Compile own ESP8266 firmware with Espressif IOT SDK
At ftp://ftp.acsoftware.pl/SUPLA/SUPLA-IOT-SDK.ova
everybody can download ready for run virtual machine dedicated for VirtualBox.
Inside you can find ESP8266 IOT SDK ready to build SUPLA firmware.
To build firmware just import Virtual Machine to your VirtualBox. Then login as supla user (password: supla). Open "ESP8266 firmware" directory, and run BUILD script.
You can also edit sources by Eclipse.
KresoMat
i was trying to download 32 and 64bit OVA but when dl reach 4GB download interrupt and
never finish... what can i do ? i try to dl from ftp, but it don't work ? is it ftp down ?
can you try with http://mega.nz i found it 50gb for free, (is not commercial)
i have my wm based on esphttpd and israelot, but regarding toolchain and
SDKver probably wouldn't work, so I would like to have your VM to learn something new :)
KresoMat
nope,
tryed on ie,chrome, other PC....
can you please upload on MEGA.nz
Check your internet connection quality or OS settings. I'm sure that is not problem of the google drive.
KresoMat
ok, maybe, but i tryed on 2 pc at home and thrird at work....
now i check on other people with similar problems...
https://productforums.google.com/forum/ ... ZjJqotSm1Y
https://productforums.google.com/forum/ ... jD_Rk6gf4c hm, they told chrome could be reason, i will try again with
ff and ie, actually i tried with ie, but then was interrupted early.. i have portable browsers installed.... when try will update status....
update:
ok... finally i downed it with no problem, but with Firefox, obviously chrome + google-Disk combination have some problems @4gb....
maybe this "research" help someone... Im at least 7 time reached 3.99G and @ 4Gb break downl. with network error, all because chrome+W10pro64...
regards
scropion86
the developing environment Link is not available .
please re-check the link and update it please
wiot
Making a library is very useful and basic for existing webconfig scripts.
Do you plan to make a basic library.
Return to “General discussion”
