Making database backup
Database backup saved to ./var/backups/supla03232024100138.sql.gz
Stopping SUPLA containers
Stopping supla-server ... done
Stopping supla-cloud ... done
Stopping supla-db ... done
SUPLA containers has been stopped.
Pulling supla-db ... done
Pulling supla-cloud ... done
Pulling supla-server ... done
Starting SUPLA containers
Starting supla-db ... done
Recreating supla-cloud ...
ERROR: for supla-cloud 'ContainerConfig'
Traceback (most recent call last):
File "/usr/local/bin/docker-compose", line 10, in <module>
sys.exit(main())
File "/usr/local/lib/python3.7/dist-packages/compose/cli/main.py", line 81, in main
command_func()
File "/usr/local/lib/python3.7/dist-packages/compose/cli/main.py", line 203, in perform_command
handler(command, command_options)
File "/usr/local/lib/python3.7/dist-packages/compose/metrics/decorator.py", line 18, in wrapper
result = fn(*args, **kwargs)
File "/usr/local/lib/python3.7/dist-packages/compose/cli/main.py", line 1186, in up
to_attach = up(False)
File "/usr/local/lib/python3.7/dist-packages/compose/cli/main.py", line 1182, in up
attach_dependencies=attach_dependencies,
File "/usr/local/lib/python3.7/dist-packages/compose/project.py", line 702, in up
get_deps,
File "/usr/local/lib/python3.7/dist-packages/compose/parallel.py", line 108, in parallel_execute
raise error_to_reraise
File "/usr/local/lib/python3.7/dist-packages/compose/parallel.py", line 206, in producer
result = func(obj)
File "/usr/local/lib/python3.7/dist-packages/compose/project.py", line 688, in do
override_options=override_options,
File "/usr/local/lib/python3.7/dist-packages/compose/service.py", line 581, in execute_convergence_plan
renew_anonymous_volumes,
File "/usr/local/lib/python3.7/dist-packages/compose/service.py", line 503, in _execute_convergence_recreate
"Recreating",
result = func(obj)
File "/usr/local/lib/python3.7/dist-packages/compose/service.py", line 496, in recreate
start_new_container=start, renew_anonymous_volumes=renew_anonymous_volumes
File "/usr/local/lib/python3.7/dist-packages/compose/service.py", line 615, in recreate_container
quiet=True,
File "/usr/local/lib/python3.7/dist-packages/compose/service.py", line 334, in create_container
previous_container=previous_container,
File "/usr/local/lib/python3.7/dist-packages/compose/service.py", line 922, in _get_container_create_options
previous_container, container_options, override_options
File "/usr/local/lib/python3.7/dist-packages/compose/service.py", line 962, in _build_container_volume_options
container_mounts
File "/usr/local/lib/python3.7/dist-packages/compose/service.py", line 1549, in merge_volume_bindings
previous_container, volumes, tmpfs, mounts
File "/usr/local/lib/python3.7/dist-packages/compose/service.py", line 1579, in get_container_data_volumes
container.image_config['ContainerConfig'].get('Volumes') or {}
KeyError: 'ContainerConfig'
