I've freshly flashed my esp with a gate-module-firmware, for the beginning Nothing expected wrong. I configured the module network and works, but when I try to enter the module into his config mode to update the wifi(pass,ssid), it reboots and reconnects again to the same IP.
I respect these configurations:
PORT SETTINGS:
[CHANNEL0] RELAY1 GPIO4
[CHANNEL1] RELAY2 GPIO13
CFG BUTTON GPIO5 // pulled up to 3.3V - RES 10kohm // pressing and hold >5s...
LED
- GREEN GPIO12
- BLUE GPIO14
[CHANNEL2] INPUT_PORT1 GPIO12
[CHANNEL3] IMPUT_PORT2 GPIO14
pls help, thanks in advance.
Updating WiFi Credentials
bouali
Ok, understood. my flash has 4MB size.
Thank you pzygmunt
Thank you pzygmunt
bouali
I've checked the [ESP8266 SDK
Getting Started Guide].
I'll reflash it, and I will get back to you once I have a problem.
