Logi
Mac
Prosze o rozszyfrowanie logów (z problemem) w miare możliwości w prywatnej instancji
DB
241125 9:20:16 InnoDB: Waiting for the background threads to start
241125 9:20:17 InnoDB: 5.5.60 started; log sequence number 9033352266
241125 9:20:17 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
241125 9:20:17 [Note] - '0.0.0.0' resolves to '0.0.0.0';
241125 9:20:17 [Note] Server socket created on IP: '0.0.0.0'.
241125 9:20:17 [Note] Event Scheduler: Loaded 0 events
241125 9:20:17 [Note] mysqld: ready for connections.
Version: '5.5.60-0+deb7u1' socket: '/var/run/mysqld/mysqld.sock' port: 3306 (Debian)
241125 9:20:18 [ERROR] mysqld: Table './mysql/proc' is marked as crashed and should be repaired
241125 9:20:18 [Warning] Checking table: './mysql/proc'
server
ERR[09:23:07.725007] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
ERR[09:23:11.814659] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:11.814776] Google Home State Report Request - The http request is delayed. ChannelId: 118, DelayUSec: 6698547, TimeSinceExecReq: 6692969
ERR[09:23:16.632525] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:16.632645] Google Home State Report Request - The http request is delayed. ChannelId: 119, DelayUSec: 11516368, TimeSinceExecReq: 11510837
ERR[09:23:17.356579] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:17.356701] Google Home State Report Request - The http request is delayed. ChannelId: 120, DelayUSec: 12240373, TimeSinceExecReq: 12234890
ERR[09:23:17.737019] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:17.737141] Google Home State Report Request - The http request is delayed. ChannelId: 121, DelayUSec: 12620761, TimeSinceExecReq: 12615326
ERR[09:23:21.823670] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:21.823786] Google Home State Report Request - The http request is delayed. ChannelId: 122, DelayUSec: 16707356, TimeSinceExecReq: 16701961
INFO[09:23:24.417917] Connection accepted: 10.0.6.43:60425 ClientSD: 118 Secure: 1
INFO[09:23:24.674614] Connection accepted: 10.0.6.26:63498 ClientSD: 51 Secure: 1
ERR[09:23:26.642874] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:26.642994] Google Home State Report Request - The http request is delayed. ChannelId: 123, DelayUSec: 21526511, TimeSinceExecReq: 21521166
ERR[09:23:27.367669] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:27.367788] Google Home State Report Request - The http request is delayed. ChannelId: 124, DelayUSec: 22251253, TimeSinceExecReq: 22245959
ERR[09:23:27.749623] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:27.749743] Google Home State Report Request - The http request is delayed. ChannelId: 125, DelayUSec: 22633157, TimeSinceExecReq: 22627912
ERR[09:23:28.907842] curl_easy_perform() failed: Timeout was reached. https://autodiscover.supla.org/service-tokens
ERR[09:23:31.835746] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:31.835864] Google Home State Report Request - The http request is delayed. ChannelId: 126, DelayUSec: 26719225, TimeSinceExecReq: 26713850
ERR[09:23:36.650023] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:36.650154] Google Home State Report Request - HTTP Request timeout. ChannelId: 127, TimeoutUSec: 30000000+1533460, TimeSinceExecReq: 31528135
WARNING[09:23:36.650208] Google Home State Report Request - HTTP Request timeout. ChannelId: 128, TimeoutUSec: 30000000+1533466, TimeSinceExecReq: 31528190
WARNING[09:23:36.650274] Google Home State Report Request - HTTP Request timeout. ChannelId: 129, TimeoutUSec: 30000000+1533461, TimeSinceExecReq: 31528237
WARNING[09:23:36.650320] Google Home State Report Request - HTTP Request timeout. ChannelId: 130, TimeoutUSec: 30000000+1533472, TimeSinceExecReq: 31528297
