u8g2.drawBitmap( 15, 32, 4, 32, hause);Wklejam cały kod programu:
* Supla.org NodeMCU WiFi minimal example
* Author: Programistyk - Kamil Kaminski <[email protected]>
* This example shows how to configure SuplaDevice for building for NodeMCU within Arduino IDE
// Biblioteki
#include <srpc.h>
#include <log.h>
#include <eh.h>
#include <proto.h>
#include <IEEE754tools.h>
// We define our own ethernet layer
#define SUPLADEVICE_CPP
#include <SuplaDevice.h>
#include <lck.h>
#include <OneWire.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#include <WiFiClient.h>
#include <ESP8266WiFiType.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiScan.h>
#include <ESP8266WiFiMulti.h>
#include <WiFiServer.h>
#include <ESP8266WiFiGeneric.h>
#include <WiFiClientSecure.h>
#include <ESP8266WiFiAP.h>
#include <ESP8266WiFiSTA.h>
#include <WiFiUdp.h>
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
static const unsigned char PROGMEM hause[] = {
0x00, 0x01, 0x80, 0x00,
0x00, 0x03, 0x80, 0x00,
0x00, 0x06, 0x60, 0x00,
0x00, 0x0c, 0x31, 0xc0,
0x00, 0x18, 0x13, 0x40,
0x00, 0x10, 0x0d, 0x40,
0x00, 0x60, 0x0c, 0x40,
0x00, 0x40, 0x03, 0x40,
0x01, 0xc0, 0x03, 0x40,
0x01, 0x00, 0x00, 0x80,
0x03, 0x00, 0x00, 0xe0,
0x06, 0x00, 0x00, 0x20,
0x0c, 0x00, 0x00, 0x30,
0x18, 0x00, 0x00, 0x18,
0x38, 0x00, 0x00, 0x0c,
0x70, 0x00, 0x00, 0x1e,
0xd0, 0x00, 0x00, 0x0b,
0x18, 0x0e, 0xf0, 0x18,
0x10, 0x0a, 0x90, 0x08,
0x10, 0x18, 0x18, 0x08,
0x10, 0x08, 0x10, 0x18,
0x18, 0x08, 0x10, 0x08,
0x10, 0x10, 0x10, 0x08,
0x18, 0x08, 0x10, 0x10,
0x10, 0x18, 0x10, 0x08,
0x18, 0x08, 0x10, 0x18,
0x11, 0x18, 0x19, 0x10,
0x1f, 0xff, 0xff, 0xf8
// Zmienne globalne
float tempC = 0.0;
int pressure = 0;
float hum = 0.0;
char temp_string[5]; //empty char array to hold the converted temp float
char hum_string[5]; //empty char array to hold the converted humidity float
char pressure_string[5]; //empty char array to hold the converted humidity float
WiFiClient client;
Adafruit_BME280 bme;
// U8g2 Contructor
U8G2_ST7920_128X64_F_SW_SPI u8g2(U8G2_R0, /* clock=*/ 14, /* data=*/ 13, /* CS=*/ 15, /* reset=*/ U8X8_PIN_NONE);
// Setup Supla connection
const char* ssid = "xxx";
const char* password = "yyy";
// BMP280 Sensor read implementation
void get_temperature_and_humidity(int channelNumber, double *temp, double *humidity) {
*temp = bme.readTemperature();
tempC = *temp;
*humidity = bme.readHumidity();
hum = *humidity;
pressure = bme.readPressure()/100;
Serial.print("Temp : ");
Serial.print(*temp);
Serial.print(" Wilgotność : ");
Serial.print(*humidity);
Serial.print(" Ciśnienie : ");
Serial.println(pressure);
if ( isnan(*temp) || isnan(*humidity) ) {
*temp = -275;
*humidity = -1;
} //void
void setup() {
Serial.begin(115200);
delay(10);
u8g2.begin();
if(!bme.begin(0x76))
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1)
yield();
delay(200);
// Set temperature callback
SuplaDevice.setTemperatureHumidityCallback(&get_temperature_and_humidity);
// Replace the falowing GUID
char GUID[SUPLA_GUID_SIZE] = {xxxxxxx};
// Ethernet MAC address
uint8_t mac[6] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
// CHANNEL0 - RELAY
