thermostat in gui generic-builder
meliwal
hello, apparently there's a problem with the generator. every time i try to generate a thermostat i get this error
Hi, I just tried two boards with "thermostat" enabled and compilation was successful.meliwal wrote: Tue Jul 15, 2025 9:29 am hello, apparently there's a problem with the generator. every time i try to generate a thermostat i get this error
Which board and options do you choose?
meliwal
Hi, i just tried wemos D1 mini ans esp32 s2 and both the same error.
meliwal
i just found out that the problem is only when i switch to french in guibuilder ,other language generate without problem. i used to select french all the time.