WARNING[09:23:36.650364] Google Home State Report Request - HTTP Request timeout. ChannelId: 131, TimeoutUSec: 30000000+1533461, TimeSinceExecReq: 31528024
WARNING[09:23:36.650406] Google Home State Report Request - HTTP Request timeout. ChannelId: 132, TimeoutUSec: 30000000+1533451, TimeSinceExecReq: 31528063
WARNING[09:23:36.650450] Google Home State Report Request - HTTP Request timeout. ChannelId: 133, TimeoutUSec: 30000000+1533439, TimeSinceExecReq: 31528103
WARNING[09:23:36.650493] Google Home State Report Request - HTTP Request timeout. ChannelId: 206, TimeoutUSec: 30000000+294481, TimeSinceExecReq: 30284744
WARNING[09:23:36.650539] Google Home State Report Request - HTTP Request timeout. ChannelId: 194, TimeoutUSec: 30000000+242885, TimeSinceExecReq: 30233572
WARNING[09:23:36.650583] Google Home State Report Request - HTTP Request timeout. ChannelId: 167, TimeoutUSec: 30000000+144645, TimeSinceExecReq: 30135345
WARNING[09:23:36.650628] Google Home State Report Request - HTTP Request timeout. ChannelId: 25, TimeoutUSec: 30000000+91591, TimeSinceExecReq: 30082127
WARNING[09:23:36.650672] Google Home State Report Request - HTTP Request timeout. ChannelId: 161, TimeoutUSec: 30000000+60212, TimeSinceExecReq: 30050926
WARNING[09:23:36.650715] Google Home State Report Request - HTTP Request timeout. ChannelId: 200, TimeoutUSec: 30000000+40724, TimeSinceExecReq: 30030728
WARNING[09:23:36.650761] Google Home State Report Request - The http request is delayed. ChannelId: 209, DelayUSec: 29966576, TimeSinceExecReq: 29966256
ERR[09:23:37.380115] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:37.380227] Google Home State Report Request - HTTP Request timeout. ChannelId: 188, TimeoutUSec: 30000000+578741, TimeSinceExecReq: 30569385
WARNING[09:23:37.380278] Google Home State Report Request - HTTP Request timeout. ChannelId: 197, TimeoutUSec: 30000000+431800, TimeSinceExecReq: 30422116
WARNING[09:23:37.380324] Google Home State Report Request - HTTP Request timeout. ChannelId: 179, TimeoutUSec: 30000000+303795, TimeSinceExecReq: 30293858
WARNING[09:23:37.380370] Google Home State Report Request - HTTP Request timeout. ChannelId: 212, TimeoutUSec: 30000000+46545, TimeSinceExecReq: 30036435
WARNING[09:23:37.380417] Google Home State Report Request - The http request is delayed. ChannelId: 32, DelayUSec: 27314793, TimeSinceExecReq: 27304890
ERR[09:23:37.763679] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:37.763806] Google Home State Report Request - The http request is delayed. ChannelId: 102, DelayUSec: 15841602, TimeSinceExecReq: 15831859
ERR[09:23:41.847786] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:41.847905] Google Home State Report Request - The http request is delayed. ChannelId: 103, DelayUSec: 19925578, TimeSinceExecReq: 19915955
ERR[09:23:45.131489] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:45.131615] Google Home State Report Request - The http request is delayed. ChannelId: 47, DelayUSec: 10288914, TimeSinceExecReq: 10279250
ERR[09:23:45.148588] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:45.149976] Google Home State Report Request - The http request is delayed. ChannelId: 138, DelayUSec: 9674888, TimeSinceExecReq: 9674802
ERR[09:23:45.641468] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:23:45.641594] Google Home State Report Request - The http request is delayed. ChannelId: 100, DelayUSec: 9355597, TimeSinceExecReq: 9345524
ERR[09:23:45.748349] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
ERR[09:23:46.659818] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
ERR[09:23:47.218739] GoogleHomeGraph client error userId: 1, code=404, message={"message":"HomeGraph error message: Requested entity was not found."}
