#include <SuplaDevice.h>
#include <supla/control/hvac_base.h>
#include <supla/clock/clock.h>
#include <supla/network/html/time_parameters.h>
#include <supla/network/html/hvac_parameters.h>
#include <supla/control/internal_pin_output.h>
#include <supla/events.h>
#include <supla/actions.h>
#include <supla/sensor/virtual_thermometer.h>
#define Przekaznik1_GPIO 2
#define DS18B20_GPIO 4
Supla::ESPWifi wifi("x", "x");
Supla::Eeprom eeprom;
// Tworzenie obiektów do komunikacji z czujnikami
OneWire oneWire(DS18B20_GPIO);
// Definicje adresów
DeviceAddress ds1addr = {0x28, 0x56, 0x72, 0x64, 0x10, 0x00, 0x00, 0xB8};
DeviceAddress ds2addr = {0x28, 0xE3, 0x71, 0x65, 0x10, 0x00, 0x00, 0x95};
DeviceAddress ds3addr = {0x28, 0x0B, 0x73, 0x64, 0x10, 0x00, 0x00, 0x11};
DeviceAddress ds4addr = {0x28, 0xFF, 0x4F, 0xAB, 0x6E, 0x18, 0x01, 0x66};
float lowestTemp;
void setup() {
Serial.begin(115200);
char GUID[SUPLA_GUID_SIZE] = {0x28,0xCC,0xFE,0x32,0x5F,0x88,0xD8,0x13,0xA7,0xBF,0x70,0x51,0xDE,0x60,0x3B,0x64};
new Supla::Clock;
eeprom.setStateSavePeriod(180000);
auto output = new Supla::Control::InternalPinOutput(Przekaznik1_GPIO);
auto hvac = new Supla::Control::HvacBase(output);
// DeviceAddress ds1addr = {0x28, 0x56, 0x72, 0x64, 0x10, 0x00, 0x00, 0xB8};
// DeviceAddress ds2addr = {0x28, 0xE3, 0x71, 0x65, 0x10, 0x00, 0x00, 0x95};
// new Supla::Sensor::DS18B20(DS18B20_GPIO, ds1addr);
// new Supla::Sensor::DS18B20(DS18B20_GPIO, ds2addr);
// If you don't have thermometers, but still want to try how it works,
// comment above lines and uncomment below lines, to configure dummy
// thermometers (they wil report temperature which is configured below)
auto t1 = new Supla::Sensor::VirtualThermometer;
auto t2 = new Supla::Sensor::VirtualThermometer;
t1->setValue(21.3);
t2->setValue(22.4);
// Konfiguracja parametrów termostatu
hvac->setMainThermometerChannelNo(1); // Main Thermometer DS1
hvac->setTemperatureHisteresisMin(20); // 0.2 degree
hvac->setTemperatureHisteresisMax(1000); // 10 degree
hvac->setTemperatureHisteresis(40);
SuplaDevice.setName("Termostat");
SuplaDevice.begin(21); // Thermostat requires proto version >= 21
"x", // SUPLA server address
"x", // Email address used to login to Supla Cloud
"x"); // Authorization key
void loop() {
// Odczyt temperatur z każdego czujnika
float temp1 = sensors.getTempC(ds1addr); // Czujnik 1
float temp2 = sensors.getTempC(ds2addr); // Czujnik 2
float temp3 = sensors.getTempC(ds3addr); // Czujnik 3
float temp4 = sensors.getTempC(ds4addr); // Czujnik 4
// Znalezienie najniższej temperatury
lowestTemp = temp1;
if (temp2 < lowestTemp) lowestTemp = temp2;
if (temp3 < lowestTemp) lowestTemp = temp3;
if (temp4 < lowestTemp) lowestTemp = temp4;
SuplaDevice.iterate();
