinMode(P4, INPUT);
Input6 = pcf8574.pinMode(P5, INPUT);
Input7 = pcf8574.pinMode(P6, INPUT);
Input8 = pcf8574.pinMode(P7, INPUT);
DS18B20/DHT11/DHT21/LED strip -1: 14
DS18B20/DHT11/DHT21/LED strip -2: 13
DS18B20/DHT11/DHT21/LED strip -3: 32 updated in PCB V1.4
DS18B20/DHT11/DHT21/LED strip -4: 33 updated in PCB V1.4
Ethernet (LAN8720) I/O define:
#define ETH_ADDR 0
#define ETH_POWER_PIN -1
#define ETH_MDC_PIN 23
#define ETH_MDIO_PIN 18
#define ETH_TYPE ETH_PHY_LAN8720
#define ETH_CLK_MODE ETH_CLOCK_GPIO17_OUT
robertklepacki94
Has thanked: 5 times
Been thanked: 14 times
@krycha88
Tu jest chyba cała dostępna dokumentacja oraz schemat.
https://templates.blakadder.com/kincony_KC868-A8.html
Return to “GUI Generic”
