Https and Https service doesn't work after upgrade to the last release 26.03.01
micdj
Hello! I upgrade as normally i did in the past, with supla.sh upgrade command, now the services cloud server and database are on, app comunicate throw 2015 and 2016 port, but https port in not reachable, if i see logs I can see this error:
Database connection has been established.
[OK] Metadata storage synchronized
[OK] Already at the latest version
("SuplaBundle\Migrations\Migration\Version20260330150252")
[OK] The "async" transport was set up successfully.
[ERROR] Could not contact AD.
[ERROR] Service temporarily unavailable
Creating SQL procedures and views
Number of scripts to execute: 39
Procedures
✅ supla_add_channel.sql
✅ supla_add_client.sql
✅ supla_add_em_current_log_item.sql
✅ supla_add_em_power_active_log_item.sql
✅ supla_add_em_voltage_aberration_log_item.sql
✅ supla_add_em_voltage_log_item.sql
✅ supla_add_iodevice.sql
✅ supla_calculate_channel_checksum.sql
✅ supla_calculate_device_checksum.sql
✅ supla_current_weekday_hour.sql
✅ supla_is_now_active.sql
✅ supla_mark_gate_closed.sql
✅ supla_mark_gate_open.sql
✅ supla_mqtt_broker_auth.sql
✅ supla_oauth_add_client_for_app.sql
✅ supla_oauth_add_token_for_alexa_discover.sql
✅ supla_oauth_add_token_for_app.sql
✅ supla_register_device_managed_push.sql
✅ supla_set_channel_caption.sql
✅ supla_set_channel_group_caption.sql
✅ supla_set_channel_json_config.sql
✅ supla_set_closing_attempt.sql
✅ supla_set_device_json_config.sql
✅ supla_set_location_caption.sql
✅ supla_set_scene_caption.sql
✅ supla_update_channel_conflict_details.sql
✅ supla_update_channel_extended_value.sql
✅ supla_update_channel_flags.sql
✅ supla_update_channel_functions.sql
✅ supla_update_channel_state.sql
✅ supla_update_channel_value.sql
✅ supla_update_client.sql
✅ supla_update_device_pairing_result.sql
✅ supla_update_iodevice.sql
✅ supla_update_push_notification_client_token.sql
✅ supla_update_subdevice.sql
Views
✅ supla_v_accessid_active.sql
✅ supla_v_auto_gate_closing.sql
✅ supla_v_client_channel.sql
Client for webapp exists.
// Warming up the cache for the prod environment with debug
// false
[OK] Cache for the "prod" environment (debug=false) was successfully warmed.
User [email protected] already exists.
micdj wrote: Sun Apr 19, 2026 2:28 pm
Do you use Proxmox? If yes, then here is a similar problem with a solution: viewtopic.php?p=234982#p234982
micdj
Solved! The problem was to left First user e First password setted in .env file, with the 26.x version, supla cloud crash, I removed and solved.
fracz
Has thanked: 4 times
Been thanked: 6 times
I also detected this issue yesterday. Will be solved in the upcoming release. Thank you!
Return to “Help”
