Hello Supla team!
Now, i am in the middle of developing the hardware with ESP8266 for Gate/Gateway operation.
I just flashing the hardware with "Gate Module Firmware" ver 1.8.2 https://github.com/SUPLA/ESP8266/tree/m ... e-firmware
Flashing process seems good, and already configured in svr1.supla.org with configuration like this :
https://www.dropbox.com/s/4eylxx3gjm357 ... M.jpg?dl=0
My question is :
1. What is the corelation between Gateway Lock operation, On/Off switch, and Gateway opening sensor?
2. Could you tell me proper usability of this fimware?
3. When i try to connect the frimware (ver 1.8.2) to my own supla cloud app (ver 1), something get wrong in the android app. The mobile app cannot show the UI.
Looking forward for the guidance.
Thanks.
Usability of "Gate Module Firmware" ver 1.8.2
astonix
1. Ok, got it. But there is also Button with caption "OPEN" on the Gate. When i press this button, it will open the gate (1 sec, 2 sec, 5 sec or 10 sec).pzygmunt wrote: Tue Mar 07, 2017 1:19 pm Hi.
1. You can use opening sensor to check that gate/doors if they are open or not.
2. Not really understand
3. I need to get access to your server for check it
Another button which is influence the Gate is ON/OFF Switch. When i press the ON/OFF switch, it will also open or close the gate.
So, i think it makes user confuse with some of button work with same function.
3. Please login to my server with previous credential that i sent to you.
- Been thanked: 59 times
It depends which function did you choose. The 1,2,3 sec time describe, how long relay should be ON when you touch "OPEN/CLOSE" button. How it works depend how you connected SUPLA device to gate driver. Normally it shoild works like this:
First touch (OPEN/CLOSE): Start opening the gate
Second touch (OPEN/CLOSE): Stop opening the gate
Third touch (OPEN/CLOSE): Start closing the gate
