#define B_RELAY1_PORT 12
#define B_RELAY2_PORT 13
#define B_RELAY3_PORT 14
#define B_CFG_PORT 0
#define B_BTN2_PORT 4
#define B_BTN3_PORT 5
void supla_esp_board_set_device_name(char *buffer, uint8 buffer_size) {
ets_snprintf(buffer, buffer_size, "SUPLA-SOCKETx3");
void supla_esp_board_gpio_init(void) {
supla_input_cfg[0].type = INPUT_TYPE_BTN_MONOSTABLE;
supla_input_cfg[0].gpio_id = B_CFG_PORT;
supla_input_cfg[0].flags = INPUT_FLAG_PULLUP | INPUT_FLAG_CFG_BTN;
supla_input_cfg[0].relay_gpio_id = B_RELAY1_PORT;
supla_input_cfg[0].channel = 0;
supla_input_cfg[1].type = INPUT_TYPE_BTN_MONOSTABLE;
supla_input_cfg[1].gpio_id = B_BTN2_PORT;
supla_input_cfg[1].flags = INPUT_FLAG_PULLUP;
supla_input_cfg[1].relay_gpio_id = B_RELAY2_PORT;
supla_input_cfg[1].channel = 1;
supla_input_cfg[2].type = INPUT_TYPE_BTN_MONOSTABLE;
supla_input_cfg[2].gpio_id = B_BTN3_PORT;
supla_input_cfg[2].flags = INPUT_FLAG_PULLUP;
supla_input_cfg[2].relay_gpio_id = B_RELAY3_PORT;
supla_input_cfg[2].channel = 2;
supla_relay_cfg[0].gpio_id = B_RELAY1_PORT;
supla_relay_cfg[0].flags = RELAY_FLAG_RESET;
supla_relay_cfg[0].channel = 0;
supla_relay_cfg[1].gpio_id = B_RELAY2_PORT;
supla_relay_cfg[1].flags = RELAY_FLAG_RESET;
supla_relay_cfg[1].channel = 1;
supla_relay_cfg[2].gpio_id = B_RELAY3_PORT;
supla_relay_cfg[2].flags = RELAY_FLAG_RESET;
supla_relay_cfg[2].channel = 2;
void supla_esp_board_set_channels(TDS_SuplaDeviceChannel_B *channels, unsigned char *channel_count) {
*channel_count = 3;
channels[0].Number = 0;
channels[0].Type = SUPLA_CHANNELTYPE_RELAY;
channels[0].FuncList = SUPLA_BIT_RELAYFUNC_POWERSWITCH \
| SUPLA_BIT_RELAYFUNC_LIGHTSWITCH;
channels[0].Default = SUPLA_CHANNELFNC_LIGHTSWITCH;
channels[0].value[0] = supla_esp_gpio_relay_on(B_RELAY1_PORT);
channels[1].Number = 1;
channels[1].Type = channels[0].Type;
channels[1].FuncList = channels[0].FuncList;
channels[1].Default = channels[0].Default;
channels[1].value[0] = supla_esp_gpio_relay_on(B_RELAY2_PORT);
channels[2].Number = 2;
channels[2].Type = channels[0].Type;
channels[2].FuncList = channels[0].FuncList;
channels[2].Default = channels[0].Default;
channels[2].value[0] = supla_esp_gpio_relay_on(B_RELAY3_PORT);
void supla_esp_board_send_channel_values_with_delay(void *srpc) {
supla_esp_channel_value_changed(0, supla_esp_gpio_relay_on(B_RELAY1_PORT));
supla_esp_channel_value_changed(1, supla_esp_gpio_relay_on(B_RELAY2_PORT));
supla_esp_channel_value_changed(2, supla_esp_gpio_relay_on(B_RELAY3_PORT));
I tried RELAY_FLAG_RESTORE_FORCE or RELAY_FLAG_RESTORE
i change "#define B_RELAY1_PORT 12" to "#define B_RELAY1_PORT 13" but same thing
