Only garage function available
sambuls
When I install Supla out of the box on my RPI and connect via the cellphone app I can see some garage and gate control functions.
When I try to change these channel function in the Supla Cloud I can only change them relating to gate or garage functions.
How can I change these relating to light functions?
Kind regards
You must change RBPI configuration.
Edit /etc/supla-dev/supla.cfg
/etc/init.d/supla-device restart
sambuls
Thank you for your reply.
In the config file, several channels are defined as type HFD4 or SENSORNO.
I can not find anything related to garage/gate references.
Could you provide me with more information on how to change these channels so that they are related to lighting io?
kind regards
sambuls
I changed the type to RELAYG5LA1A, this enable me to select lighting properties in the supla Cloud.
Is there a description available for this config file?
kind regards
sam
What description you need ?
Return to “General discussion”
