Hi.
I have bought a Varilight Dual Dimmer (V-PRO SMART) and it seems to have paired correctly, however I am only see 1 dimmer control in the application. Do you need to press the dimmer button down on the 2nd dimmer to pair that separately?
Dual dimmer only showing 1 dimmer in app?
showstopper
Thanks for this. How do I do that as if I hold the 2nd dimmer button it never seems to flash and the bulb is just pulsing. Also should it show in the app without a bulb? If not could it be wired wrong?