//SuplaDevice.addRelay(D0); // 44 - Pin number where the relay is connected
// Call SuplaDevice.addRelay(44, true) with an extra "true" parameter
// to enable "port value inversion"
// where HIGH == LOW, and LOW == HIGH
// CHANNEL1 - DIMMER
//SuplaDevice.addDimmer();
// CHANNEL2 - RGB
//SuplaDevice.addRgbController();
// CHANNEL3 - DIMMER
// CHANNEL1 - RELAY
// SuplaDevice.addRelay(45, true); // 45 - Pin number where the relay is connected
// CHANNEL3 - TWO RELAYS (Roller shutter operation)
//SuplaDevice.addRollerShutterRelays(46, // 46 - Pin number where the 1st relay is connected
// 47, true); // 47 - Pin number where the 2nd relay is connected
// CHANNEL4 - Opening sensor (Normal Open)
//SuplaDevice.addSensorNO(A0); // A0 - Pin number where the sensor is connected
// Call SuplaDevice.addSensorNO(A0, true) with an extra "true" parameter
// to enable the internal pull-up resistor
// CHANNEL5 - Opening sensor (Normal Open)
//SuplaDevice.addSensorNO(A1); // A1 - Pin number where the sensor is connected
// CHANNEL6 - DHT22 Sensor
// SuplaDevice.addDHT11();
// SuplaDevice.addAM2302();
SuplaDevice.addDHT22();
//SuplaDevice.addDS18B20Thermometer();
mac, // Ethernet MAC address
"svr1.supla.org", // SUPLA server address
xxx, // Location ID
"xxx"); // Location Password
u8g2.firstPage();
do {
draw_Str_1();
} while( u8g2.nextPage() );
delay(2000);
void loop() {
SuplaDevice.iterate();
u8g2.firstPage();
do {
draw_Str_2();
// Supla.org ethernet layer
if ( size > 0 ) {
return -1;
return client.connected();
client.stop();
// Serial.println("WiFi init");
WiFi.begin(ssid, password);
delay(500);
// Serial.print(".");
//Serial.print("\nlocalIP: ");
//Serial.println(WiFi.localIP());
//Serial.print("subnetMask: ");
//Serial.println(WiFi.subnetMask());
//Serial.print("gatewayIP: ");
//Serial.println(WiFi.gatewayIP());
SuplaDeviceCallbacks cb;
cb.get_temperature = NULL;
cb.get_rgbw_value = NULL;
cb.set_rgbw_value = NULL;
return cb;
void draw_Str_1(void){
u8g2.drawFrame(0,20,128,17); // ramka ZEWNĘTRZNA (start x, start y, szerokość, wysokość)
u8g2.drawFrame(2,22,124,13); // górna WEWNĘTRZNA (start x, start y, szerokość, wysokość)
u8g2.setFont(u8g2_font_helvB08_tr); // rozmiar i krój czcionki 9 px
u8g2.drawStr(9, 32, "STACJA POGODOWA"); // położenie i tekst do wyswietlenia
u8g2.drawStr(1, 60, "MATEUSZ WROBEL 2018"); // położenie i tekst do wyswietlenia
void draw_Str_2(void) {
// tu zamieszczamy polecenia graficzne do wyświetlenia całego ekranu
drawText();
u8g2.drawVLine(50, 32, 31); // linia pionowa (odległość od lewej strony, odległość od góry, długość linii pionowej)
void drawText(void) {
u8g2.setFont(u8g2_font_maniac_tn);
u8g2.drawStr(25, 30, "22:42");
u8g2.setFont(u8g2_font_6x12_tf);
dtostrf(tempC, 3, 1, temp_string);
u8g2.drawStr(55, 40, temp_string);
u8g2.drawStr(79, 40, "°C"); //°
dtostrf(pressure, 3, 0, pressure_string);
u8g2.drawStr(55, 51, pressure_string);
u8g2.drawStr(81, 51, "hPa");
dtostrf(hum, 3, 1, hum_string);
u8g2.drawStr(55, 62, hum_string);
u8g2.drawStr(81, 62, "%");
//u8g.drawBitmapP( 15, 32, 4, 32, sun_regular);
//u8g.drawBitmapP( 15, 32, 4, 32, clouds);
//u8g.drawBitmapP( 15, 32, 4, 32, rain);
