[Zgłoszenie] (_TZE200_crq3r3la::CK-BL702-MWS-01(7016)) [bramka ZigBee]
edm
Witam.
Proszę o dodanie czujnik obecności radar MmWave 24G. (_TZE200_crq3r3la::CK-BL702-MWS-01(7016))
https://pl.aliexpress.com/item/1005005876174817.html
Dokładam kod dla tego urządzenia, który odczytałem za pomocą Tuya Developer Platform.
Robiłem to bardzo dawno temu ale na 99% obstawiam że to jest właściwy kod tego urządzenia.
Code	Type	Values
presence_state	Enum
  "range": [
    "none",
    "presence"
sensitivity	Integer
  "unit": "x",
  "min": 0,
  "max": 10,
  "scale": 0,
  "step": 1
near_detection	Integer
  "unit": "cm",
  "min": 0,
  "max": 1000,
  "scale": 0,
  "step": 1
far_detection	Integer
  "unit": "cm",
  "min": 0,
  "max": 1000,
  "scale": 0,
  "step": 1
human_motion_state	Enum
  "range": [
    "none",
    "large_move",
    "small_move",
    "breathe",
    "far",
    "near"
presence_time	Integer
  "unit": "s",
  "min": 0,
  "max": 28800,
  "scale": 0,
  "step": 1
dp_false_alarm	Integer
  "unit": "x",
  "min": 0,
  "max": 20,
  "scale": 0,
  "step": 1
motionless_far_detection	Integer
  "unit": "cm",
  "min": 0,
  "max": 600,
  "scale": 0,
  "step": 1
motionless_sensitivity	Integer
  "unit": "x",
  "min": 0,
  "max": 10,
  "scale": 0,
  "step": 1
illuminance_value	Integer
  "unit": "lux",
  "min": 0,
  "max": 6000,
  "scale": 0,
  "step": 1
indicator	Boolean
"{true,false}"
breathe_detection	Integer
  "unit": "cm",
  "min": 0,
  "max": 600,
  "scale": 0,
  "step": 1
breathe_sensitivity	Integer
  "unit": "x",
  "min": 0,
  "max": 10,
  "scale": 0,
  "step": 1
micro_min_detection	Integer
  "unit": "cm",
  "min": 0,
  "max": 600,
  "scale": 0,
  "step": 1
bre_min_detection	Integer
  "unit": "cm",
  "min": 0,
  "max": 600,
  "scale": 0,
  "step": 1
reset_setting	Boolean
"{true,false}"
false_breath	Boolean
"{true,false}"
study_timer	Integer
  "unit": "s",
  "min": 0,
  "max": 300,
  "scale": 0,
  "step": 1
alarm_time	Integer
  "unit": "min",
  "min": 0,
  "max": 60,
  "scale": 0,
  "step": 1
alarm_volume	Enum
  "range": [
    "low",
    "middle",
    "high",
    "mute"
host_mode	Enum
  "range": [
    "arm",
    "disarm",
    "sos",
    "doorbell"
mov_auto	Boolean
"{true,false}"
micr_auto	Boolean
"{true,false}"
bre_auto	Boolean
"{true,false}"
batttery	Integer
  "unit": "%",
  "min": -1,
  "max": 100,
  "scale": 0,
  "step": 1
distance	Integer
  "unit": "cm",
  "min": 1,
  "max": 2000,
  "scale": 0,
  "step": 1
detection_near	Integer
  "unit": "cm",
  "min": 0,
  "max": 600,
  "scale": 0,
  "step": 1
resend_presence	Boolean
"{true,false}"
Has thanked: 289 times
edm wrote: Wed Jul 08, 2026 8:07 pm Witam.
+BWNU:1.5.130-08/07/26.
edm
Czujnik z powodzeniem dodał się do bramki. Wygląda że częściowo działa, tzn. wykrywa ruch (obecność).
Jednak w ZIGBEE <=> SUPLA CONTROL PANEL ---> Tuya custom cluster (0xEF00) devices.
W polu Tuya datapoints jakby nie działały ustawienia?.
Cokolwiek nie wybiorę z listy "Tuya datapoints" np. "Large motion detection sensitivity" i klikam na "Data query" to w "Command Result" mam info "Tuya custom cluster data query sent successfully!". Ale pole "Command Response payload zawsze wyświetla tylko "...".
Także nie wyświetla zapisanych ustawień. Pomimo że niby da się je poprawnie wprowadzić używając "Data request". Aczkolwiek nie wiem czy je faktycznie przyjmuje i zapisuje.
Zrobiłem test na parametrze "LED indicator" gdzie w pole "Datapoint value (numbers only, no range checking)" wpisałem wartość 0 a później 1, zatwierdzając "Data request" i niby w polu "Command Result"
Tuya custom cluster data request sent successfully!
Datapoint id   = 107(0x6B)
Datapoint type = BOOL(0x01)
Datapoint length 	= 1(0x01)
Datapoint value = 1(0x01)
Enter numeric value:
0 => set indicator OFF
1 => set indicator ON
Jednak fizycznie LED cały czas jest wyłączony bez względu na to czy zapisałem parametr 0 czy 1.
Po czym użyłem "Data query" i w polu "Command Result" jest "Tuya custom cluster data query sent successfully!" a w polu "Command Response payload" "...".
edm wrote: Thu Jul 09, 2026 9:44 am Czujnik z powodzeniem dodał się do bramki. Wygląda że częściowo działa, tzn. wykrywa ruch (obecność).
To pole Command Response payload zostało celowo wyłączone w trakcie poszukiwań przyczyny nieregularnych restartów niektórych bramek. Przyczyna została już odnaleziona, więc w sumie mogę je odblokować i wtedy zobaczymy, co urządzenie zwraca. Dane do tych datapoints zaczerpnąłem z sieci, więc są na tyle wiarygodnie, co w ZigBee2MQTT.
edm
A widzisz. Nie wiedziałem że to zostało celowo wyłączone w poszukiwaniu przyczyny restartów bramki.
Także poproszę o włączenie tego ponownie. Ładne widać było co zwraca bramka.
Daj znać jak to przywrócisz. Zrobię aktualizacje.
edm wrote: Thu Jul 09, 2026 10:27 am A widzisz. Nie wiedziałem że to zostało celowo wyłączone w poszukiwaniu przyczyny restartów bramki.
+BWNU:1.5.135-09/07/26
edm
vajera wrote: Thu Jul 09, 2026 8:04 pm +BWNU:1.5.135-09/07/26
Dziękuję.
