Problem z wgraniem softu z webinterface ESP8266
nebraska
Witam
Mam taki problem.
Chce na wemosa d1Mini esp8266 wgrac soft. Mam dwa wemosy starsza wersja bez problemu przyjmuje soft z trybem webinterface, a nowszy w wersji v 3.0 wywala
Scheduling soft restart in 2500 ms
LAST STATE ADDED: Software reset (45)
Current status: [41] Software reset
LittleFsConfig: formatting partition
LittleFsConfig: failed to mount and to format partition
SERVER: get request
Reset requested. Reset device
Stopping local web server
Resetting in 0.5s...
See you soon!
#define STATUS_LED_GPIO 2
#define ROLLER_SHUTTER_UP_RELAY_GPIO 4
#define ROLLER_SHUTTER_DOWN_RELAY_GPIO 5
#define RELAY_GPIO 12
#define BUTTON_UP_GPIO 13
#define BUTTON_DOWN_GPIO 14
#define BUTTON_CFG 0
#include <SuplaDevice.h>
#include <supla/control/roller_shutter.h>
#include <supla/control/action_trigger.h>
#include <supla/events.h>
// Choose where Supla should store roller shutter data in persistent memory
// We recommend to use external FRAM memory
Supla::Eeprom eeprom;
// #include <supla/storage/fram_spi.h>
// Supla::FramSpi fram(STORAGE_OFFSET);
Supla::ESPWifi wifi;
Supla::Device::StatusLed statusLed(STATUS_LED_GPIO, true); // inverted state
void setup() {
  Serial.begin(115200);
  // HTML www component
  new Supla::Html::DeviceInfo(&SuplaDevice);
  new Supla::Html::WifiParameters;
  new Supla::Html::ProtocolParameters;
  new Supla::Html::StatusLedParameters;
  // Channels configuration
  // CH 0 - Roller shutter
  auto rs = new Supla::Control::RollerShutter(
      ROLLER_SHUTTER_UP_RELAY_GPIO, ROLLER_SHUTTER_DOWN_RELAY_GPIO, true);
  // CH 1 - Relay
  auto r1 = new Supla::Control::Relay(RELAY_GPIO);
  // CH 2 - Action trigger
  auto at1 = new Supla::Control::ActionTrigger();
  // CH 3 - Action trigger
  auto at2 = new Supla::Control::ActionTrigger();
  // CH 4 - Action trigger
  auto at3 = new Supla::Control::ActionTrigger();
  // Buttons configuration
  auto buttonOpen = new Supla::Control::Button(BUTTON_UP_GPIO, true, true);
  auto buttonClose = new Supla::Control::Button(BUTTON_DOWN_GPIO, true, true);
  auto buttonCfgRelay = new Supla::Control::Button(BUTTON_CFG, true, true);
  buttonCfgRelay->setHoldTime(1000);
  buttonCfgRelay->setMulticlickTime(800);
  buttonCfgRelay->configureAsConfigButton(&SuplaDevice);
  buttonCfgRelay->addAction(Supla::TOGGLE_CONFIG_MODE, SuplaDevice, Supla::ON_CLICK_5);
  buttonOpen->addAction(Supla::OPEN_OR_STOP, *rs, Supla::ON_PRESS);
  buttonOpen->setHoldTime(1000);
  buttonOpen->setMulticlickTime(300);
  buttonClose->addAction(Supla::CLOSE_OR_STOP, *rs, Supla::ON_PRESS);
  buttonClose->setHoldTime(1000);
  buttonClose->setMulticlickTime(300);
  buttonCfgRelay->addAction(Supla::TOGGLE, r1, Supla::ON_CLICK_1);
  // Action trigger configuration
  at1->setRelatedChannel(rs);
  at1->attach(buttonOpen);
  at2->setRelatedChannel(rs);
  at2->attach(buttonClose);
  at3->setRelatedChannel(r1);
  at3->attach(buttonCfgRelay);
  // configure defualt Supla CA certificate
  SuplaDevice.begin();
void loop() {
  SuplaDevice.iterate();
W logach dość wyraźnie widać, że jest problem z formatowaniem partycji do little fs.
Pewnie masz źle partycje ustawione
nebraska
klew wrote: Sat Oct 11, 2025 2:18 pm W logach dość wyraźnie widać, że jest problem z formatowaniem partycji do little fs.
Tak to wiem, tylko nie wiem jak je ustawic?
W ustawieniach boarda w Arduino wybiera się partycję.
Potrzebujesz coś z spifs (na tym też little fs chodzi)
nebraska
klew wrote: Sat Oct 11, 2025 2:29 pm W ustawieniach boarda w Arduino wybiera się partycję.
chyba jestem ślepy nie widze tego. Jeśli to flash size to przestawiałem, ale nic nie daje :roll:
Has thanked: 37 times
Been thanked: 27 times
Mi się bez problemu ten szkic kompiluje. Ustawienie domyślne dla płytki.
nebraska
Robert Błaszczak wrote: Sat Oct 11, 2025 2:49 pm Mi się bez problemu ten szkic kompiluje. Ustawienie domyślne dla płytki.
Robercie u mnie tez się kompiluje tylko kiedy chce wprowadzić do Supli ze strony CFG jak wpisze dane i save&restart to wyrzuca problem z partycją
U ciebie urządzenie rejestruje się w Supli?
Siedze nad tym 3 godz i ciągle to samo bez cfg urządzenie się loguje w Supli a web ciągle ta partycja. :roll:
Has thanked: 289 times
nebraska wrote: Sat Oct 11, 2025 2:56 pm
Jakie masz opcje pod pozycją FLASH SIZE?
nebraska
vajera wrote: Sat Oct 11, 2025 3:01 pm
nebraska wrote: Sat Oct 11, 2025 2:56 pm Robercie u mnie tez się kompiluje tylko kiedy chce wprowadzić do Supli ze strony CFG jak wpisze dane i save&restart to wyrzuca problem z partycją
Niestety nie mam już żadnego ESP8266 żeby to zweryfikować.
