Values missing when downloading from two different PCs
thorstendb
Hi,
I found when downloading data (cloud website) using two different PCs, on one PC there are three value entries / timestamps missing in the table, in the first 20 entries. This can be seen when comparing CSV files (All, Incremental), and remains as a constant error when downloading the next time hours or days later.
I found that when trying to put some values in my comparison table to the standard electricity counter.
Timestamps are missing:
1706728371;2024-01-31 20:12:51;0;0.00004;0;0.0002;0.0675;0;0;0.01858;0.01202;0;0.0034;0;0.07952;0.00004;0.07948;0.07948;0
1706730771;2024-01-31 20:52:51;0;0.00002;0;0.0002;0.06468;0;0;0.0185;0.00118;0;0.0002;0.00002;0.06586;0.00002;0.06584;0.06584;0
1706728972;2024-01-31 20:22:52;0;0.00004;0;0.0002;0.09004;0;0;0.01914;0.01198;0;0.00348;0;0.10202;0.00004;0.10198;0.10198;0
1706729571;2024-01-31 20:32:51;0;0.00002;0;0.0002;0.07568;0;0;0.01872;0.00176;0;0.0005;0;0.07744;0.00002;0.07742;0.07742;0
1706730171;2024-01-31 20:42:51;0;0.00002;0;0.0002;0.07364;0;0;0.01898;0.00146;0;0.00022;0.00012;0.0751;0.00002;0.07508;0.07508;0
Values differ:
1707412371 2024-02-08 18:12:51 2,95206 0,04032 0,06664 0,23704 39,68366 0,0016 0,03806 18,1576 14,91344 0,0895 1,90656 1,94688 57,54916 0,13142 57,41774 57,504 0,08626
1707412371 2024-02-08 18:12:51 2,95206 0,0404 0,06664 0,23764 39,92302 0,0016 0,03806 18,21444 14,92864 0,0895 1,91076 1,947 57,80372 0,1315 57,67222 57,75848 0,08626
thorstendb
I further found out, that on thew PC where lines are missing, the result is correct when using MS Edge.
There should be a validator embedded in the exporter, to check if the timestamps are consistent.
fracz
Has thanked: 4 times
Been thanked: 6 times
Can you please send me those two exports via private message?
thorstendb
I have sent a PM with the data attached.
Tried to send another one as test with no attachment. Both messages got tuck in my "Outgoing messages" folder.
Return to “General discussion”
