php bin/console cache:clear --no-warmup -e devCode: Select all
[WARNING] Some commands could not be registered:
In appAppKernelDevDebugContainer.php line 348:
Class "Doctrine\Common\Persistence\Mapping\Driver\MappingDriverChain" not found
In TokenManager.php line 37:
FOS\OAuthServerBundle\Entity\TokenManager::__construct(): Argument #1 ($em) must be of type Doctrine\Common\Persistence
\ObjectManager, EntityManager_9a5be93 given, called in E:\work-files\supla\supla-cloud\var\cache\dev\Container4KhNAAj\a
ppAppKernelDevDebugContainer.php on line 1876
In IODeviceManager.php line 31:
SuplaBundle\Model\IODeviceManager::__construct(): Argument #2 ($doctrine) must be of type Doctrine\Common\Persistence\M
anagerRegistry, Doctrine\Bundle\DoctrineBundle\Registry given, called in E:\work-files\supla\supla-cloud\var\cache\dev\
Container4KhNAAj\appAppKernelDevDebugContainer.php on line 1304
In ClientManager.php line 37:
FOS\OAuthServerBundle\Entity\ClientManager::__construct(): Argument #1 ($em) must be of type Doctrine\Common\Persistenc
e\ObjectManager, EntityManager_9a5be93 given, called in E:\work-files\supla\supla-cloud\var\cache\dev\Container4KhNAAj\
getFosOauthServer_ClientManager_DefaultService.php on line 9
\ObjectManager, EntityManager_9a5be93 given, called in E:\work-files\supla\supla-cloud\src\SuplaBundle\Auth\SuplaAccess
TokenManager.php on line 15
// Clearing the cache for the dev environment with debug true
[OK] Cache for the "dev" environment (debug=true) was successfully cleared.
PS E:\work-files\supla\supla-cloud>