INFO[09:23:47.274561] Device registered. ID: 85, ClientSD: 57 Protocol Version: 23 ThreadID: 196 GUID: C9397ACA ResultCode: 3
INFO[09:23:47.308666] Cipher: AES128-SHA, SSL Version: TLSv1.1, ClientSD: 24
ERR[09:23:47.393296] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
ERR[09:23:47.773031] curl_easy_perform() failed: Timeout was reached. https://odokilkqoesh73zfznmiupey4a0uuga ... -1.on.aws/
WARNING[09:24:27.425685] Google Home State Report Request - HTTP Request timeout. ChannelId: 129, TimeoutUSec: 30000000+2713054, TimeSinceExecReq: 32704033
WARNING[09:24:27.425772] Google Home State Report Request - HTTP Request timeout. ChannelId: 130, TimeoutUSec: 30000000+2713080, TimeSinceExecReq: 32704129
WARNING[09:24:27.425821] Google Home State Report Request - HTTP Request timeout. ChannelId: 131, TimeoutUSec: 30000000+2713057, TimeSinceExecReq: 32704179
WARNING[09:24:27.425866] Google Home State Report Request - HTTP Request timeout. ChannelId: 132, TimeoutUSec: 30000000+2713030, TimeSinceExecReq: 32704223
WARNING[09:24:27.425910] Google Home State Report Request - HTTP Request timeout. ChannelId: 133, TimeoutUSec: 30000000+2712998, TimeSinceExecReq: 32704264
WARNING[09:24:27.425956] Google Home State Report Request - HTTP Request timeout. ChannelId: 106, TimeoutUSec: 30000000+2567090, TimeSinceExecReq: 32556987
WARNING[09:24:27.426003] Google Home State Report Request - The http request is delayed. ChannelId: 139, DelayUSec: 22593842, TimeSinceExecReq: 22584192
WARNING[09:24:27.673733] Google Home State Report Request - The http request is delayed. ChannelId: 212, DelayUSec: 8711951, TimeSinceExecReq: 8711516
WARNING[09:24:27.674270] Google Home State Report Request - The http request is delayed. ChannelId: 100, DelayUSec: 8074092, TimeSinceExecReq: 8064482
WARNING[09:24:27.678504] Google Home State Report Request - The http request is delayed. ChannelId: 167, DelayUSec: 7015709, TimeSinceExecReq: 7006418
WARNING[09:24:27.682590] Google Home State Report Request - The http request is delayed. ChannelId: 209, DelayUSec: 6977180, TimeSinceExecReq: 6967309
WARNING[09:24:27.914026] Google Home State Report Request - The http request is delayed. ChannelId: 25, DelayUSec: 7106152, TimeSinceExecReq: 7096543
WARNING[09:24:27.934895] Google Home State Report Request - The http request is delayed. ChannelId: 200, DelayUSec: 7048981, TimeSinceExecReq: 7039195
WARNING[09:24:27.939365] Google Home State Report Request - The http request is delayed. ChannelId: 47, DelayUSec: 5654152, TimeSinceExecReq: 5653746
WARNING[09:24:27.952055] Google Home State Report Request - The http request is delayed. ChannelId: 138, DelayUSec: 5510029, TimeSinceExecReq: 5500094
s_pol
U mnie (instalacja dockerowa) również takie próby połączenia występują:
docker logs --tail=100 supla-server | grep 'https://odokilkqoesh73zfznmiupey4a0uugaz.lambda-url.eu-west-1.on.aws/'
ERR[18:30:29.387759] curl_easy_perform() failed: Couldn't connect to server. https://odokilkqoesh73zfznmiupey4a0uugaz.lambda-url.eu-west-1.on.aws/
ERR[18:30:29.388048] curl_easy_perform() failed: Couldn't connect to server. https://odokilkqoesh73zfznmiupey4a0uugaz.lambda-url.eu-west-1.on.aws/
ERR[18:30:53.562389] curl_easy_perform() failed: Couldn't connect to server. https://odokilkqoesh73zfznmiupey4a0uugaz.lambda-url.eu-west-1.on.aws/
ERR[19:00:36.807077] curl_easy_perform() failed: Couldn't connect to server. https://odokilkqoesh73zfznmiupey4a0uugaz.lambda-url.eu-west-1.on.aws/
ERR[19:02:01.933029] curl_easy_perform() failed: Couldn't connect to server. https://odokilkqoesh73zfznmiupey4a0uugaz.lambda-url.eu-west-1.on.aws/
ERR[19:11:40.404470] curl_easy_perform() failed: Couldn't connect to server. https://odokilkqoesh73zfznmiupey4a0uugaz.lambda-url.eu-west-1.on.aws/
