Convert Heatpol Element to WiFi?
Alexmillar
Sorry if this isn't the correct sub forum to post this in, happy to move it if needed but wondering if anyone can help me.
Context: about 5 years ago I bought ready filled DQ modus radiators that use the Heatpol WiFi Enabled Element/Controller.
2 or so years ago we realised we needed some additional radiators and I found by chance someone on eBay selling some Heatpol elements that I assumed were the WiFi ones (I didn't realise they made both WiFi and Non WiFi ones that look identical...my bad)
Anyway I'm now at a point of being ready to set these up and I'm wondering if there is a way to convert/modify the non WiFi elements to work via Supla in the same way that my other WiFi enabled ones do?
My assumption is that there is some sort of relay module that 'plugs in' to the standard non WiFi element in some way, I'm pretty competent with modifying circuit boards etc so if this is something that's possible I'm confident I could do it, I just need to figure out what my options are and what I might be able to purchase in order to do this.
Thanks in advance for any suggestions!
I doubt if this is possible.
Most probably the easiest way is to replace all electronic parts and then prepare software for this new device
malarz
You can try contacting Heatpol technical support and asking about the appropriate replacement parts.
https://heatpol.pl/en/contact/
Return to “Zrób to sam”