ERR[19:12:55.146064] curl_easy_perform() failed: Couldn't connect to server. https://odokilkqoesh73zfznmiupey4a0uugaz.lambda-url.eu-west-1.on.aws/
ERR[19:30:22.930375] curl_easy_perform() failed: Couldn't connect to server. https://odokilkqoesh73zfznmiupey4a0uugaz.lambda-url.eu-west-1.on.aws/
ERR[19:30:28.629317] curl_easy_perform() failed: Couldn't connect to server. https://odokilkqoesh73zfznmiupey4a0uugaz.lambda-url.eu-west-1.on.aws/
ponadto server ciągle podejmuje próby uzyskania tokena
docker logs --tail=20 supla-server | grep 'https://autodiscover.supla.org/service-tokens'
ERR[19:31:39.314919] curl_easy_perform() failed: Couldn't connect to server. https://autodiscover.supla.org/service-tokens
ERR[19:32:39.339625] curl_easy_perform() failed: Couldn't connect to server. https://autodiscover.supla.org/service-tokens
ERR[19:33:39.364544] curl_easy_perform() failed: Couldn't connect to server. https://autodiscover.supla.org/service-tokens
ERR[19:34:39.389211] curl_easy_perform() failed: Couldn't connect to server. https://autodiscover.supla.org/service-tokens
ERR[19:35:39.412802] curl_easy_perform() failed: Couldn't connect to server. https://autodiscover.supla.org/service-tokens
ERR[19:36:39.439120] curl_easy_perform() failed: Couldn't connect to server. https://autodiscover.supla.org/service-tokens
ERR[19:37:39.462849] curl_easy_perform() failed: Couldn't connect to server. https://autodiscover.supla.org/service-tokens
ERR[19:38:39.505682] curl_easy_perform() failed: Couldn't connect to server. https://autodiscover.supla.org/service-tokens
ERR[19:39:39.531526] curl_easy_perform() failed: Couldn't connect to server. https://autodiscover.supla.org/service-tokens
ERR[19:40:39.560365] curl_easy_perform() failed: Couldn't connect to server. https://autodiscover.supla.org/service-tokens
ERR[19:41:39.586097] curl_easy_perform() failed: Couldn't connect to server. https://autodiscover.supla.org/service-tokens
ERR[19:42:39.617716] curl_easy_perform() failed: Couldn't connect to server. https://autodiscover.supla.org/service-tokens
ERR[19:43:39.647481] curl_easy_perform() failed: Couldn't connect to server. https://autodiscover.supla.org/service-tokens
ERR[19:44:39.681060] curl_easy_perform() failed: Couldn't connect to server. https://autodiscover.supla.org/service-tokens
ERR[19:45:39.706629] curl_easy_perform() failed: Couldn't connect to server. https://autodiscover.supla.org/service-tokens
nie mam pojęcia czy można to jakoś wyłączyć, niepotrzebnie generuje mi ruch w sieci i trochę już mnie to irytuje.
Czy ktoś ma wiedzę jak się tego pozbyć?
Taki ruch to nie ruch. Wyrejestruj instancję to nie będzie pytać.
s_pol
Mam jakiś problem z wyrejestrowaniem prywatnej instalacji.
Mianowicie, jak na stronie https://cloud.supla.org/register-cloud uruchomiłem wyrejestrowanie, to na maila otrzymałem linka z wyrejestrowaniem mojego dostępu ale tej w chmurze, tj. na serwerze svr20 i o dziwo (klon???) na svr109.
Teraz ponawiając próbę wyrejestrowania "z moją domeną" uzyskuję odpowiedź, że moja instalacja nie jest zarejestrowana.
Z kolei jak próbuję ją zarejestrować to po wygenerowaniu komendy "docker exec -it -u www-data supla-cloud php bin/console supla:register-target-cloud ........." dostaję w consoli odpowiedź "Your instance seems to be registered already. If you have any problems integrating some of the apps, feel free to contact us."
W containers (supla-cloud i supla-server) w katalogu /var/local jest pusto.
aktualizacja:
przy próbie rejestracji dostaję odpowiedź:
Registering your private SUPLA Cloud...
In SuplaBrokerHttpClient.php line 67:
  Service temporarily unavailable
ponadto serwer (autodiscover.supla.org) nie odpowiada na pingi, czy to normale?
